Applying Newton's Laws: Crate on an Inclined Ramp
The discussion focuses on applying Newton's Laws to determine the forces acting on a crate of mass 96 kg on a frictionless ramp inclined at 27°. The main calculations involve finding the horizontal force F required to push the crate up the ramp at constant speed, as well as the normal force Fn acting on the crate. The correct approach involves resolving the gravitational force Fg into its components and applying the equilibrium condition for forces in both the x and y directions. The final values derived are Fx = 427.1143 N and Fy = -217.8476 N.
  • Understanding of Newton's Laws of Motion
  • Basic trigonometry for resolving forces
  • Knowledge of free body diagrams
  • Familiarity with gravitational force calculations (Fg = mg)
  • Study the application of Newton's Laws in two-dimensional motion
  • Learn about free body diagrams and their importance in physics
  • Explore trigonometric relationships in force resolution
  • Investigate the concept of normal force in inclined planes
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of force analysis on inclined planes.
coco87
In the figure, a crate of mass m = 96 kg is pushed at a constant speed up a frictionless ramp (θ = 27°) by a horizontal force F. The positive direction of an x-axis is up the ramp, and the positive direction of a y-axis is perpendicular to the ramp. (a) What is the magnitude of F? (b) What is the magnitude of the normal force on the crate?
m = 96 kg
θ = 27°
http://lcphr3ak.is-a-geek.com/figpf1.png
F = ma
Fg = mg (g=9.8)
Fnet = Fg + F
Currently I'm trying to map out the situation, but am running into an issue. Considering we are dealing with constant speed, we can assume that the acceleration is 0. First, I figured out Fg, which is (96)*(9.8), so Fg = (940.8). Using a little trig, we can derive a triangle with a hypotenuse Fg, and a base angle of 63°. This means that Fgx = (940.8)(cos 63°) = -427.1143 (negative because it lies in the third quadrant); and Fgy = (940.8)(sin 63°) = -838.2589. Ultimately (I think I am understanding this properly), Fnetx will be 0, because the acceleration is 0. So, Fnetx = Fgx + Fx, which is 0 = -427.1143 + Fx; so Fx = 427.1143. I've verified all of this is correct. However, When trying to find Fy, I'm (at least I think so) stuck with Fnety = Fgy + Fy; which is Fnety = -838.2589 + Fy. How am I suppose to figure out Fy from here?
Thanks for any help
Since the crate is not moving the direction of the y-axis, the net force in that direction is zero.
I apologize, I left out a part. The answer that is given for that part is: Fy = -217.8476. I did set Fnety to 0 and solve that way, but when I do that I get: Fy = 838.2589. So there is something I'm missing here :frown:
...and don't forget the normal force, Fn, in the y direction:wink:. That's what you need. Fy you can get with trig.
Well, Fn = mg (since there's no acceleration), so that's not hard to find. I'm assuming Fy isn't either, and I figured it was only trig, but whenever I try with trig, I can't seem to get anywhere near -217.8476
Fn does not equal mg. You are not looking correctly at all components of the forces in the y direction, which, as Rockfreak points out, must equal zero when summed. You already calculated the y component of Fg. You now need Fy (the y component of F) to solve for Fn. Note that Fn lies along the y axis.
Well, you got the answer for Fx ok, so what's the trig relationship between Fx and Fy, knowing that theta is 27 degrees?
PhanthomJay said:
Fn does not equal mg. You are not looking correctly at all components of the forces in the y direction, which, as Rockfreak points out, must equal zero when summed. You already calculated the y component of Fg. You now need Fy (the y component of F) to solve for Fn. Note that Fn lies along the y axis. Well, you got the answer for Fx ok, so what's the trig relationship between Fx and Fy, knowing that theta is 27 degrees?
Thank you for your response, it seems I did not understand the relationship between forces correctly. I've got it now :)
  • · Replies 21 ·
