Are virtual particles real or just math filler
In summary, virtual particles are just a convenient visual aid used in the math of Quantum Field Theory. There is no known physical test that could further answer the question of whether they are "real" or not.
  • #36
Well, you don't need to use Feynman diagrams but just the mathematical formalism. Famously Schwinger apparently never used Feynman diagrams but got the same results as Feynman. With Feynman diagrams it's of course tremendously more easy to get the calculations. I guess that the full understanding of perturbative renormalization theory (BPHZ) would have been also very much more complicated without the use of Feynman diagrams. Zimmermann's forest formula is even formulated in terms of Feynman diagrams. Ironically, the corresponding paper, where it's proven doesn't draw a single Feynman diagram ;-)).
  • #37
jtbell said:
No, they are not necessary. See the discussion of lattice field theory in this thread which has been going on parallel to this one. (in particular, post #6 onwards)
Which particles are never used in a Feynman diagram? If they can possibly be used in virtual processes, then why should it be wrong to develop a theory using them?
  • #38
The name "virtual particle" suggests that there is something like "real particle", but we know that the name "particle" in quantum physics means something else than a classical particle. In this sense a virtual particle is as real as a 'real' particle, but it cannot be observed directly. However, their effect can be measured and this must be taken into account in theoretical models.
See also http://www.scientificamerican.com/article/are-virtual-particles-rea/
  • #40
friend said:
There's something wrong with your link. The text only appears at the bottom and keep moving around.
Here it works fine. Plus I'm looking forward for another explanation of the Lamb effect.
  • #41
I don't have problems with the link, but the content may depend on your particular browser.
SA's way of advertising is a bit anoying. Try to get rid of ads by clicking on the X.
  • #42
Well, I could read it too, and I'm shocked that someone like Kane could write it, who wrote a good textbook on introductory particle physics, including QFT.
Likes bhobba
  • #43
DrChinese said:
Welcome to PhysicsForums, J-eastwood!
The generally accepted answer is: Virtual particles are artifacts of the math of Quantum Field Theory. Many find them convenient for discussion purposes. Whether they are "real" or not is something of a matter of philosophy. There is no known physical test that would further answer this question.
I would only add that the entire QFT approach is unphysical or unreal if you like.
  • #44
Unphysical and unreal are not the same thing. QFTs are definitely physical theories. They have made several astonishing predictions which have later been verified, which is what a physical theory is all about. Something being "real" or not is more of a philosophy issue than a science one.
Likes bhobba and vanhees71
  • #45
Very true.
They do not appear in Lattice theory so obviously do not have to be taken into account.
They are simply the pictorial representation of terms that appear in a Dysen series, which is what a Feynman diagram is.
Real particles are responsible for things like clicks in a particle detector - virtual particles are not. That's pretty common-sense, but as Orodruin says its a philosophical minefield. Scientists generally don't worry about such things, the consequences of which can be seen by the progress each field has made.
There is thread after thread about this issue on this forum, and its all exactly the same - they get no-where because some simply do not want to accept the obvious. Anything said outside an actual QFT textbook is very suspect and must be taken with a grain of salt. Study the real deal and this semantic quibbling never comes up. Its a much better use of an enquiring minds time. Recently some very good books have started to appear that can, with effort, be studied after a first course, or the study of a good text, in QM:
https://www.amazon.com/dp/019969933X/?tag=pfamazon01-20
Having got that book and studied it myself I think, again with effort, it can be studied after reading Susskinds text:
https://www.amazon.com/dp/0465062903/?tag=pfamazon01-20
Thanks
Bill
  • #46
I've always taken the view:
In-State = physics
Stuff in between = mathematics to get the right transition amplitudes in<->out
Out-State = physics
Statements like
"Quantum theory predicts that every particle spends some time as a combination of other particles in all possible ways. These predictions are very well understood and tested"
strike me as misleading. If you've done a QFT course you know what he's alluding to, but to phrase it like this is a bit sloppy. But then he's a professional physicist and I'm just a guy on the internet!
Likes Jilang, vanhees71 and bhobba
  • #47
In-State = physics
Out-State = physics
Yes! An the correct adiabatic switching a la Gell-Mann and Low is crucial. See
F. Michler, H. van Hees, D. D. Dietrich, S. Leupold, C. Greiner, Non-equilibrium photon production arising from the chiral mass shift
Ann. Phys. 336, 331 (2013)
http://dx.doi.org/10.1016/j.aop.2013.05.021 [Broken]
http://arxiv.org/abs/1208.6565
for an example.
Likes bhobba
  • #48
I'm a little surprised that I've not seen any math equations in this thread showing where virtual particles appear in the equations. Are virtual particles a part of QFT? Or do they exist in QM as well?
  • #49
One can find them in both, and even in classical field theory (as explained in the link given)!
But the corresponding Feynman diagrams are heavily used primarily in QFT.
Giving formulas is not really useful since their whole purpose is to substitute imagery for formulas. You can read the Feynman rules relating the diagrams to integrals in any QFT book.
  • #50
Well, that's easy. What's called "virtual particle" in popular science books is symbolized by internal lines of Feynman diagrams, and they stand for free-particle Green's functions (in usual perturbation theory; sometimes they can have a different meaning, e.g., in the context of resummation schemes like the ##\Phi##-derivable approximation or the functional RG methods), but that doesn't matter too much on the level of this discussion.
In the Standard Model you have only scalars, (Dirac-)spinors, and vectors (gauge fields). Thus the "virtual particles" stand for the corresponding propagators
$$\Delta(k)=\frac{1}{k^2-m^2+\mathrm{i} 0^+},$$
$$G(p)=\frac{p_{\mu} \gamma^{\mu}+m}{p^2-m^2+\mathrm{i} 0^+},$$
$$D_{\mu \nu}(k)=-\frac{g_{\mu \nu}}{k^2+\mathrm{i} 0^+},$$
the latter in the Feynman gauge.
Likes bhobba
  • #51
What you've shown here is for perturbation theory. What about the virtual particles that are supposed to be everywhere, the ones that get ripped apart by black hole horizons or Unruh acceleration, or that are supposed to be involved in the Casimir effect, etc? What is the math for these?
  • #52
As has been explained in many many threads they don't exist. They are simply representations of integrals. Everything you cite above can be explained without them.
This has been explained to you many times - the following simply being the latest:
https://www.physicsforums.com/threads/can-particles-be-absorbed-into-a-field.855789/#post-5368838
I gave you a link to John Baez's paper before:
https://www.physicsforums.com/insights/struggles-continuum-part-5/
'Each of these diagrams is actually a notation for an integral! There are systematic rules for writing down the integral starting from the Feynman diagram.'
Please please read it and post with any queries you have so it can be put to rest once and for all.
Thanks
Bill
Likes Vanadium 50
  • #53
I'm sorry, but I hear every Professor that gives a lecture invoking them to explain things. Perhaps that is just a tool, but I have seen them show equations where they sum up all the zero point frequency modes and give this as the reason that the calculated vacuum energy is so many orders of magnitude greater than what is measured. I've heard professionals teach about virtual particles, virtual paths, and even virtual geometries. From what I can gather, virtual objects are the differential parts of the path integral that are being summed up in superposition. They aren't observable in and of themselves, but they are the basis of the integral. We sum up differential parts in other integrals of physics, and those differential parts can't be observed either.
What I think is going on is that this aversion to virtual particles is being fueled by the faith that quantum mechanics cannot be explained. And any attempt to do so is misguided. For if there were to be any explanation of QM, it would have to necessarily involve virtual particles just as classical physics is explained in terms of differential parts. So I think that your attempt to definitively rule out virtual particles is misguided.
  • #54
Already the "are not observable" should ring the warning bells. They are also not the basis of the path integral, but only a very convenient way of computing it (approximately). Much like you might use partial integration or the Leibniz rule to perform computations in calculus.
That being said, they are a very useful tool and I know many people like to think in terms of them.
Likes bhobba
  • #55
Exactly.
To Friend - did you read what John Baez wrote? He stated it clearly - they are representations of integrals. Why exactly won't you accept it? Why do you chose instead to worry about what others say? Here you get the real deal - but for it to be of value you must take it on board. You will get nowhere constantly saying others say different. They are not being careful. We are. It's that simple.
You pretty well admit you haven't studied an actual QFT textbook. Until you do you will not have the background necessary to reach conclusions like the above. It's wrong - but since you seem to doubt what we say here I don't know what to say. I tell you its wrong - but because you won't accept it it won't make any difference. You come here seeking to learn - but won't accept what those you have chosen to learn from say. In science you have two choices. Either you believe what those that have studied it tell you or you read the textbooks yourself. There is no middle path of reading what others say then using that as ammunition to challenge those that tell you different. That leads nowhere.
The challenge I have for you is to study an actual text:
When you have done that then we can discuss if you still think they are real.
Thanks
Bill
  • #56
This is because in explaining things to people without a thorough grounding in math you cannot explain much without using gross simplifications and imagery in place of the real thing. But if you come to this forum to learn you are expected to realize that the views created for the general public are different from the views physicists have when doing real work.
One talks informally as if virtual particles were real since it is a quick way of conveying superficial information. But the word ''virtual'' (which is opposite to ''real'') is added everywhere to signal that this is only a figure of speech. Once one tries to substantiate in which way the virtual particles could be thought of as real, the whole concepts dissolves into nothing but a metaphor for multivariate integrals. Please read https://www.physicsforums.com/posts/5334791/bookmark and the link posted there, where this is carefully explained.
Likes bhobba
  • #58
Without having read the paper, I can only say that for sure they don't measure the vacuum. The very fact that they measure something means that there is a measurement apparatus present, and that's not vacuum. There are quantum fluctuations of the electromagnetic field, but they manifest themselves always only at the presence of charges, because we cannot detect anything without having the interaction of the electromagnetic field with matter consituting a measurement device, and this matter consists of electrically charged particles.
Likes bhobba
  • #59
I feel like I'm arguing the existence of God, something that is the cause of everything else but not in and of itself observable. What is it, then, that we are integrating in the path integral? The integrand in the path integral is the exponential of the complex Action integral. And this exponential of the Action can be broken up into exponentials of differential Actions. What do these exponentials of differential Actions mean if not virtual particles?
I think the problem comes in because the path integral involves an infinite number of integrations. In the development of classical physics the integrals are along a path or throughout a space which seem more intuitive. So we don't question what the integrand means in those classical integrals, and we feel that the integrand in those classical integrals do have intuitive physical meaning. They are differential objects described in terms of force, velocity, and acceleration on infinitesimal bits of matter and charge that we then have no trouble integrating to get overall energies and distances, etc. But these differential bits are not any more observable than anything in the path integral. Nobody observes these bit of mass or charge or these differential displacements. But nobody argues that they are not real because it seems more intuitive to integrate them to get observables.
We still have differential bits in the path integral; these are called virtual to stress that they are not observable, but that's not something new. The difference here is that we are using an infinite number of integrations to take into account every possible combination of the differential, virtual effects from one point to another in a continuum. That together with the fact that we are summing up complex numbers to get a superposition of all these virtual effects makes the path integral less intuitive. But if we are going to understand what's going on in the math, we're going to have to get a better idea of what these differential, virtual processes are just as we do in the classical picture. Then we can take every combination of them in superposition to get the observables that we can measure. It seems we are doing some of that when we describe the Lagrangian in terms of interacting terms of quantum fields and coupling constants and the like, that exist in the Action integral inside the path integral. And then these quantum fields are described by particle number at each point. Some of these particles are real and others cancel out in superposition and are described as virtual.
  • #60
I do not understand your desire to interpret more into the virtual particles than there is to it. The path integral is perfectly well defined without the introduction of virtual particles as an integral over all possible field configurations (with a given appropriate measure). Expanding the exponential in an asymptotic series is essentially only a trick we use to compute this integral because it is generally very difficult to compute it analytically in other ways. Once you have made the asymptotic expansion, the Feynman rules, including the virtual particles, are only a means of keeping track of the terms in this series. This does not change the fact that the path integral itself is well defined without virtual particles.
The path integral itself is the same type of integral which appears in normal quantum mechanics (where you integrate over actual paths and not field configurations). The situation is similar for ghost fields which do appear in Feynman diagrams due to what is essentially a mathematical trick for rewriting the path integral in a way which handles gauge invariance in a pleasant manner.
Likes bhobba
  • #61
I'm not trying to interpret more than there is to it. I'm trying to understand what is to it. I don't understand how you could have missed my point. It seems obvious and unavoidable that we need to understand what's inside the integrals just as we do in classical mechanics. If some of that involves virtual effects then we need to understand that as well.
We may be using the term "virtual" in different ways. You seem to be using them to refer only to terms in a perturbation expansion. I think I may be using them more generally as mathematical artifacts that exist everywhere and must be taken account of in calculations. I don't think your use of virtual particles in a perturbation expansion take into account other uses of virtual in such things as the Casimir effect, that assume they are all over the place and not just hiding in a the calculation of some particular observable.
  • #62
It is a fallacy that each part of a formula means something else than what the formula actually says.
Yes. The path integral is (in certain cases) well-defined, but as you say, the virtual particles are only a means of keeping track of the terms in this series. They don't have more meaning in the path integral itself than the terms ##x^n/n!## in the expansion of the exponential function have for the exponential function itself! They even have less meaning since most individual Feynman diagrams evaluate to infinity if taken by themselves, and only well-chosen combinations in the formal expansion lead to a well-defined numerical result.
We also don't question what the integrand means in a path integral, and the integrand in a path integral does have intuitive physical meaning. But once you are singling out particular contributions to the path integral appearing in a perturbative expansion and declare them to have physical meaning by themselves it is like saying that ##x^n/n!## has an intrinsic meaning for the exponential function. But the exponential function can be defined in many other ways, e.g., as the limit ##\lim_{n\to\infty}(1+x/n)^n##, where these terms are completely absent - so they cannot have an intrinsic meaning. Similarly, the path integral can be defined in other ways, e.g., as a formal limit of lattice approximations, and if you do that, virtual particles are completely absent - so they cannot have an intrinsic meaning.
But I won't argue that again; read and think about the link in post #4 of this thread! If after having digested that you still want to argue, you are incurable and I won't answer anymore.
Likes bhobba and Orodruin
  • #63
Those are some interesting points. But if virtual particles are a way of understanding processes in some calculations, then the bottom line is that if they can lead to calculations, then use them. That's what they do in the Casimir effect, isn't it? I'm not arguing that they are necessarily real. I'm perfectly content to say that they are mathematical artifacts. For we haven't proven that our mathematical description of physics is unique, have we? There might be other math that results in the same answers. So perhaps we should start showing the math we are referring to and stop arguing about undefined words. (What is a virtual particle? Sheeeesh)
  • #64
It is precisely the same use, once you look at the calculations done.
Only how one talks about them may differ from application to application and from author to author since virtual particles as ''real'' objects (rather than wiggles on paper) are limited in their properties only by the fantasy of the respective authors.
  • #65
They don't lead to calculations. They are a pictorial way to talk about calculations without having to display the details. And they are indeed heavily used in this way. Just don't mistake this use as being more than figurative speech!
  • #66
When you do a Fourier analysis on a function and express the function as an integral what does that function mean? That too is integrating over complex exponentials. Does that mean it contains virtual particles that are real?
Thanks
Bill
  • #67
If you want to that you must study a textbook.
Thanks
Bill
  • #68
One should, however, stress that the Casimir effect is (of course) NOT proof of the existence of "vacuum fluctuations" but of quantum mechanical charge and em.-field fluctuations. Without any matter there's no Casimir effect. The usually treated way in introductory textbooks describing two conducting plates in terms of a boundary-value problem is in fact the em. coupling to ##\infty## limit (leading to an ideal conductor as an idealized model for the plates) of the true affairs. See
http://arxiv.org/abs/hep-th/0503158
  • #69
They used electro-optic sampling with following setup: Electro-optic sampling of an electric-field waveform by an ultrafast probe pulse, consisting of an EOX (electro-optical crystal), a quarter-wave plate (λ/4), a Wollaston polarizer (WP), and a differential photocurrent detector (DD).
Obviously you have a point. What perplexes me is how can this research be titled as it is? The only way to understand it is umm... 'We tuned into the void to see what the fabric of reality itself translates into when looked at with an optical kaleidoscope?'
  • #70
Well, I must admit that I couldn't understand the paper just from reading, because I'm not an expert in quantum-optics. At least they could have written out their three-letter acronyms. I'd have to dig through a lot of literature before being perhaps able to do so.
Obviously the referee was not very strict in letter through this paper in the published form! I don't say that there's anything wrong with the core physics, but despite the misleading title at least the introduction, I'd have rejected right away, because neither of the given examples for radiation correction effects of QED are "vacuum fluctuations". Rather they are indeed quantum fluctuations of charges and the em. field: There's no Casimir effect without charges (google for Jaffe and Casimir effect to find a nice treatment). The Lambshift of the hydrogen lines are quantum effects on the Coulomb-bound state energies (vertex corrections, photon polarization, including also QCD corrections) etc. etc.
Likes bhobba
<h2>1. Are virtual particles real or just math filler?</h2><p>This is a commonly asked question in the field of quantum mechanics. The answer is that virtual particles are a mathematical concept used to explain certain phenomena, but they do not have a physical existence in the same way that particles we observe do. They are a useful tool for understanding the behavior of particles at a subatomic level.</p><h2>2. How do virtual particles differ from real particles?</h2><p>Virtual particles are different from real particles in several ways. Real particles have mass, spin, and can be directly observed and measured. Virtual particles, on the other hand, do not have mass or spin, and cannot be directly observed. They only exist as mathematical constructs to help explain certain phenomena.</p><h2>3. Can virtual particles be detected?</h2><p>No, virtual particles cannot be directly detected. This is because they do not exist in the same way that real particles do. They are a mathematical concept used to explain certain behaviors of particles at a quantum level. However, their effects can be indirectly observed through experiments and calculations.</p><h2>4. Do virtual particles violate the laws of physics?</h2><p>No, virtual particles do not violate the laws of physics. They are a part of the mathematical framework of quantum mechanics, which is a well-established and highly successful theory. While their behavior may seem strange and counterintuitive, they are consistent with the laws of physics and have been confirmed through various experiments.</p><h2>5. How do virtual particles contribute to the vacuum energy of space?</h2><p>Virtual particles are constantly popping in and out of existence in the vacuum of space. This contributes to the vacuum energy, also known as the zero-point energy. However, the total energy of the vacuum is still considered to be zero because the positive and negative energy contributions from virtual particles cancel each other out. This is known as the vacuum energy catastrophe problem.</p>
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
