Arc length and straight lines(Need clarification please)
30 replies · 6K views
Cauchy1789
Here is difficult one guys,
Lets imagine that an object movement along a curve is described by the parameterized function called
[tex]\omega: I \rightarrow \mathbb{R}^3[/tex] which moves on the interval [tex][a,b]\subset I[/tex]. and this depended on motor which supplies the constant effect of |v| = 1.
With this in mind show that
[tex](\omega(b) - \omega(a)) \cdot v = \int_{a}^{b} \omega(t)' \cdot v dt \leq \int_{a}^{b} |\omega(t)'| dt[/tex]
From what I learned in Calculus is relatively easy to show that according to the fundametal theorem of Calculus which states that [tex]\int_{a}^{b} f(x) dx = F(b) - F(a)[/tex] where F is the anti-derivate of f.
such that [tex](\omega(b) - \omega(a)) = \int_{a}^{b} \omega'(t) dt[/tex] where [tex]\omega(t)[/tex] is the anti-derivative, and since the movement depends of the constant, then both on side are the same aren't they?
If I expand the inequaliy then [tex]v \cdot(\omega(b) - \omega(a)) \leq |\omega(b) - \omega(a)|[/tex] which is only true if [tex]|v| \leq 1[/tex]
Haven't I covered what needs to be covered in this?
Sincerely
Cauchy
Careful, just because [itex]||\vec{v}||[/itex] is a constant, doesn't mean that [itex]\vec{v}[/itex] is constant --- It can still point in different directions at different points along the curve. (I'm using \vec to make it clear which quantities are vectors!)
Hint (1): Use the product rule for [tex]\left(\vec{\omega}(t)\cdot\vec{v}(t))'[/tex]
Hint (2): [tex]\vec{A} \cdot \vec{B}=||\vec{A}||*||\vec{B}||\cos\theta[/tex] , where [itex]\theta[/itex] is thew angle between the vectors.
Hi gab and thank you for your answer,
Then using hint(1) and hint (2)
[tex]\omega(t) \cdot v(t)' + \omega(t)' \cdot v(t) = \omega'(t) \cdot v(t) \leq |\omega'(t)|[/tex]
Is this what you mean?
Sincerely
Cauchy
Sincerely
Cauchy
Careful, you need to justify why [tex]\vec{\omega}(t)\cdot\vec{v}(t)'=0[/tex]...Hint: is [tex]\vec{v}(t)'[/tex] (a)tangent to the curve? (b)normal to the curve (c) some combination of the above?
if [tex]\omega(t) \cdot v(t) = 0[/tex] then v(t) is perpendicular to the omega function? and thus the normal vector. Isn't it?
where [tex]v(t) \cdot(\omega(b)-\omega(a)) = 0[/tex]
this is what you mean?
Sincerely
Cauchy
You are missing the primes in this expression and you have the if statement backwards...you should have that:
If [tex]\vec{v}(t)'[/tex] is perpendicular to [tex]\vec{\omega}(t)[/tex] then [tex]\vec{\omega}(t) \cdot \vec{v}(t)' = 0[/tex]
But why is [tex]\vec{v}(t)'[/tex] is perpendicular to [tex]\vec{\omega}(t)[/tex] in this case?
P.S. You really need to make it clear which quantities are vectors and which are scalars; your original post was very confusing.
Hi again,
That can only be because v'(t) its the normal for the omega function?
So if I have understood this correctly then v'(t) is the normal vector for the omega function. Then reversed [tex]\omega(t)'[/tex] is the normal vector for [tex]v(t)[/tex] ? Because v is constant?
Sincerely
Cauchy
Cauchy1789 said:
Hi again,
No. [tex]\vec{v}(t)[/tex] represents the velocity of the object correct?...So [tex]\vec{v}(t)'[/tex] represents___?
the speed.
oh then the right hand side of the equality sign is the function which defines the speed and the left hand the verlocity??
Sincerely Cauchy
gabbagabbahey said:
The time derivative of velocity is not the speed. I think you need to reread the chapter on vector calculus in your textbook.
The time derivative is [tex]\frac{d\omega}{dt} = \omega(t)'[/tex] isn't it?
Sincerely
Cauchy
Sincerely
Cauchy
That's the time derivative of omega...what's the time derivative of [tex]\vec{v}(t)[/tex]?
That must be [tex]\frac{dv}{dt} = v'(t)[/tex]
The first part of the original eqn:
[tex](\omega(b) - \omega(a)) \cdot v(t) = \omega(b) \cdot v(t) - \omega(a) \cdot v(t)[/tex]
But what I don't get here is that this then according should equal [tex]= \int_{a}^{b}( \omega(t) \cdot v(t))' dt = \omega(b) \cdot v(t) - \omega(a) \cdot v(t) = v(t) \cdot (\omega(b) - \omega(a))[/tex]
because omega(t) is the anti-derivative of omega(t)'.
Isn't this pretty much it for equality part?
Next I end up with [tex](\omega(b) - \omega(a)) \cdot v(t) = \omega(b) \cdot v(t) - \omega(a) \cdot v(t) = \int_{a}^{b}( \omega(t) \cdot v(t))' dt = \omega(b) \cdot v(t) - \omega(a) \cdot v(t) = v(t) \cdot (\omega(b) - \omega(a)) \leq |\omega(b) - \omega(a)|[/tex]
But then this must mean that the left hand side of the inequlity is depending on the verlocity vector while the right hand is not? Or in which direction should I go here?
Sincerely
Cauchy
Sure, but what quantity does this represent? Position? Velocity? Acceleration? Speed? The number of Newfies it takes to screw in a light bulb?
Hold on, doesn't the fundamental theorem of calculus tell you that
[tex]\int_{a}^{b}( \vec{\omega}(t) \cdot \vec{v}(t))' dt = \vec{\omega}(b) \cdot \vec{v}(b) - \vec{\omega}(a) \cdot \vec{v}(a)[/tex]
Something is clearly missing/unclear in your original post...For [itex]\vec{\omega}(b) \cdot \vec{v}(b) - \vec{\omega}(a) \cdot \vec{v}(a)[/itex] to be equal to [itex]\left(\vec{\omega}(b)- \vec{\omega}(a)\right) \cdot \vec{v}(t)[/itex], [itex]\vec{v}(t)[/itex] would have to be constant...but that wasn't what I inferred from your OP.
Are you told that [itex]\vec{v}(t)[/itex] is a constant or that [itex]\vec{v}(a)=\vec{v}(b)[/itex], or are you actually asked to show that
[tex]\vec{\omega}(b) \cdot \vec{v}(b) - \vec{\omega}(a) \cdot \vec{v}(a)=\int_{a}^{b}\vec{\omega}(t)' \cdot \vec{v}(t) dt \leq \int_a^b|\vec{\omega}(t)|dt[/tex]
Your original post is very unclear...
Hi again,
I am very sorry if my op has been unclear.
I am told to show the later.
I will repost it again now.
Let [tex]\omega: I \rightarrow \mathbb{R}^3[/tex] be a parameterized curve. Let [tex][a,b]\subset I[/tex] and set [tex]\omega(b) = s[/tex] and [tex]\omega(a) = t[/tex].
1) Show that, for any constant vector v, |v| = 1,
[tex](t-s) \cdot v(t)= \int_{a}^{b} \omega(t)' \cdot v(t) dt \leq \int_{a}^{b}|\omega(t)'| dt[/tex]
2) Set [tex]v = \frac{t-s}{|t-s|}[/tex]
and show [tex]|\omega(b) - \omega(a)| \leq \int_{a}^{b} |\omega(t)'|dt[/tex]
that is that the shortest length between omega(a) and omega(b) is a straight line.
Solution part(1)
[tex](s-t) \cdot v(t) = \int_{a}^{b} \omega'(t) \cdot v(t) \ dt[/tex]
Because by the fundamental theorem of Calculus.
[tex]\int_{a}^{b} \omega'(t) \cdot v(t) \ dt = \int_{a}^{b} (\omega(t) \cdot v(t))' dt = \omega(b) \cdot v(b) - \omega(a) \cdot v(a)[/tex] and since as |v| = 1 is constant vector v, then the lefthand side and the righthand side of the equality equal each other.
But does that apply for the inequality as well? Thats what I am not sure of.
Sincerely
Cauchy
Okay...a constant [tex]\vec{v}(t)[/tex] makes much more sense! :smile:That means that [tex]\vec{v}(t)'=0[/tex] and hence
[tex]\left(\vec{\omega}(t)\cdot\vec{v}(t)\right)'= \vec{\omega}(t)'\cdot\vec{v}(t)+\vec{\omega}(t)\cdot\vec{v}(t)'=\vec{\omega}(t)'\cdot\vec{v}(t)+\vec{\omega}(t)\cdot(0)=\vec{\omega}(t)'\cdot\vec{v}(t)[/tex]
Now for the inequality part just use the fact that [tex]\vec{A} \cdot \vec{B}=||\vec{A}||*||\vec{B}||\cos\theta[/tex]
[tex]\implies \vec{\omega}(t)'\cdot\vec{v}(t)=\left(||\vec{\omega}(t)'||*||\vec{v}(t)\right)||\cos\theta=||\vec{\omega}(t)'||*(1)\cos\theta=||\vec{\omega}(t)'||\cos\theta[/tex]
theta is the angle between omega'(t) and v, which is always between 0 and pi right? what does that make the min and max values of cos(theta)?
hi again and thanks for taking time :)
cos has max in cos(0) = 1 and min in cos(pi) = -1.
and this basically proves that the inequality is true?
Sincerely Cauchy
Opps...the max angle between two vector is pi/2 not pi, so cos\theta has min of 0 and max of 1 ...therefor
[tex]\cos\theta\leq1[/tex]
So, [itex]||\vec{\omega}(t)'||\cos \theta\leq[/itex] ____?
That must be then
[itex]||\vec{\omega}(t)'||\cos \theta\leq ||\vec{\omega}(t)'||[/itex]
please excuse me if I am misunderstanding you but cos(theta) <= 1 shows then that inequality is true if the vector v is constant?
Cauchy
Cauchy1789 said:
That must be then
Right, so [itex]\vec{\omega}(t)'\cdot\vec{v}(t)\leq[/itex]___?
Hi
That must be [itex]\vec{\omega}(t)'\cdot\vec{v}(t)\leq \|\vec{w(t)'}\|[/itex] ?
Cauchy
Cauchy1789 said:
Hi
Cauchy
Well, in post #16 I showed [itex]\vec{\omega}(t)'\cdot\vec{v}(t)=||\vec{\omega}(t)'||\cos\theta[/itex]
And in post #19 You showed that [itex]||\vec{\omega}(t)'||\cos \theta\leq ||\vec{\omega}(t)'||[/itex]
So yes, when you put those two relations together you get [itex]\vec{\omega}(t)'\cdot\vec{v}(t)\leq||\vec{\omega}(t)'||[/itex]
So, now what can you say about [tex]\int_a^b \vec{\omega}(t)'\cdot\vec{v}(t)dt[/tex] ?
Thats its
that [tex]\vec{\omega}(b)\cdot\vec{v}(b) - \vec{\omega}(a)\cdot\vec{v}(a)[/tex] ?
Cauchy
No.
If [itex]\vec{\omega}(t)'\cdot\vec{v}(t)\leq||\vec{\omega}(t)'||[/itex], then [itex]\int_a^b \vec{\omega}(t)'\cdot\vec{v}(t)dt\leq[/itex]___?
gabbagabbahey said:
No.
Then thinking about it it must be:
[itex]\int_a^b \vec{\omega}(t)'\cdot\vec{v}(t)dt \leq \int_a^b ||\vec{\omega}(t)'|| dt[/itex]??
Sincerely Cauchy
Sincerely Cauchy
Yes, exactly!:smile:
And that's exactly what you were trying to show isn't it?
I surely is.
So just to recap then proving part(1) I partion the equation into vector equtions, and then use the fact about th constant vector.
Thank You.
I hope I don't sound completely stupid, been away from the studies for 6 month do a irregular heartrytm, but that a longer story. I can see that I need to re-read some stuff.
Anyway part(2) Do You have an idear howto get started here?
From I can figure that v is presented a united vector composed by the components of omega. What need to show here is that the dot-product between omega prime and the distance from omega(b) to omega(a) is less or equal to each other??
Sincerely
Cauchy
Cauchy1789 said:
2) Set [tex]\vec{v} = \frac{\vec{t}-\vec{s}}{|\vec{t}-\vec{s}|}[/tex]
and show [tex]|\vec{\omega(b)}-\vec{\omega(a)}| \leq \int_{a}^{b} ||\vec{\omega}(t)'||dt[/tex]
I've added vector arrows to this to make it more clear...do exactly what they tell you to.
Set [tex]\vec{v} = \frac{\vec{t}-\vec{s}}{|\vec{t}-\vec{s}|}[/tex] and plug it into your result from (1)
Hi again You mean
[itex]\frac{\vec{t}-\vec{s}}{|\vec{t}-\vec{s}|} \cdot (t-s)= \int_a^b \vec{\omega}(t)'\cdot \frac{\vec{t}-\vec{s}}{|\vec{t}-\vec{s}|} dt \leq \int_a^b ||\vec{\omega}(t)'|| dt[/itex]??
and then just expand??
Cauchy
Cauchy1789 said:
Hi again You mean
Cauchy
Sure, but all you really need is
[tex]\frac{\vec{t}-\vec{s}}{|\vec{t}-\vec{s}|} \cdot (\vec{t}-\vec{s}) \leq \int_a^b ||\vec{\omega}(t)'|| dt[/tex]
