Anyone know how to tell which USB ports are Hi speed?
  • Thread starter Thread starter Saladsamurai
    Hi Speed Usb
The discussion centers around identifying which USB ports on a computer are "Hi speed," particularly in the context of transferring files quickly during a system backup and factory restore. Participants explore various methods to determine the speed of USB ports, including testing and device manager observations.
  • Some participants suggest that USB 2.0 ports are classified as "Hi speed," indicating that most computers made since 2001 should have these ports.
  • One participant mentions checking the device manager to identify which port is Hi-speed but expresses uncertainty about how to determine this.
  • Another participant proposes testing each port with a flash drive and timing the transfer of a 10MB file to identify the faster ports.
  • There is a suggestion that it would be unusual for a computer to have a mix of USB 1.0 and 2.0 ports, especially if the computer has been upgraded.
  • One participant recalls that Windows provides a notification when a USB 2.0 device is plugged into a USB 1.0 port, which could help identify the port speeds.
  • Another participant discusses alternative methods for data transfer, such as using wired connections or adding USB 2.0 cards, while assuming the user has successfully backed up their data.
  • There is a mention that if no notification appears when a high-speed device is connected, it is likely that the port is high speed.
Participants express varying levels of certainty about the identification of USB port speeds, with no clear consensus on the best method to determine which ports are Hi speed. Multiple approaches and opinions are presented without resolution.
Some participants rely on assumptions about the age of the computer and its components, which may affect the accuracy of their claims regarding USB port speeds. There are also mentions of potential limitations in the device manager's reporting.
Saladsamurai
Anyone know how to tell which USB ports are "Hi speed?"
I read something about some of the USB ports on a computer being hi speed allowing for faster file transfers.
I am backing up my system now to do a factory restore and I want to make sure I am using the fastest ports since these 8 GB transfers are taking sooooooo long.
Thanks
Computer science news on Phys.org
Thanks
If it's USB 2.0 then it's high speed. Pretty much any computer components released since 2001 are USB 2.0.
I have gone to my device Manager and it appears that only 1 of the ports is Hi-speed, I am just not sure how to figure out which one it is...
I will try plugging a flash drive into all of them and see if anything changes under the device manager...
yeah. i cannot tell which of the 6 ports that I have is 2.0
the computer is at least 5-6 yrs old, so i don't think that they are all 2.0
Anyone know how to interpret this:
I couldn't tell you how to discern one from the other. Maybe test each one and time how long it takes to move a 10MB file. The 2.0 one will be at least 20 times faster.
Old trial and error. I like it. :smile:
The ports should be consistent. It would be very odd if 2 were 1.0 and 2 were 2.0
Did you upgrade your PC at some point?
If you plug a USB 2.0 device into a 1.0 port, Windows should notify you with a pop-up that says something like "This device can be made to operate faster by using another port."
- Warren
- Warren
I recall seeing this before. Not lately though. It makes me wonder if I checked a "Do not show this message again" box.
You can get add-in USB 2.0 cards for a few bucks, but it might be faster to use a wired connection to transfer your files over (assuming you have a 100 mbit network card and another computer with some spare space). The absolute fastest way of backing up lots of data over is to simply throw in a spare hard drive into the computer (using the ATA or SATA connection) and transfer files over. Yeah, I nuke / fix / restore computers fairly regularly.
But given your other question, I'll assume you've managed to back up your data successfully!
EDIT: If you only have one computer, this is the stage at which you acquire the necessary drivers, files, etc. to get your computer up and running, and connected to the net again.
If you plug in a high speed device your pc should say if its not a high speed one. If it says nothing then it is high speed.
  • · Replies 21 ·
9K
  • · Replies 36 ·
