Approximate Location On Number Line
4 replies · 3K views · last reply
mathdad
Show the approximate location of the irrational number
[(3 - sqrt{5})/2]^(1/2) on a number line without a calculator. Then use a calculator to confirm your approximation.
I can find the approximate location using a calculator. How is this done without a calculator?
We could start by writing:
$$x=\sqrt{\frac{5-\sqrt{3}}{2}}$$
We know we will only be interested in positive values.
Square:
$$x^2=\frac{5-\sqrt{3}}{2}$$
$$2x^2=5-\sqrt{3}$$
$$5-2x^2=\sqrt{3}$$
This tells us we are interested in the smaller of any positive roots, when we square again:
$$25-20x^2+4x^4=3$$
Standard form:
$$f(x)=2x^4-10x^2+11=0$$
We find:
$$f(1)=3$$
$$f(2)=3$$
We should suspect that there are two roots between 1 and 2, and let's cut in between and see if we get a negative value...
$$f\left(\frac{3}{2}\right)=-11/8$$
Yes, it's negative, so the root we want must be in between.
So, we know:
$$1<x<\frac{3}{2}$$
$$f\left(\frac{5}{4}\right)=33/128$$
Now we know:
$$\frac{5}{4}<x<\frac{3}{2}$$
$$f\left(\frac{13}{10}\right)=-\frac{939}{5000}$$
Thus:
$$\frac{5}{4}<x<\frac{13}{10}$$
We could continue to get whatever desired accuracy we want, but at this point we know $1.25<x<1.3$, which is a reasonable approximation. :D
Note that $\sqrt{\frac{3-\sqrt5}{2}}=\left|\frac{1-\sqrt5}{2}\right|$
Yeah, I messed up the value we want by interchanging the 3 and the 5...I hate when that happens. :D
That would simply things greatly. (Yes)
$$x=\sqrt{\frac{3-\sqrt5}{2}}=\sqrt{\frac{6-2\sqrt5}{4}}=\frac{\sqrt{1-2\sqrt{5}+5}}{2}=\frac{\sqrt{(\sqrt{5}-1)^2}}{2}=\frac{\sqrt{5}-1}{2}$$
$$2<\sqrt{5}<3$$
$$1<\sqrt{5}-1<2$$
$$\frac{1}{2}<\frac{\sqrt{5}-1}{2}<1$$
Begin with a narrower interval containing $\sqrt{5}$, and you'll end up with a better approximation for the requested value. :D
Square:
$$2x^2=5-\sqrt{3}$$
$$5-2x^2=\sqrt{3}$$
$$25-20x^2+4x^4=3$$
Standard form:
We find:
$$f(1)=3$$
$$f(2)=3$$
So, we know:
$$1<x<\frac{3}{2}$$
Now we know:
Thus:
What a great reply! You are great!
- - - Updated - - -
$$2<\sqrt{5}<3$$
$$1<\sqrt{5}-1<2$$
Another great reply. You are awesome!
