Archimedes Principle: Calculating Relative Density for a Block of Oak and Lead
The discussion centers on calculating the relative density of a block of oak and a piece of lead using Archimedes' Principle. The oak weighs 90 N in air and the lead weighs 130 N in water, with a combined weight of 100 N in water. The calculations reveal that the relative density of the oak is 1.499, but the correct relative density is 0.75, indicating a sign error in the calculations. The negative force interpretation is clarified, emphasizing the importance of understanding buoyancy and net forces in fluid mechanics.
  • Understanding of Archimedes' Principle
  • Basic knowledge of weight and buoyancy
  • Familiarity with the formula F=mg
  • Ability to manipulate equations involving density and volume
  • Study the concept of buoyant force in fluids
  • Learn about the calculation of density using the formula density = mass/volume
  • Explore the implications of negative forces in physics
  • Investigate the principles of floating and sinking in different fluids
Students studying physics, particularly those focusing on fluid mechanics and density calculations, as well as educators seeking to clarify concepts related to buoyancy and Archimedes' Principle.
Nanu Nana
. Homework Statement
A block oak weighs 90 N in air. A piece of lead weighs 130 N in water. The two weigh together 100N in water. Calculate the relative density of the wood.
F=mxg
F(archimedes)= density x Volume x g
F (g)oak = 90 N
F= mxg
m= 90N/9.81 m/s2
m= 9.17 gram
Oak in water = 130-100 N =30 N
Farchimedes oak = 90N-30N =60N
60N =1000kg/m3 x V x 9.81 m/s2
V=60N/9810
V=0.00611
Now that I have calculated V I can find density
rho = 9.17kg/ 0.00611 m3
density = 1499
Relative density is 1499 /1000 kg/m3 = 1.499
But the correct answer is 0.75
Check your signs. In water, oak+lead=100N, while lead =130N.
How to do find N Force of oak in water ??
Your method was ok but you made a mistake with the signs. Manipulate the two equations I wrote above.
100+130?
Nanu Nana said:
100+130?
Please, don't make wild guesses.
If Ow+Lw=100 and Lw=130, what is Ow?
Sorry /D its -30 so 90-(-30) = 120
Right. Does this get you to the right answer?
(How do you interpret the weight of -30N?)
Yes I just calculated it. Negative force means opposite direction . But i don't know in this context
If the wood were immersed in the water without being bound to the lead, what would happen?
It floats ofcourse
Nanu Nana said:
It floats ofcourse
Right, hence the negative net force.
Oh I see . thank you very much :)
11K
