Are generators efficient when powering only one small appliance?
Generators are more fuel-efficient when powering a single small appliance, like a 100W bulb, compared to multiple appliances. They operate at a constant voltage, with the circuit's resistance determining the amperage needed. The generator's engine is designed to run at a steady RPM, typically 3600, and a governor adjusts fuel supply to maintain this speed when the load changes. While the fuel consumption decreases with fewer appliances, it does not drop proportionately; efficiency is highest near maximum output. Excess energy is primarily dissipated as heat, highlighting the inherent inefficiency of internal combustion engines.
rohit1987
i am asking about the generators we use in house when there is a power failure(now a days people use inverters)
here goes the question
suppose the generator is running (max ouput is 1kw) but we are using a electric bulb(100w)
is it running in its max potential or using less fuel compared to when it is used tp light 10 100w bulbs
if yes
how does it know how much energy output is required
if no
how is the excessive energy dissipated it is too much energy to be be dissipated by sound and heat (then generators are very inefficient)
awaiting answer
Rohit Kumar Patra
Welcome to PF.
It will use less fuel if only one light bulb is attached to it than if 10 are. It doesn't need to "know" anything - the generator runs at constant voltage and the resistance on the circuit determines the amperage. The amperage and voltage together determine the torque required to spin the generator and thus the fuel input required.
That said, a generator is sized and matched with the engine that drives it. It is at its most efficient near its maximum output. As such, it won't use 1/10th the fuel with 1light bulb as with 10 - perhaps it only uses 1/5th the fuel. The extra energy is dissipated as heat: at best, about 2/3 of the energy of an internal combustion engine is dissipated at heat (at worst, all of it is).
can you explain the following part to me
"the generator runs at constant voltage "
thanking you
Rohit
Sorry, I'm not quite sure what there is to explain about that statement. Could you be more specific about what you don't understand about that?
thanking you
Rohit
Generator voltage is based on RPM, most gas driven generators are designed to be driven at a steady speed of 3600 RPM.
If no power is being drawn from the generator the speed will be steady and you can tell by the sound of the gas engine what is going on, if one bulb is turned on you can hear a slight momentary drop in speed, a governor senses this drop and automatically increases fuel supply to bring the engine back to the proper speed, as more bulbs are turned on this process repeats.
If the load imposed on the generator is large enough, the gas engine can be stalled completely .
thank you
that's what i exactly wanted to know
rohit
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
