Are my calculations right? Also, not sure about a formula?
This discussion focuses on solving two projectile motion problems involving a ball thrown horizontally from a building. In Problem #1, the ball is thrown from a height of 56 meters and lands 45 meters away, requiring the calculation of initial speed. The correct approach involves using the equation for horizontal motion and the relationship between vertical displacement and time. In Problem #2, the ball is thrown horizontally at 22.2 m/s and lands 36 meters away, leading to the calculation of the building's height, which is determined to be approximately 12.544 meters using kinematic equations.
  • Understanding of projectile motion principles
  • Familiarity with kinematic equations
  • Knowledge of horizontal and vertical velocity components
  • Basic grasp of trigonometric functions related to angles
  • Study the kinematic equations for projectile motion in two dimensions
  • Learn how to decompose velocity into horizontal and vertical components
  • Explore the concept of gravitational acceleration and its effects on motion
  • Practice solving similar projectile motion problems with varying initial conditions
Students studying physics, particularly those focusing on mechanics and projectile motion, as well as educators seeking to clarify concepts related to horizontal projectile motion.
kLPantera
Problem #1
A ball is thrown horizontally from the roof of a building 56m tall and lands 45m from the base. What was the ball's initial speed.
Problem #2
A ball thrown horizontally at 22.2m/s from the roof of a building lands 36.0 meters from the base of the building. How high is the building?
Problem #1
Not sure which equation(s) I need to use. I know I have to find initial speed, but I think I have to find time to find initial speed. So I'm unsure as to how to find time, because time keeps giving me some trouble.
Problem #2
x=Vot + (1/2)at2
y=Vot + (1/2)gt2
Problem #1
Don't know which equation(s) to use so, no attempt.
Problem #2 (Could someone please confirm my calculations for this one?)
Delta x = 36
Delta y = ?
Vo = 22
ax = 0
ay = -9.8m/s2
t = ?
x = Vot+ (1/2)at2
36 = 22t
t = 1.6 seconds
y = Vot + (1/2)at2
y = (22)(1.6) + (1/2)(-9.8)(1.6)2
y = 35.2 - 12.544
y = 22.656
Thanks
Problem #1:
As far as I can tell the question is related to projectile motion in 2 dimensions while your equations will only work for 1 dimension motion and because I'm new to physics as well I'll do my best to help you out.
A simple equation I found for initial velocity is: Square root (g/2 delta y) * delta x
In which g= gravity, 2 delta y= delta y * 2And Problem #2
Simple Equation for delta y is (1/2)g * delta t squared
And to find delta t it is delta x/initial velocity*cos angle
And angle is 0
I don't know if my calculation for time is right though.
Problem #2:
Your answer is incorrect, although your technique is fine.
The question states that the ball is thrown horizontally at a speed of 22 m/s.
Therefore, the initial horizontal velocity is 22 m/s.
What is the initial vertical velocity? (Hint, it's NOT 22 m/s).
Problem #2
Is the time I calculated wrong too? Or is it just the second part of my calculations that is wrong?
So to find Viy I should do:
Vix = Vo cos(theta)?
The calculated time is correct.
No...
To find Viy, you use Viy = Vo sin(theta).
Vix = Vo cos(theta) is obviously used to find Vix.
Vo = 22 m/s as well?
I would have to calculate theta too wouldn't I?
I tried an equation:
Vfy = Viy+ayt
0 = Viy + (-9.8)(1.6)
Viy = 15.68 m/s
Delta y = Viyt + (1/2)gt2
Delta y = (15.68)(1.6) + (1/2)(-9.8)(1.6)2
Delta y = 25.088 - 12.544
Delta y = 12.544 meters
(The answer some other people in my class calculated was 12.8 meters)
Is this correct?
Is this correct?
Your answer is correct, but your technique is still wrong...
kLPantera said:
Vfy = Viy+ayt
This says that after falling some distance, the velocity of the ball is Viy = 0 m/s.
This is not likely, since we know that the acceleration of gravity is 9.8 m/s/s.
The ball can only gain speed.
Yes, but it's given to you...
"A ball is thrown horizontally..."
Oh right how did I miss that...
So since it's thrown horizontally, theta = 0 right?
So then Viy = 0
Then use the equation:
Delta y = (0)(1.6) + (1/2)(-9.8)(1.6)2
Delta y = -12.544
However since it's a building, the answer would be +12.544 right?
Also I tried Problem #1 some more could you point me in a direction?
I did
Theta = tan-1(-56/45) = -51.215 degrees
Vfy2 = Viy2 + 2ay Delta y
0 = Viy2 +2(-9.8)(56)
Viy2 = 1097.6
Viy = 33.13
Viy = Vosin(theta)
33.13 = Vosin(-51.215)
Vo = 33.13/sin(-51.215)
Vo = -25.8249
So then Viy = 0
Delta y = -12.544
That's correct. The formula finds the displacement in the y-direction which, in this case, is down (hence the negative result).
I did
Viy2 = 1097.6
Viy = 33.13
Viy = Vosin(theta)
Vo = -25.8249
You calculated the angle of displacement; you need the angle of trajectory.
Again: "A ball is thrown horizontally..."
Since the ball is thrown horizontally that means Vo = Vix right? Since the Viy = 0 because there is no vertical velocity. This also means that (theta) = 0 degrees right?
But when I try to find Viy I get:
Viy = Vosin(theta)
Vo = 0/sin(0)
But that's undefined since sin(0) is 0 and you can't divide by 0.
I was figuring I would find Viy and then use the equation: Delta y = Viyt + (1/2)gt2 to find time.
Then use the equation: V = Vo + gt to find Vo.
Viy = Vosin(theta)
Vo = 0/sin(0)
You can't do that!
Consider X = 2 * 0
X = 0
But X \div[/tex] 0 \ne[/tex] 2.<br /> <br /> <br /> You'll have to go about it a different way...
Is it plausible to first find time then use the equation:
Delta x = Vixt + (1/2)at2
Since ax = 0, the second half of the equation would be gone then right?
So I could find Vix = Delta x/t
And I think Vix = Vo, that would be my answer?
You got it!
... the problem is: you only know \Delta[/tex]x<br /> so you need to find either Vi<sub>x</sub> or t ...
I tried a different way by doing:
Delta y = Viyt + (1/2)(g)(t^2)
-56 = -4.9t2
t= 3.3
Then:
Delta x = Vot + (1/2)axt2
45 = Vix(3.3)
Vix = 13.63
Is this correct now? I think it is.
Also would you mind if I asked you about another problem, I'm not sure if my answer is correct because. I did not catch the answer my teacher said it should be.
Great job!
Sure, but you should either start a new thread, or PM me...
  • · Replies 38 ·
  • · Replies 31 ·
  • · Replies 19 ·
