Are All Eigenvalues of a Matrix Between Defined Limits?
14 replies · 5K views · last reply
angelz429
[SOLVED] Positive Definite Matrices
a) If A is Symmetric show that A-λI is positive definite if and only if all eigenvalues of A are >λ, and A-λI is negative definite if and only if all eigenvalues of A are <λ.
b) Use this result to show that all the eigenvalues of
[ 5 2 -1 0]
[ 2 5 0 1]
[-1 0 5 -2]
[ 0 1 -2 5]
are between zero and eight.
If all eigenvalues of A>0, A is positive definite.
i'm not sure where to start
here's a hint: since A is symmetric, you can get a set of eigenvectors of A which are an orthonormal basis for the vector space.
hmm... i understand what you are saying, but I'm not sure how to apply it. My main problem is with proving part a.
to show that a matrix M is positive definite, it is sufficient to show that v^T M v > 0 for any vector v in an orthonormal basis. since you can get such a basis with eigenvectors of A, you just need to show that for any eigenvector v of A, v^T (A-λI) v > 0. remember that you know how A acts on eigenvectors.
How would you find the eigenvalues of A-lambda*I? How would you find the eigenvalues of A for that matter?
like any other eigenvalue i suppose do det((A-lambda*I)-alpha*I)=0 and solve for alpha.
Right. So when you do that alpha is an eigenvalue of A-lambda*I. Do you see that makes (lambda+alpha) an eigenvalue of A? So what's the relation between the eigenvalues of A and those of A-lambda*I?
ok, so det(A-lambda*I-alpha*I) implies det (A-alpha*lamba*I) therefore alpha is an eigenvlaue od A-lambda*I and alpha*lambda is an eigenvalue of A.
But what does this say about the relationship between alpha and lambda? I'm supposed to see that if alpha > lambda A is positive definite & is alpha < lambda A is negative definite.
If alpha > lambda, alpha*lambda > lambda
If alpha < lambda, alpha*lambda can be < lambda
That's all I can see. How does this show that all alpha*lambda> 0 or alpha*lambda<0?
det(A-lambda*I-alpha*I)=det(A-(lambda+alpha)*I). '+', not '*'! If alpha+lambda is an eigenvalue of A when alpha is an eigenvalue A-lambda*I, I would say that the eigenvalues of A-lambda*I are obtained by subtracting lambda from the eigenvalues of A. Wouldn't you agree??
oh riiiight! Thanks!... but how can we guarantee that alpha + lambda is > 0?
angelz429 said:
errr i mean that alpha - lambda is > 0
You'd better put some conditions on the eigenvalues of A. Look at what you are trying to prove.
Alright, so I understand the first part... now how do I use this to show that all the eigenvalues of B are between zero & eight? I just checked that B is positive definite...
