Why Do P=IV and P=I^2*R Yield Different Results in This Case?
The discussion clarifies the discrepancy between the power calculations using the formulas P=IV and P=I^2*R in the context of a circuit with a current of 0.5 A, a voltage of 30 V, and a resistance of 40 Ω. While P=IV yields 15 W, the correct power dissipated through the resistor is 10 W, calculated using P=I^2*R. This difference arises because P=IV requires the voltage across the specific resistor, while P=I^2*R directly incorporates the resistance value, making it more reliable in this scenario. Understanding Ohm's Law is crucial for applying these formulas correctly.
  • Understanding of Ohm's Law (V=IR)
  • Familiarity with electrical power formulas (P=IV, P=I^2*R)
  • Basic knowledge of series and parallel resistor circuits
  • Ability to perform calculations involving voltage, current, and resistance
  • Study the implications of using P=IV in different circuit configurations
  • Learn how to apply Ohm's Law in complex circuits
  • Explore the differences between series and parallel resistor calculations
  • Investigate the conditions under which each power formula is most applicable
Students studying electrical engineering, physics enthusiasts, and anyone seeking to deepen their understanding of electrical power calculations in circuits.
pietastesgood
Part f. Calculated current = 0.5 A. Voltage = 30 V. Resistance = 40 Ω
P=IV
P=I^2*R
P=V^2/R
I've been curious about this for a while. Sometimes when I am asked to find the power dissipated through a resistor, and I use P=IV, it doesn't yield the same answer as if I used P=I^2*R, which is generally the correct answer. This is such an example. P=IV yields 15 W, while P=I^2*R yields 10 W, which is the correct answer. Can anyone explain this? And under which circumstances should I use P=I^2*R, and under which circumstances should I use P=IV? Thanks in advance!
The power dissipated in a resistor is P=IV where V is the voltage across the resistor and I is the current through the resistor. Ohm's Law states that the voltage across a resistor of resistance R is V=IR. So P=IV can also be written as P=I(IR)=I2R.
30 V is the voltage across the chain of the 40 Ω and 20 Ω resistors. It is 20 V across the 40 Ω resistor when the switch is closed for a long time.
ehild
Aha! I understand now, thanks!
