Approximation to the binomial distrubution
The discussion confirms that the normal approximation to the binomial distribution is appropriate since np equals 25, which is greater than 5. The mean of the distribution is calculated as np, resulting in a mean of 25. The standard deviation requires the value of q, which is determined to be 1 - p, equating to 1/2 in this case. To find the standard deviation, it is necessary to use the formula npq and square the result. The key takeaway is that both the mean and standard deviation can be calculated using the parameters provided.
Biochemgirl2002
Consider a binomial random variable with n = 50
trials and p = 1/2.
(A)Is it appropriate to use the normal
approximation to the binomial distribution? If so,
what mean and standard deviation we should we
use when standardizing?
X~N(mean, std dev^2)
X~N(np,npq) if np>5 and npq>5
a) since np has to be greater than 5,
n*p= 50*.5
=25
so yes, we can use this since it is much larger than 5.
now, for mean, i believe the equation is saying that the mean is np, which is 25
but in this equation we do not have a q value, so this is where my issue begins...
what should i use for my standard deviation?
do i square it once i find out what q is ?
rhiana said:
Homework Statement: Consider a binomial random variable with n = 50
trials and p = 1/2.
Homework Equations: X~N(mean, std dev^2)
n*p= 50*.5
=25
q is 1 - p, so for this situation, q = 1/2.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 0 ·
