Area - 5'x6' which is the width and which is the length?
  • Thread starter Thread starter GreenPrint
    Area Length Width
The notation 5'x6' typically refers to dimensions where the first number represents the length and the second number represents the width, although this convention can vary based on context and perspective. In practical applications, such as parking spaces or room dimensions, the distinction between length and width may not significantly impact functionality. Users should be aware that terms like "length" and "width" can be subjective and may change depending on the viewer's orientation to the object. Ultimately, clarity in communication is essential to avoid confusion in measurements.
  • Understanding of basic geometric concepts
  • Familiarity with dimensional notation
  • Knowledge of practical applications in construction and design
  • Awareness of perspective in spatial reasoning
  • Research the conventions of dimensional notation in architecture and engineering
  • Explore the implications of perspective on measurements in design
  • Learn about the impact of dimensional terminology on construction projects
  • Investigate how different countries standardize measurement terms in building materials
Architects, builders, interior designers, and anyone involved in spatial planning or construction who needs to understand the nuances of dimensional terminology.
GreenPrint
Hi, I realized that I don't know when someone uses this notation
5'x6'
which one are they referring to as being the width and which as being the length? What is the standard behind stating things like this for area
thanks in advance
5'x6'
It almost never matters, and neither should it. (Unless it's a spot to park your car. :smile: )
Length x width is customary. But in physics calculations it shouldn't matter. Usually.
to confirm...
if your looking at a object say head on... like a parking space... is it more proper to call the "unit of length" to be the dimension that is parallel to your view of site or the one perpendicular, given that your looking head on to a parking space that is a perfect rectangle? You could change what you call width and what you call length depending on your point of view?
like if i then looked at the parking space say from the side what I once called a length I would now call a width?
There is plenty of room for confusion. Then throw into the mix breadth and depth and along with length and width you can see why it's advisable to place no reliance on "convention". What is your convention may not be mine.
If you rely on "width" and "length" you could end up with your newly-constructed house being rotated by 90o to how you believed you so clearly specified.
Depends. But would it be a good idea to change the term as you walk around the shape?
And if it was your job to lay out the white plastic tape and melt it into the asphalt to delineate a parking space, you may well use "length" for a further dimension: the perimeter. :wink:
I have always taken the longer one to be the length, and the shorter to be the width. I t has never mattered.
Also, in Australia, a common building timber used to be a 4 by 2, meaning cross section was 4" by 2". In the USA I believe that is called a 2 by 4. [We use metric now anyway]
Peter
What a incredibly flawed system =/
What "system" are you talking about?
I guess it's not much of a system, but the ability to call whatever you want length and what ever you want width,
Given that we add lengths and widths to get perimeters, and multiply them to get areas, and both addition and multiplication are commutative, it is not surprising that they can be interchanged.
Also broadloom carpet comes in (amongst other sizes) 12' widths and 15' widths.
If you wanted to carpet a 12' x 15' room, you could use a 15' length of the 12' wide carpet, or a 12' length of the 15' wide carpet!
  • · Replies 18 ·
