Calculating Buoyancy: Solving for the Height of a Boat in Salt Water
The discussion revolves around calculating the height a boat will float in salt water compared to fresh water. A small boat weighing 1000 N displaces different volumes of water in each scenario, with fresh water requiring 0.102 m³ and salt water 0.0991 m³ for buoyancy. The difference in displaced volume is 0.0029 m³, which is critical for determining how much higher the boat will float in salt water. Participants express confusion over how to relate the volume difference to the boat's height above the waterline, particularly given its surface area of 3 m². The conversation emphasizes the importance of understanding the relationship between volume, surface area, and buoyancy in different water densities.
BrainMan
A small boat weighing 1000 N has a surface area of 3 m^2. It floats only 5 cm above the water level when in a fresh-water lake. How high out of the water will it ride in a salt-water lake? Assume the surface area of the boat does not change as it rises (salt water has a density of about 1.03 x 10^3 kg/m^3).
B = pVg
I can use the above equation to solve for the volume of the water displaced which will be the same as the volume of the boat. Unfortunately I am not sure were to go from there. I am not sure how to find the relationship between the height the boat rises in the water and it's volume. I also am not sure what to do with the information it gave me on the boats surface area.
The "surface area" of the boat should be understood as the area enclosed by the boat's outline at the water line. If this area is 3 m^2 and the boat rises by 5 cm, by how much will the submerged volume of the boat be reduced?
I'm sure it would be much clearer if they'd said the boat is in the shape of an upright rectangular box!
Likes BrainMan and jbriggs444
So it's not the surface area of the entire boat just the part of the boat under the water?
What is the displaced volume of salt water required to support the weight of the boat? What is the displaced volume of fresh water required to support the weight of the boat? What is the difference in displaced volume between salt water and fresh water?
Chet
Chet
Volume of water displaced for fresh water = .102 m^3
volume of water displaced for salt water = .0991 m^3
difference in water displaced = .0029 m^3
If the boat cross sectional area at the water line is 3 m^2, for the volume difference you calculated, how much higher will the boat float in salt water?
Chet
Chet
I'm not sure that's the part I'm having trouble with
But it's the only step you have left to do.
Likes Chestermiller
  • · Replies 19 ·
