Application of Fourier law of conduction
The discussion revolves around the application of Fourier's law of conduction to a wire with a temperature gradient, specifically exploring how temperature changes propagate along the wire over time. Participants examine the implications of the diffusion equation and the concept of heat transfer velocity, considering both theoretical and practical aspects.
  • One participant describes a scenario where one end of a wire is heated while the other remains cooler, questioning how long it takes for the temperature at the cooler end to begin to rise, and attempts to apply Fourier's law and the diffusion equation.
  • Another participant argues that the classical diffusion law suggests temperature would rise everywhere immediately, though it would occur very slowly at remote points, and proposes defining a threshold temperature rise to clarify the concept of heat-front velocity.
  • A question is raised about whether it is possible to extract a heat-front velocity directly from the heat equation, and if the equation itself indicates that the velocity of propagation is infinite.
  • One participant expresses uncertainty about whether the point of maximum temperature gradient aligns with the intuitive concept of a wavefront, suggesting that a threshold temperature rise might be a better definition.
  • Another participant notes that the diffusion equation is not relativistic and suggests that a relativistic framework is necessary for heat conduction analysis.
  • A reference to an equation related to the infinite uniform bar case is provided, indicating that the influence of initial temperature spreads out as the square root of time.
  • One participant thanks another for a resource but continues to seek clarity on why the velocity of heat transfer should be considered infinite based on the heat equation.
  • Another participant discusses an example with a high initial temperature over a small range, suggesting that practical limitations, such as the velocity of sound in the material, may explain discrepancies with theoretical predictions.
Participants express differing views on the nature of heat propagation, with some suggesting immediate temperature rise while others argue for a more nuanced understanding involving thresholds and practical limitations. The discussion remains unresolved regarding the implications of the heat equation and the concept of heat-front velocity.
Participants highlight limitations in the assumptions made about the wire's setup, such as the need for a heat reservoir or external source to maintain a temperature gradient. There is also mention of the non-relativistic nature of the diffusion equation and its implications for heat conduction analysis.
QuArK21343
Consider a wire of length l. At time t=0, one end of the wire is at temperature T_0, while the rest of the wire is at temperature T_1, T_1<T_0 (for example, one end of the wire is kept in contact with an external hot body, at temperature T_0). After how much time the temperature near the second end of the wire will begin to rise? I tried to use Fourier law of conduction, in particular I wrote. starting from the diffusion equation, that the Fourier transform of the function T(x,t) that gives the temperature along the wire is f(k)e^(-k^2Dt), D is the diffusion constant and f is to be determined from the initial conditions. From now on, I am not sure how to go on...
Science news on Phys.org
The classical diffusion law implies the temperature would start to rise everywhere in the conductor immediately. Diffusion doesn't have a 'speed' in that sense. Of course, it can't really happen faster than light, but that doesn't help much. The resolution is that it only starts to rise very slowly at first at remote points. So if you want the speed of diffusion to mean something you have to find another way to define it.
You could specify a threshold temperature rise; or you could define the 'wavefront' as being the location at which the temperature gradient is a maximum.
So, is it impossible to extract some kind of heat-front velocity directly from the heat equation (as in the classical wave equation)? And why is it so? Is there some way to see that the velocity of propagation is infinite from the equation itself?
Also, is there some simple way to estimate the velocity of the wavefront along which the temperature gradient is maximum?
Thanks
Actually I'm not at all sure that the point of maximum gradient reasonably matches the intuitive concept of wavefront. Rising above a temperature threshold would be better.
In the set up you state, there is zero length of wire at T_0, so I think you'll find the temperature will become T_1 everywhere immediately. You need more of a heat reservoir, or some external source maintaining one end at T_0.
Once you've clarified the set up you can try solving the equation and then seeing if some reasonable definition of wavefront provides an algebraic solution, but I don't hold out much hope.
The reason for this discrepency between the heat-conduction (diffusion) equation and special relativity is very simple: The diffusion equation is not relativistic. If you want to consider heat conduction within a relativistic framework you have to use relativistic transport theory.
More thoughts...
At http://www.mth.pdx.edu/~marek/mth510pde/notes%202.pdf there's a useful equation (2.4.12) for the infinite uniform bar case. For t > 0, substituting x+2y√t for y inside the integral gives u(x, t) = (1/√π)∫e^(-y^2).g(x+2y√t).dy.
That can be read as indicating that the influence of an initial temperature g(x) at point x spreads out as the square root of time.
Thank you, haruspex, for your link. I'll read it with care (I've had a quick look and seems good). Yet, I still don't see if and why the velocity of heat transfer should be infinite (I mean, is there a way to look at the heat equation and see it?).
Looking at eqn 2.4.12, consider some very small t > 0 and an initial distribution with a very high temp over a smal range around x =0, 0 elsewhere.
The integral gives a positive result for all x.
I don't think you need to invoke relativity to explain why this doesn't happen in practice. It's probably limited by the velocity of sound in the object.
  • · Replies 23 ·
