Answer AP Physics Q: Moment of Inertia, Angular Accel, Tension, Torque, & RKE
The forum discussion centers on solving a physics problem involving two uniform disks with equal mass, where the smaller disk has a radius R and moment of inertia I. The larger disk's moment of inertia is determined to be 2I, derived from the equation I(B) = m(2R) = 2I. The angular acceleration of the larger disk is found to be alpha(B) = alpha / 2, and the tension in the chain is calculated as T = (I*alpha) / R. The torque applied to the smaller disk is established as torque(A) = 2I*alpha, leading to the rotational kinetic energy equation RKE = (1/2)I*(alpha*t)^2.
  • Understanding of moment of inertia and its calculation for disks
  • Knowledge of angular acceleration and its relationship to torque
  • Familiarity with rotational dynamics and tension in connected systems
  • Ability to apply calculus to derive equations of motion in rotational systems
  • Study the derivation of moment of inertia for different shapes, focusing on disks
  • Learn about the relationship between torque, angular acceleration, and moment of inertia
  • Explore the principles of rotational kinetic energy and its applications
  • Investigate the effects of tension in systems with multiple connected rotating bodies
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors looking to enhance their understanding of rotational dynamics and problem-solving techniques in this area.
pezzang
Hi, thank you so much for making this kind of post for students like me. I have tried the quesotins but i want to make sure that i was right. if worng, please correct me.
THANK YOU SO MUCH. Also i had attached pictures of the question to give you enough information. PLEASE REFER TO THE PICTURE ATTACHED.
Q) The two uniform disks shown above have equal mass, and each can rotate on frictionless bearings about a fixed axis through its center. The smaller disk has a radius R and moment of inertia I about its axis.
(a) determine the moment of inertia of the larger disk about tis axis in terms of I.
-> I used the equation Inertia = mass*radius to solve this question,
Let's say that smaller disk has a subscript "A" and larger; "B".
Then, I(B) = m(2R) = mR(2).
since mR is equal to I, we have I(B) = I*2 = 2I
so the answer is 2*I. Am I right?
The two disks are then linked as shown below by a light chain that cannot slip. They are at rest when, at time t = 0, a student applies a torque to the smaller disk, and it rotates counterclockwise with constant angular acceleration alpha. Assume that the mass of the chain and the tension in the lower part of the chain are negligible.
In terms of I, R, alpha and t, determine each of the following.
(b) The angular acceleration of the larger disk (alpha(B))
-> torque(A) = I*alpha
torque(B) = 2I*alpha(B)
torque(A) = torque(B) <- IS IT POSSIBLE THAT I ASSUME THIS?
I*alpha = 2I*alpha(B)
alpha(B) = alpha / 2. <- AM I RIGHT?
(c) The tension in the upper part of the chain
T(Tension) = (I*alpha) / R.
T(A) = (I*alpha) / R
T(B) = (2I)(alpha(B)) / (2R) = (2I*alpha/2) / R = (I*(alpha) / (2R)
TO FIND TENSION, DO I SUBTRACT THE SMALLER ONE FROM LARGER ONE??
IF I DO, I GET:
T(A) = T(B) = (I*alpha) / R - (I*alpha) / (2R) = (I*alpha) / (2R)
Therefore, the tension in the upper part of the chain equals to (I*(alpha) / (2R).
(d) The torque that the student applied to the smaller disk
torque(A) = I*alpha <- I found this equation in my physics book. Is right? I kind of doubt it though. Please help me.
(e) The rotational kinetic energy of the smaller disk as a function of time
RKE = (1/2)*I*w^2 (omega)
to find an equation of w(omega) in terms of t and alpha, we take antiderivative of the equation alpha = (dw)/(dt), then we get:
alpha*t = w
IF we substitute alpha*t for w(omega) in the equation RKE = (1/2)*I*w^2 (omega), we get
So that is the answer.
So please correct me and thank you so much. Have a wonderful day, people!
I don't see the picture.
can i send you email so that you can see the pictures?
Please give me your email address. Thank you, again.
Use the attachment feature.
i tried but it does not work..ok i will explain instead
in the first picture for question part (a) only, there are two regular circles. circle A has a radius of R and circle B has a radius 2R. They have the same mass and are indeendent of each other.
in the second picture which will be used from part (b) to (e), the two circles described in the first picture are in a chain. the circle B on the right and Circle A on the left. the chain moves from left to right and the tension on the bottom part at first is zero.
i hope this helps to solve the question.
Thank you!
First things first: What's the moment of inertia of a disk about a central axis? It's I = 1/2 M R2
Redo the first part, then we'll continue.
Let me give you some tips on the other parts.
Forget about torques for this part. &alpha;A is a given. What's the relationship between &alpha;A and &alpha;B? Hint: the two disks are tied by a chain. What does that mean?
Also, no, you cannot assume that the torque is the same on both disks! Think about it. DiskA has two forces acting on it: the force applied by the student in giving his torque, and the tension in the chain pulling the other way. DiskB has only a single force on it.
IF I DO, I GET:
The way to solve c & d is to write down the torque equations for both disks and solve the two equations together.
Torquenet=I&alpha;, for each disk. (You'll need the results from parts b and a.)
alpha*t = w
Yes!
Than you so much. Here is what I have so far after getting your advice.
(a) Moment of Inertia of a disk is equal to I = (MR^2) / 2.
So, I(B) = (1/2) (M)(2R)^2 = 2MR^2.
Therefore, the answer is 2MR^2.
(b) Since the disks are connected by a chain, they have the same angular acceleration. Thus the angular acceleration of the larger disk is equal to just ¥áA, which is given in the problem.
(c) I do not know how to find tension. I guess the tension on the upper part of the chain would equal to torque(B) - torque(a). Since torque is equal to I*¥á, and ¥á is same for disk A and B,
Tension = (1/2)*M(2R^2)*¥á - (1/2)(MR^2)*¥á = (3/2)MR^2*¥á.
So, the answer is equal to (3/2)MR^2*¥á.
(d) torque of the smaller disk is equal to (1/2)(MR^2)*¥á, which we found in part(c).
How do they look now? Much closer?
Thank you for your helpful suggestions. Please leave me more feedbacks~!
Yes. Now put it in terms of IA= I;
IB= 4*(1/2MR2)= 4I
No, they have the same tangential acceleration, not angular acceleration. Think about it: the same length of chain must pass along each disk. Imagine the disk B was 1000 times bigger than disk A: the same bit of chain that turns A half way around would barely budge disk B.
Write out the torque equations for each disk. Tension is force; TensionXradius is the torque exerted by the tension.
You're getting closer. Keep going!
Thank you again for your advice.
I have found part (b) but i really can't solve part (c) and (d).
Can you please explain the answer in detail?
Meanwhile here is part (b)
(b) a(tan) = (dv)/(dt) = r*(dw)/(dt) = r*alpha.
a(tanA) = a(tanB)
R*alpha = (2R)*alpha(B)
alpha(b) = (R*alpha)/(2R) = alpha / R.
thus, the answer is alpha / R.
PLEASE TELL ME PART (C) AND (D). I AM REALLY REALLY REALLY CURIOUS~!
a(tanA) = a(tanB)
You messed up the algebra above: &alpha;B= &alpha;/2
OK, OK, you've suffered enough...
The torque equation for Disk B:
FTRB = IB &alpha;B
Which, when we use the results of a & b, becomes:
FT = I&alpha;/R(That's the answer to part C!)
The torque equation for Disk A:
&Tau;-FTR = I &alpha; (where FT is the tension; &Tau; is the the applied torque)
Now we can solve for &Tau; (using the answer from part C)
&Tau; = 2I&alpha; (That's the answer to part D.)
Make sense? Go over this until you understand it. (And you'd better check my algebra.)
I TRULY APPRECIATE YOUR HELP ALONG THE WAY.
EVERYONE OF US WHO GETS HELP FROM YOU ARE GRATEFUL TO YOU!
THANK YOU SO SO SO SO SO MUCH!
  • · Replies 97 ·
  • · Replies 45 ·
  • · Replies 18 ·
  • · Replies 17 ·
