Are the Req's between Two Nodes Equivalent? Basic Resistor Question Explained
  • Thread starter Thread starter nhmllr
    Resistor
The forum discussion centers on determining the equivalence of resistor networks between two nodes, specifically analyzing four different configurations. The first three configurations are confirmed to be equivalent, while the fourth configuration is not. Participants suggest using unique identifiers for resistors and applying Kirchhoff's Current Law (KCL) to find equivalent resistance, especially when traditional series/parallel combinations do not apply. The discussion also touches on delta-wye (triangle-star) conversions as a method for simplifying complex resistor networks.
  • Understanding of resistor networks and equivalent resistance
  • Familiarity with Kirchhoff's Current Law (KCL)
  • Knowledge of delta-wye (triangle-star) conversion techniques
  • Basic circuit analysis skills
  • Study Kirchhoff's Current Law (KCL) applications in circuit analysis
  • Learn about delta-wye (triangle-star) conversion methods
  • Explore resistor network simplification techniques
  • Practice analyzing complex resistor configurations for equivalence
Electrical engineering students, circuit designers, and anyone involved in analyzing or designing resistor networks will benefit from this discussion.
nhmllr
Are the following Req's between the two nodes equivalent? I'm pretty sure the first and seconds ones are, sort of sure the third is, and a little sure the fourth one is. The r's are the resistors. I'm sorry that the pictures are so crude, I couldn't attach my MS paint picture's jpeg or png
Bonus Question: Why does Req stand for Total Resistance? Nobody seems to know...
1.
o------------
...r...r
o------------
...-----r---
o---|...|----o
...----r-----
2.
o--------------------
...r...r...r
...-----r---
o---|---r---|----o
...----r-----
3.
...----r-------r-----
o---|...|...|---o
...----r----...---r-----
o---|...|----|...|---o
4.
o---|...r...|---o
o---|...|-r--|...|---o
Req stands for equivalent resistance.
Please share more of your thoughts on your problems.
It may help you to look at it this way:
Re-label the resistors with unique identifiers (R1, R2, etc.)
Determine the minimum path or paths from one node to the other.
Which resistors are passed through in each case?
Use that information to determine if the 2 circuits are equivalent.
Example:
In #1, you can get from one node to the other by passing through either R1 or R2.
This holds true for the both circuits, so they are equivalent.In #3, let's relabel the resistors in the 1st circuit so that the upper left resistor is R1, the upper right one is R2, the lower left one is R3, and the lower right one is R4. Now, notice that there are four ways to traverse from one node to the other (without looping back or re-using a resistor): R1 to R2, R1 to R4, R3 to R2, and R3 to R4. Keeping the same labeling convention for the 2nd circuit, you can see that the same 4 routes get you from one node to the other. Therefore, the circuits are equivalent.
Now, try this with problem #4.
So the 4th one isn't equivalent... Then how do I find the Req?
...----r1-------r2--
o---|...r3...|---o
...----r4-------r5--
Would it be the same as this?
...|-----r1-----r2----|
o---|--r1----r3---r5--|---o
...|-----r4-----r5----|
...|--r4----r3---r2--|
ugh that's annoying...
Also by that logic, this (assuming the second node is not on the intersection)
------r-------
...----o---
could be replaced with this?
---r---o---r-----
Just curious...
------r-------
...----o---
---r---o---r-----
Just curious...
What's "o"? Another resistor? Whatever it is, it's in parallel with "r", and you would need to use the parallel combination formula to combine them.
o---|...r3...|---o
Yes, trying to draw resistors like that is annoying. You could use "code" tags in order to force a non-proportional font, or you could just draw them in Visio and convert to PDF.
And you are correct that #4 is not equivalent. I'm not sure there's an easy way to find the equivalent resistance (there may be some trick), but in general, I just write a couple KCL equations for the network and solve.
My bad- the o is just a node
So both my first and second attempts at trying to find an equivalent layout are both wrong?
I could be missing something, but I don't think they are right.
Are you familiar with how to write Kirchoff's Current Law (KCL) equations? That's the sure-fire way to figure out the equivalent resistance if it doesn't look like the resistor structure will simplify with traditional series/parallel combinations.
No, please don't follow this advice. It is a painful exercise for a one-line problem.
Is there a trick when all 5 resistors are different?
EDIT -- Certainly if all 5 resistors are the same value, there is an easy simplification. But I didn't think we were making that assumption in this thread...?
I am sorry, I thought they have some symmetry. However, if they don't, maybe he can use the triangle(polygon)/star conversion. It still relies on KCLs, though.
EDIT:
Link: http://en.wikipedia.org/wiki/Y-Δ_transform
EDIT:
No worries, and actually, looking back at Post #1, they *are* all labelled the same. Maybe it was us "helpers" that generalized the problem for the OP...?:-p
Hey nhmllr -- were you supposed to assume that all the "r" values were the same? That definitely simplifies configuration #4. Quiz Question -- Why does it?
o---|...r3...|---o
No, that doesn't work. You can't convert like this since your paths utilize R3 more than once. That's the flag telling you that there's something else going on here.
As Dickfore mentioned, you'll need to use "triangle-star conversion" (better known as "delta-wye conversion"). Google that ... there's plenty of info out there on how to do it.
To summarize though, problems 1, 2 & 3 all have equivalent circuits (regardless of resistor values). Problem 4 however, does NOT show equivalent circuits.
Note that this network
Code:
    ---- r1 -------- r2 ----
o---|          r3          |---o
    ---- r4 -------- r5 ----
is equivalent to these 2 networks in series:
Code:
    ---- r1 --------o          o---- r2 ----
o---|          r3                          |---o
    ---- r4 --------o          o---- r5 ----
The network on the left is in a delta configuration and will need to be converted into an equivalent wye configuration of the form
Code:
           ----o
           s1
o--- s2 ---|
           s3
           ----o
The "S's" represent resistors with values different than those in the delta configuration.
The original network can then be shown as:
Code:
           ------ r2 ----
           s1           |
o--- s2 ---|            |----o
           s3           |
           ------ r5 ----
which is the same as
Code:
            ---- s1 ---- r2 ----
o--- s2 ---|                   |----o
            ---- s3 ---- r5 ----
o---|...r3...|---o
If (and only if) all the resistors have equal value r, the bridge circuit simplifies very easily. Can you see what the total would be?
Hint, imagine a voltage applied across the network: what then would be the voltage across the central resistor R3?
Oops. Berkemann has already pointed this out. Sorry!
The condition denoted in red is not necessary for that to be possible.
Dead right too - I must have been asleep. Any balance condition would do the trick.
9K
  • · Replies 22 ·
