What is the proof of Zorn's lemma for extending linear transformations?
  • Thread starter Thread starter mahler1
    Application
The discussion focuses on proving the extension of a linear transformation f from a subspace S of a vector space V to the entire space V using Zorn's lemma. The proof involves defining a partially ordered set P of pairs (U, T), where U is a subspace containing S and T is a linear transformation satisfying T restricted to S equals f. By demonstrating that every totally ordered subset of P has an upper bound, Zorn's lemma guarantees the existence of a maximal element, leading to the conclusion that the linear transformation can indeed be extended to the whole vector space V.
  • Understanding of vector spaces and subspaces in linear algebra.
  • Familiarity with linear transformations and their properties.
  • Knowledge of Zorn's lemma and its application in proofs.
  • Ability to work with partially ordered sets and maximal elements.
  • Study the application of Zorn's lemma in various mathematical contexts.
  • Explore the properties of linear transformations in vector spaces.
  • Learn about the structure of partially ordered sets and their significance in proofs.
  • Investigate examples of extending linear transformations beyond subspaces.
Mathematics students, particularly those studying linear algebra and functional analysis, as well as educators looking to deepen their understanding of proof techniques involving Zorn's lemma.
mahler1
1. Homework Statement .
Let V be a vector space over the field R and S be a subspace of V. Now let f:S→R be a linear transformation. Prove that T can be extended to all the vector space V, i.e., there exists f':V→R such that f' restricted to S equals f.
3. The Attempt at a Solution .
In this exercise I am supposed to use Zorn's lemma to prove the existence of f'. I define a partially ordered set as follows: P={(U,T) where U is a subspace of V which contains the subspace S and T is a linear transformation T:U→R that satisfies T restricted to S equals f}. Then, I define the relation (U,T)≤(U',T') if and only if UcU' and T' restricted to U equals T. I need to verify that the relation I defined is indeed an order relation on P, but I didn't have problems with that; it's very easy to check for reflexivity, antisymmetry and transitivity.
I want to show that every totally ordered set of P has an upper bound, so let P' be a totally ordered set of P. If I choose the set X to be the union of all elements (U',T') of P', then (U',T')≤X for all (U',T') in P'. Now I can apply Zorn's lemma: P has a maximal element which I will denote M=(W,T'') where W is a subspace of V and T'' is a linear transformation, T'':W→R. By definition of maximal element, W is a subspace which includes all subspaces which contain the subspace S and T'' is a linear transformation that satisfies T'' restricted to S equals f. To complete the proof, I need to show that the domain of T'' is all the vector space V. Suppose V is not the domain of T''. So the domain W has to be a proper subspace of V. Then there is an element v in V which is not in W and Wu<v> is another subspace of V which includes W. I define h to be the linear transformation on Wu{v} as: h restricted to W equals T'' and h(v)=0. Then (W,T'')≤(Wu<v>,h). This is absurd since (W,T'') was the maximal element of P. Then V must be the domain of T'' and T'' restricted to S equals f so T'' is the linear transformation I was looking for.
Well, I know my proof is verbose, but is it correct?
You'd need to show that W\cup &lt;v&gt; is a subspace (it's not in general) and that h is linear. I reckon you're on the right track, though.
