Area of the region inside the unit circle
The discussion focuses on calculating the area inside the unit circle and above the curve defined by the function f(x) = x^5. The correct integration points for this area are from 0 to the intersection of the unit circle and the curve, which requires solving the equation sqrt(1 - x^2) = x^5. This results in a 10th degree polynomial that complicates finding exact solutions. The area is determined by integrating the difference between the upper curve (unit circle) and the lower curve (f(x)).
  • Understanding of integral calculus
  • Familiarity with the unit circle equation
  • Knowledge of polynomial equations and their solutions
  • Experience with numerical methods for solving complex equations
  • Learn how to solve 10th degree polynomial equations
  • Study numerical integration techniques for area calculation
  • Explore the properties of the unit circle and its intersections with other functions
  • Investigate the use of software tools like Wolfram Alpha for solving complex integrals
Students studying calculus, mathematicians interested in geometric applications, and educators teaching integration techniques.
aznboi855
The area in the region inside the unit circle and above the graph of f(x) = x^5
I don't know how to type the equation in here but the area is the integral between two integration points of the higher curve minus the lower curve.
I tried using the integration points 0 and 2.02381 (the farthest the graph will stretch out according to derive), but that's the area outside and under the curve, i think the question is asking for the area INSIDE the curve.
As far as I know you can't do it with respect to y because it's infinite.
Thanks.
I'm not sure why you'd be using those integration points. For a unit circle, what is the largest possible value of x and/or y? Or, maybe think about the equation for a unit circle. Where does f(x) cross the unit circle?
(1,1)? So it'll be from 0 to 1 correct?
If we were to do it that way, the point of intersection would be 1 and I'm guessing the radius will be on top of the curve?
So it'll be... SQRT(1-x^2) - (x^5)?
(1, 1) is not a point on the circle.
Finding the points of intersection entails solving the equation sqrt(1 - x^2) = x^5. If you square both sides, you get a 10th degree equation that has no easy-to-get solutions.
