Approaching vehicles with acceleration
5 replies · 2K views
JohnnyGui
Two vehicles, A and B, are approaching each other. Vehicle A has a constant velocity of ##v_A##. Vehicle B has a constant acceleration ##a## with an initial velocity of ##v_B##. The starting distance at ##t=0## between them is ##D##.
Is there a way to solve at what time ##t## they'd meet?
##D = v_At + v_Bt + \frac{1}{2} \cdot a \cdot t^2##
I deduced the equation above but I can't find a way to solve for t. Simplifying gives:
##\frac{D}{t} = v_A + v_B + \frac{1}{2} \cdot a \cdot t##
Is there a way to solve for t without plotting these two equations?
It is just a quadratic equation in ##t##, so is easily solved using the standard quadratic-solution formulas.
PeroK said:
Your equation looks very like a quadratic in ttt to me!
Ray Vickson said:
It is just a quadratic equation in ttt, so is easily solved using the standard quadratic-solution formulas.
Ah, for some reason I thought this wasn't possible because there are two parameters with either a ##t## or a ##\frac{1}{t}## in it. But after looking at it I noticed it could be written as:
##\frac{1}{2} \cdot at^2 + (v_A + v_B)t - D = 0##
And then use the abc-formula in which ##a=\frac{1}{2}\cdot a## and ##b=(v_A + v_B)## and ##c = D##. Is this correct?
You already had the quadratic in section 2 of your original post.
I guess you mean ##c = -D##?
You may like to think what difference it makes if vehicle A is at rest and vehicle B is initially moving at the combined speed ##v_a + v_b##.
Apologies, I did mean ##c = -D##. I take it you mean that I could just put the equation in section 2 in parentheses? My initial target was to use the abc-formula to only give the positive solution of ##t##.
