Applying pressure on a body in ANSYS 15.0
To apply pressure on a specific area of a face in ANSYS 15.0, users can hover over the desired concentric area and click to select it, utilizing the highlighted rectangles to choose internal faces. If direct selection is problematic, using SPACE CLAIM direct modeler to sketch or divide the surface into smaller regions is recommended. After sketching the area, the ruler icon can be used to create and modify dimensions for accurate placement. Importing models from CATIA as STEP files may not recognize boundaries, necessitating external modeling for proper region definition. This method ensures that ANSYS can correctly identify and mesh the designated area for pressure application.
abq123
Hi,
Could anyone help me out on how to apply pressure on a portion of a face in ANSYS 15.0, as in like a concentric area within a solid body.
Thanks in advance
Not sure what this is exactly, but hover your mouse over the "concentric area" and left click. You will click the outside area of the body but, at the bottom left, there will be a bunch of rectangles. Hover mouse over each rectangle and Ansys will highlight specific internal faces. Left click on rectangle to select the internal face you want to apply pressure to.
I just had the same problem. I have to use SPACE CLAIM direct modeler to either sketch a region or you can divide an existing surface into smaller regions. Ideally, you sketch out the area you need to apply said load to, hit the "ruler" icon on the pop up menu and it creates a dimension that you can then modify to size and locate said region. Then, ANSYS will recognize the boundary and mesh it accordingly. I use CATIA for 3-D modelling and it would not recognize any such boundary after importing as a STEP file and there is no way to create this region inside of ANSYS itself. Hope this helps?
My idea is that I want to use immerse Whitetail Antlers in a fishtank to measure their volumetric displacement (the Boone and Crockett system is the current record measurement standard to place in a juxtaposition with) I would use some sight glass plumbed into the side of the tank to get the change in height so that I can multiply by the tank cross-section. Simple Idea. But... Is there a simple mechanical way to amplify the height in the sight glass to increase measurement precision...
16K
  • · Replies 19 ·
16K
