B Are time and light at the same speed?
  • B
  • Thread starter Thread starter adafus
    Light Speed Time
adafus
TL;DR Summary
I guess it's probably a silly question but i was wondering about it in quite some time now, if you go (hypothetically) faster than the speed of light, time itself will not exist for you. Doesn't that means that the light is moving in the same speed as the time itself? That could be the reason of the constant of the light too, or am i thinking too high?
I'm probably am wrong in this but i guess you guys could light me in this one
adafus said:
Summary:: I guess it's probably a silly question but i was wondering about it in quite some time now, if you go (hypothetically) faster than the speed of light, time itself will not exist for you. Doesn't that means that the light is moving in the same speed as the time itself? That could be the reason of the constant of the light too, or am i thinking too high?
I probably am wrong in this but i guess you guys could light me in this one
It doesn't make much sense to talk about the speed of time. Speed is generally the rate of distance/time. What would "the speed of time" even mean?
Likes Vanadium 50
Well it could measure the speed of the expansion in the universe i guess, like if the time is a dimension and the universe itself is what creates the others dimensions of space, it could as well in it be the same speed as it moves, something like that.
Correct me if I'm wrong please
The expansion of the universe is measured in speed/distance as in ##70km/s## per Mega parsec. Or thereabouts.
I see... then it doesn't go in the way i thought, i will think more about it
I know this can be dumb but, when light is travelling, this ##70km/s## remain the same? Or the speed of the expansion of the universe is a constant as well?
I'm talking about turning the light itself as the reference frame
That makes no sense. Even trying to interpret it as a question about the rest frame of light makes no sense, since light can never be at rest and cannot have a rest frame.
Light travels through vacuum locally at the speed ##c##: that means as measured by a local observer. If a light signal travels through an expanding universe then the light is always moving locally at ##c##, but the total time to get from point A to point B depends on the expansion of the space between A and B.
The universe expansion is not constant. At the moment it is thought to be accelerating, which means that the expansion rate is increasing.
Well in my head it was different, i thought about if we put the light as reference frame the speed of the universe expansion would go up or something like that, guess I'm wrong then, still fun to wonder about.
Yeah i studied that, and how the time slow down to make the light travel at the same time even with the space itself bending, but i just don't quite understand why just photons can make this, why photons itself need to travel at such speed and why is time bending within it, so i just thought that maybe the question was is not the light that needs to travel at the smallest distance, but time itself, or something like that
I don't know how much English mistakes i made so far, so, apologies
I think you are confusing gravity with universe expansion. Modern cosmology is built on General Relativity, which is well understood in terms of the paths of light through spacetime.
That the local speed of light is always ##c## is a postulate of relativity. It can't be proved or explained, as such, but it can be confirmed by observation.
oh no, i guess I'm just confusing myself because I'm not good at giving examples, i understand well the diference between gravity and universe expansion (I'm a bit ashamed of myself for looking like i don't), the thing is that i am trying to make correlation about this two things, like , ''why when space bends the examples we use are about how the light is traveling and not about how TIME is travelling'' and ''The universe expanded and keeps accelerating, but it start expanding at the same time as the time itself, so is time accelerating?'', And if the time is accelerating, how could we know? Because we are traveling within it.
Guess this is where I'm trying to get.
There is a geometrical interpretation of Relativity similar to what you describe:
https://diagonalargument.com/2019/09/15/epstein-relativity-diagrams/
In this interpretation, everything (not just light) advances at the same rate in space-propertime. Only the direction with respect to the space and propertime axes is different. So if you are at rest in space, then you are advancing at the same rate thought propertime, as light is advancing through space.
Likes adafus
Thanks, i will take a look, but is kinda strange, why we just see the rest in space and not in time? Am i getting into a misconception about thinking that time is a dimension as well?
adafus said:
oh no, i guess I'm just confusing myself because I'm not good at giving examples, i understand well the diference between gravity and universe expansion (I'm a bit ashamed of myself for looking like i don't), the thing is that i am trying to make correlation abut this two things, like , ''why when space bends the examples we use are about how the light is traveling and not about why TIME is travelling'' and ''The universe expanded and keeps accelerating, but it start expanding at the same time as the time itself, so is time accelerating?'', And if the time is accelerating, how could we know? Because we are traveling within it.
Imagine drawing two spacetime axes (##x## and ##t##, say). You can plot the worldline of a particle or light ray and it makes sense to talk about the motion of the particle or light ray.
But, it makes no sense to talk about time moving. Your coordinate axes provide a reference frame in which motion may be described.
Spacetime curvature (including the concept of an expanding universe) is described by the notion of a distance (metric) between any two points in spacetime.
''How can you be moving if you are at rest in a chair? You are moving through time. '' This is what Einstein said, this makes me think even more that time and light move at the same speed, but i just don't have proof yet i guess
  • Skeptical
Likes weirdoguy and PeroK
You've already been told that this does not make any sense. Why are you repeating it?
Likes Vanadium 50 and PeroK
You're also spinning with the surface of the Earth, orbiting the Sun and orbitting the galactic centre. Your watch is always ticking, that's true.
I don't think that just by don't understanding completely makes me wrong, maybe i just can't proof it yet, I'm looking at it in new ways, i will not surrender about it yet
  • Sad
Likes weirdoguy
In relativity you have two different time quantities:
- coordinate time, measured by a clock at rest in the used reference frame
- proper time, measured by a clock moving with each object
It makes you wrong because statement "time and light move at the same speed" makes no sense to begin with. Time is not a "thing" that moves anywhere. So there is no "speed of time".
Is it the same time dilation that is learned in school right?
weirdoguy said:
Light is not a "thing" that moves anywhere. So there is no "speed of time".
Is not a thing but yet it exist as a property, and so does time
Sorry, I corrected my post. I meant "Time is not a "thing" that moves anywhere. So there is no "speed of time"." Light is a thing, it's electromagnetic wave and it definitely moves.
Likes adafus and PeroK
Light is electromagnetic radiation; and time is not electromagnetic radiation!
Likes adafus
Yes, it's the same formula, just visualized geometrically.
In the usual Minkowski diagram you have the coordinate time on the vertical axis, and no direct visualization of proper time.
Likes adafus
don't change my response, is not a thing but is a propriety, gravity not exist as well but doesn't mean that we can't measure, i just saying that maybe we're looking at time and light as almost the same thing when we need to measure it
  • Sad
Likes weirdoguy
  • #31
This is where I'm trying to get, light is not the only thing that travels at ##c##, there is a reason for that am i wrong?
  • #32
adafus said:
light is not the only thing that travels at , there is a reason for that
Every massless "thing" travels at the speed of ##c##. That's pretty well understood.
Likes adafus
  • #33
Good Good, why? is almost like is not traveling in space but in something else, but i know that it is in space, because it can get distorted by gravity
  • #34
Proof by endless repetition?
  • #35
This is not only wrong, but logically impossible.
  • #36
I'm not trying to prove it yet, I'm just trying to understand it better, I'm only a teenager who wants to study physics in a soon future, and you guys are the experts, but i need to give my best being this dumb to understand at least a bit
  • #37
You can't do that by personal speculation based on incorrect beliefs, or by throwing out further questions when you haven't even understood the answers to the previous ones. And you certainly can't by refusing to listen to what people who are much more knowledgeable than you are telling you.
Thread closed.
