Area of y = sin x is equal to y = x^2, find k
  • Thread starter Thread starter Knight226
    Area Sin
The discussion centers on finding the value of k such that the area under the curve of y = sin x equals the area under y = x^2 from x = 0 to x = k. Participants suggest different approaches, with one assuming k = 1 based on the graph of sin x, while another estimates k to be approximately 1.1. The correct method involves evaluating the definite integrals of both functions to establish a transcendental equation, which will yield the necessary value of k. The emphasis is on using mathematical methods rather than assumptions to solve the problem accurately.
  • Understanding of definite integrals
  • Familiarity with transcendental equations
  • Knowledge of the functions y = sin x and y = x^2
  • Basic graphing skills for visualizing functions
  • Learn how to evaluate definite integrals of trigonometric functions
  • Study methods for solving transcendental equations
  • Explore numerical approximation techniques for finding roots
  • Investigate the properties of the sine function and its graph
Students studying calculus, particularly those focusing on integration and area under curves, as well as educators looking for effective methods to teach these concepts.
Knight226
If the area under y = sin x is equal to the area under y = x^2 between x = 0 and x = k, then k = :
I do not have any idea how to do this problem. So I asked my friends for help, but their methods are different. One of my friend says that he assumes k is 1 because of the graph of sin x. The other friend uses the following method:
That method gives the result of about 1.1
Now… my question is… how should one know k is the upper value? I mean, in the graph of sin x, there is a -1 as well. That will make 0 the upper value and -1 the lower bound value (wouldn’t it?)
The mathematical method sounds reasonable because the areas are equal. But, I am not quite sure how to continue from that equation… she said she wasn’t sure about that equation so didn’t explain to me how to continue the problem.
My biggest question is, are they doing the problem correctly and how should I approach this problem?
Please help. Thank you very much in advance.
The whole point is to determine k, so it's not correct to assume some k value. Try the "mathematical method", which is actually just the correct way of doing the problem.
First things first -- evaluate those integrals! You are going to get a transcendental equation that has at least one obvious solution. I doubt you want that obvious solution; is there another?
  • · Replies 20 ·
9K
