Are the Lorentz Transformations False?
54 replies · 5K views
Leepappas
TL;DR
SR just doesn't make sense.
Consider the Lorentz transformations with c=1, and consider any point in space whose x coordinate isn't zero, starting from
##t_{inital }= t'_{inital }=0##
##t' =\gamma (t-xv)##
##t= \frac { t'}{\gamma} + xv##
##\Delta t' = t'-0##
##\Delta t = t-0##
Time dilation provides
##\Delta t' =\gamma \Delta t##
So
##\Delta t = \frac {\Delta t'}{\gamma} + xv##
Or
##\Delta t = \Delta t + xv##
Whick implies x=0 or v=0.
Since x isn't zero, v=0.
But the rulers are in relative motion therefore not(v=0).
Therefore v=0 and not (v=0).
This contradiction was arrived at by assuming the Lorentz transformations are true, therefore they are false.
#\Delta t'=\gamma \Delta t#
No, it doesn’t. Not in general. You need to work on your understanding of the requirements that apply for time dilation and length contraction formulas to apply.
Edit: Working on correcting your use of math delimiters would also be desirable. 😛
Edit 2: To put things in context: Here
Leepappas said:
consider any point in spacetime whose x coordinate isn't zero.
you are essentially stating “pick any event such that the time dilation formula I am going to use does not apply”.
Leepappas said:
TL;DR Summary: SR just doesn't make sense.
Consider the Lorentz transformations with c=1, and consider any point in spacetime whose x coordinate isn't zero.
##\Delta t'=\gamma \Delta t##
Clearly, those two statements cannot both be true.
If you assume the Lorentz transformation, can you identify the constraint for time dilation to apply?
##\Delta t = t-0##
I assume that ##\Delta t## and ##\Delta t'## are meant to refer to the intervals measured between some pair of events using different frames. But note that you've specified that the start time in both frames is zero. The only event that has ##t=t'=0## is the origin, where also ##x=x'=0##. So you are here implicitly assuming an x coordinate of zero, in contradiction to the preceding paragraph.
That's where your problems start.
Yes they are measured with respect to a pair of events. The first event has SpaceTime coordinate
##(t,x)=(0,0)##
The second event has space-time coordinate
##(t,x)##.
##(t,x)##.
Then either ##x=0## here too, or else the clock is not at rest in the unprimed frame and the time dilation formula you quoted does not apply.
Ibix said:
I assume that ##\Delta t## and ##\Delta t'## are meant to refer to the intervals measured between some pair of events. But note that you've specified that the start time in both frames is zero. The only event that has ##t=t'=0## is the origin, where also ##x=x'=0##. So you are here implicitly assuming an x coordinate of zero, in contradiction to the preceding paragraph.
This is not a problem. The assumed ##x\neq 0## is for the other event, that which OP is Lorentz transforming. However, the problem is that ##x=0## is necessary for the quoted time dilation formula to apply.
Indeed
The time dilation formula is a general statement about how amounts of time measured by clocks at rest in one inertial frame disagree with clocks at rest in another inertial reference frame moving relatively to the first frame. It says nothing about where those clocks are located
But you said the clock was at ##x=0## at first and ##x\neq 0## later, so its ##x## position is changing and it's not at rest!
If you want to use ##x=0## as your start position then you must either choose ##x=0## as the end position or your clock is not at rest and you cannot use the time dilation formula you are using. You cannot have it both ways.
Ibix said:
But you said it was at ##x=0## at first and ##x\neq 0## later, so it's not at rest!
The clock that makes the measurement is stationary in the unprimed frame.
Leepappas said:
The clock that makes the measurement is stationary in the frame.
Then its ##x## coordinate does not change and ##x=0## at both events.
Let its x coordinate be at x=a, where ##a\neq 0##
Let the clock at rest at ##x=a## be synchronized with a clock at rest at the origin of the unprimed frame. Clearly the x coordinate is not zero at both events.
  • Skeptical
Leepappas said:
Let its x coordinate be at x=a, where ##x\neq a##
You're getting nowhere with this approach. The time dilation formula applies to the time shown on a given clock. It does not apply to coordinates generally.
The time dilation formula is a special case of the Lorentz transformation for a single clock: I.e. at a constant spatial location at one of your frames.
The time dilation formula is a special case of the Lorentz transformation for a single clock: I.e. at a constant spatial location.
The clock located at ##x=a## does have a constant spatial location in the unprimed frame.
Sure, but the clocks aren't synchronised in the primed frame, and blindly applying the time dilation formula doesn't acknowledge that.
Look. The Lorentz transform for time is ##t'=\gamma(t-vx)##. If there is an event at ##(x,t)=(x_0,t_0)## and another event at ##(x,t)=(x_0+\Delta x, t_0+\Delta t)## then the primed frame sees time coordinates ##t'_0=\gamma(t_0-vx_0)## and ##t'_0+\Delta t'=\gamma(t_0+\Delta t-v(x_0+\Delta x))## for the same events. Subtracting them gives you the time interval ##\Delta t'=\gamma(\Delta t-v\Delta x)##. This only simplifies to the time dilation formula you used in the case that ##\Delta x=0##.
You keep using the ##\Delta x=0## form while insisting ##\Delta x\neq 0##.
And if you plug ##x=a## in as the location of the first event and the correct corresponding value of ##t'## then you will find no contradiction.
What you cannot do is use one reading on one clock and another reading on another clock at another location and then use a formula that expects the clocks to be at the same location.
So, we have two events ##x_1 = a## at time ## t_1## and ##x_2=a## at time ## t_2##. Using Lorentz:
$$t'_1=\gamma(t_1 - va), \ t'_2=\gamma(t_2 -va)$$Hence$$\Delta t' = t'_2-t'_1 = \gamma(t_2-t_1) = \gamma \Delta t$$
Then it is not synchronized with the clock at the unprimed origin in the primed frame and hence the time dilation formula does not apply to your events. This is relativity of simultaneity.
This is all wrong. The only correct general formula is the Lorentz transformation. The time dilation formula is only applicable to special cases, and the scenario you are trying to analyze is not one of them. That is what other posters are trying to tell you. Please take heed.
Time dilation is already in the Lorentz transform. If you are already using the Lorentz transform then it doesn’t make sense to also separately use the time dilation formula.
The Lorentz transform is the general equation that always applies to any inertial frame. The time dilation formula is a simplification that only applies in specific cases. Here you have used it incorrectly
Here are some Minkowski diagrams to explain what's going on. All are drawn using the unprimed frame.
The first diagram shows a green line representing a clock at rest in this frame and located at ##x=0##. It starts ticking at ##t=0## and stops at ##t=\Delta t## and only this portion of its worldline is marked. There are also two fine blue lines showing the lines of simultaneity in the primed frame, and a thicker blue line showing a clock measuring the elapsed time in the primed frame.
If you were to compute the interval (the "length") of the blue line you would find that it was ##\gamma## times greater than the interval along the green line. This is time dilation.
Time dilation, indeed, does not care where you place the clocks. In this second diagram, I've added a second clock at ##x=a##, again ticking for the same interval in this frame. I've faded out the simultaneity lines from the first diagram and put in new simultaneity lines and a new blue clock. You can see (or calculate!) that it's the same length as the blue line in the first diagram - so again, this is time dilation.
So it doesn't matter whether you use a clock at ##x=0## or a clock at ##x=a##, nor where you place the blue clock that's at rest in the primed frame. The problems start when you try to use the left clock for the start time and the right clock for the end time. In the third diagram I've shown the simultaneity lines in the primed frame associated with those events and added another blue clock showing a much shorter time.
This is why your calculation fails, @Leepappas. It's because, when you apply the time dilation formula the way you are doing, you are assuming that the blue clock line in this diagram is the same length as the ones in the first two diagrams. It manifestly isn't due, as Orodruin says, to the relativity of simultaneity.
Just for completeness, here's the diagram if you use the right clock for the start event and the left clock for the end - this time the blue clock line is so long it doesn't fit on my scale.
Let's derive the Lorentz's transformation . The speed ##v## and the Lorentz factor ##\gamma=(\sqrt{1-v^2})^{-1}## are constant.
We need to express the coordinates of the same point in two coordinate systems.
For me, the most convenient way, is to use scalar product with a normal vector in order to calculate a distance from a coordinate axis.
[1] If we know ##(x,t)## and we want to calculate ##(x',t')##
\begin{align}
&x'=\gamma\left<(1,-v),(x,t)\right>=\gamma(x-vt)\nonumber\\
&t'=\gamma\left<(-v,1),(x,t)\right>=\gamma(-vx+t)\nonumber\\
\end{align}
Also ...
\begin{align}
\Delta x'&=x'_1-x'_2\nonumber\\
&=\gamma(x_1-vt)-\gamma(x_2-vt)\nonumber\\
&=\gamma(x_1-\cancel{vt}-x_2+\cancel{vt})\nonumber\\
&=\gamma \Delta x \nonumber\\
\end{align}
and
\begin{align}
\Delta t'&=t'_1-t'_2\nonumber\\
&=\gamma(-vx+t_1)-\gamma(-vx+t_2)\nonumber\\
&=\gamma(-\cancel{vx}+t_1+\cancel{vx}-t_2)\nonumber\\
&=\gamma \Delta t \nonumber\\
\end{align}
[2] If we know coordinates in the prime reference frame ##(x',t')## and we want to calculate ##(x,t)##
\begin{align}
&x=\gamma\left<(1,v),(x',t')\right>=\gamma(x'+vt)\nonumber\\
&t=\gamma\left<(v,1),(x',t')\right>=\gamma(vx'+t')\nonumber\\
\end{align}
Also, similarly as in [1] ...
\begin{align}
\Delta x&=x_1-x_2\nonumber\\
&=\gamma(x'_1+vt)-\gamma(x'_2+vt)\nonumber\\
&=\gamma(x'_1+\cancel{vt}-x'_2-\cancel{vt})\nonumber\\
&=\gamma \Delta x' \nonumber\\
\end{align}
and
\begin{align}
\Delta t&=t_1-t_2\nonumber\\
&=\gamma(vx+t'_1)-\gamma(vx+t'_2)\nonumber\\
&=\gamma(\cancel{vx}+t'_1-\cancel{vx}-t'_2)\nonumber\\
&=\gamma \Delta t' \nonumber\\
\end{align}
Event 1 at (0,0).
Event 2 at (a,t).
The primed frame sees time coordinates ##t'_0=0## and ##t'_0+\Delta t'=\gamma(t_0+\Delta t-v(x_0+\Delta x))## Subtracting them gives you the time interval ##\Delta t'=\gamma(\Delta t-v\Delta x)##. I completely see this is not the simple time dilation formula.
Something about this is counterintuitive. Why in the world should the amount of passage of time in the primed frame depend upon ##where## a clock is in the unprimed frame? To the contrary, it should be independent of the location of any clock at rest in the unprimed frame. We can change the amount of time in the primed frame simply by changing position in the unprimed frame, that's ludicrous.
Yes. And that's the Lorentz transformation formula. It is not the time dilation formula. You have just demonstrated why your logic in the OP of this thread is wrong.
From those two equations follows, even without the time-dilation formula:
##0=t'_{inital } =\gamma (t_{inital }-x_{inital }v)=\gamma (0 -x_{inital }v)##
##\Rightarrow##
##x_{inital }v=0##.
With
##\Rightarrow##
##x_{inital }=0##.
Then with ...
... follows, that you assume, that the clock rests at
##x=x_{inital }=0##.
This looks a lot like your locked thread.
@Leepappas what's your goal here? Is it to convince us that you have found a contradiction in SR, like you tried in your old thread? Sorry...you won't. It is known to be internally consistent and it has been shown to match observation.
If it's to better understand SR, I would start by going back to that thread and re-read those responses so we can start from there. Why should people type essentially the same answers to essentially the same questions if they did so before?
Since that old thread I have familiarized myself with the relativity of simultaneity and Minkowski world lines. This is a new thread with a new idea. I'm starting to suspect that it is internally consistent as you say, but I have my intuition which tells me it contradicts reality. Can you explain to me why on Earth the amount of passage of time in the primed frame should depend upon where in space a clock is located in the unprimed frame?
  • Sad
This is a very common feeling. Intuition is based on experience and relativistic speeds are outside of our experience. So we simply do not have intuition that is trustworthy in relativity.
Part of the reason that we do careful scientific experiments is precisely so that we can overcome our limitations and find out how nature behaves in regimes we don’t directly experience. Here is a summary of the experimental evidence:
https://math.ucr.edu/home/baez/physics/Relativity/SR/experiments.html
Our intuition is wrong. Reality is relativistic.
What? I don’t understand what you are asking. Can you write it with math?
Now in response to Dale's question I say:
While the equation ##\Delta t'=\gamma \Delta t## was merely distasteful, the equation
$$\Delta t'= \gamma (\Delta t - v\Delta x)$$
Is totally repugnant.
In the former equation, ## \Delta t'## isn't a function of the spatial coordinates of a point in the unprimed frame. In the latter equation ##\Delta t'## is a function of the coordinates of a point in the unprimed frame. That goes against all common sense.
The universe, alas, is not required to conform to your intuition. You're just not that important. :smile:
