Archimedes Principle - Mass floating on ice
4 replies · 4K views · last reply
Mike Dacre
Question: What minimum volume must a slab of ice in a freshwater lake have for a 50.0kg woman to be able to stand on it without getting her feet wet?
Archimedes principle.
[PLAIN]https://lh6.googleusercontent.com/qRkIpr7Mg9TFQYXwa2Xoj5jv3vcBNP7hPUxT5Xk1inIv-Qdk_KhZWF-Pha5AJ_Aq9_e7ZQPUGeUrMdRCb7vTUgQKtYY4sGutyIYtGiLW6bspSIuL6-sdiCDjIHaN7viYGQ
[PLAIN]https://lh5.googleusercontent.com/csDszB-wBCqIGI4g9bRCmLfDFgEbQcXTKjieRXO3BVOUmGCYJoq7CdCpd844FOemjb_MrhnaHitt0Dk0mBssD6-QSdQ2S51f3WpZ6tyamq5xrxfjmc64gZNMTqNR0NGq7g
https://lh6.googleusercontent.com/kH5QjwyHmXZcrpHD2JM1sggbdDI43yXiUxr7e17NopEUM4dRfYHKsU19hO6lTbb9Pui_TCMytxYtHLXHTK_8Wj_EegNUFy3263FZEDVXh-h7eQMoWycZ0S09_kYp5Mhnig
https://lh5.googleusercontent.com/sDINzVNO1G2GzJlJnTrYY80Q1E9a9crTVdNyR1hm0jX8ru3R4WB7sWrZDla_CVpij173_N1r6yI-gaFr7DnQqwABqi1r-AeN9FotFK11RrRbhivhHm9GUqeTqZC79P_I_g
https://lh4.googleusercontent.com/_x3gT0FzL5kRBHNLUVXT24OZAh_9KJZAmBfRqQuYbxUMl92CvDL9Pkx7or1qoCZHyl8bz-4PdUA5Zc0PC61I1siMKjuDGoqgQtApYxSfyfiJO28kzZv8wDaMytKlKuz_IA
https://lh4.googleusercontent.com/joYLqXziuC1oujBIhA6YwQF6y8R8YIWBo10XaC8kaFNKSnFq44Bwh4hpQYUIZCAeFrMz-IZY5r_KYrLYSejPhz-_urptxyIWSiEIo4qRhbjOFm8SBc3Ui4WazZO_AtAAtQ
https://lh3.googleusercontent.com/19SQ3f8VkxjzitZKKnrCuilqBRVW4NsYhopELqqT2BRcxhcBwstvHpXf8ME0Fbg58_7pshIuW51QFxzPRwUH5xCLBWEeel1X-Xn-bG86FZIm3zq0RwhOXHgHzEZWgtAtJg
https://lh6.googleusercontent.com/xiV61mYNtopcHzoTYWVaiLDUnuWlUOwlnuxAa9JGvK5zJt9brfkrL4FKCPzR4b8a4R5Ta54dk3vbDFRM6jggqErfnkKbDxBIlRfa0R4T9IOnpdv5AHYJPGrWT5cwwo6oNg
My answer: 0.601 m^3. masteringphysics.com answer: 0.625 m3
What am I getting wrong? I am so sure I am right, am I missing something really obvious?
Where did you get the values for the density of water and ice? Did masteringphysics.com use the same values?
Those are from wikipedia and pubchem, masteringphysics.com didn't provide any values to use with the question. I tried with a number of different values including 1000 kg/m3 for water and 917 kg/m3 for ice, which comes to 0.602 instead of 0.601... still a good deal less the 0.625.
On the net I see two values commonly, 917 and 931. At a guess, the latter corresponds to a pure crystalline form, Ih, while the former is for naturally occurring ice. But I could be wrong.
To get the given answer you need 920, very close to 917. The key point is that the difference in the densities is a small difference between two large numbers, so a small error in one of the numbers leads to a relatively large error in the result.
Ah you are right. Well, at least the problem wasn't with the method, I can accept a silly mistake like that.
It is just interesting that they chose the density of ice at - 10 ºC, rather than at 0 ºC or at -180 ºC, which is the other commonly cited density.
Thanks for the help
