Approximation Using Taylor POlynomial
To approximate e^-0.1 with an error less than 10^-3, the Taylor series for e^x is utilized, where x is replaced with -0.1. The series expansion is given by e^x = Σ(x^n/n!), starting from n=0. A Taylor polynomial is needed for the approximation, along with a remainder estimate to ensure the desired accuracy. The discussion emphasizes the importance of using the Taylor polynomial method rather than just the series for precise calculations. This approach effectively provides a means to achieve the required approximation.
e179285
Find an approximate value of the number e-0.1 with an error less than 10-3
ı know that ex = Ʃ(from zero to ınfinity) xn / n!=1+x/1!+x
/2!+...
ı don't know how to use e-0.1 in this question.Do ı write -0.1 instead of x in ex series?
/2!+...
yup! :biggrin:
Since you are asked to calculate to within a particular accuracy, what you need is not the Taylor series, but a Taylor polynomial plus remainder estimate.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
