Why Do Argon Atoms in a Toroidal Box Show Unusually Large Positional Values?
In summary, the conversation discusses a problem with calculating the positions of 100 argon atoms in a box using the Verlet method. The issue arises when trying to update the positions to stay within the boundaries of the box. The code uses a torus boundary condition to simplify the calculations. However, when the final positions are outputted, they are outside of the box and have extremely large values. The individual's code is shared and they are seeking assistance in finding the error.
llello
32
So I'm working on a problem where you have 100 argon atoms in a box that obey the Lennard Jones potential. We're using the Verlet method to calculate the position of each particle at the next time step. The issue I'm having has to do with our boundary conditions. We assume that atoms are on a torus, that way we don't have to worry about binging into the walls.
So my problem arises when I try to calculate their positions at a later time. We're coding in Fortran. So the position of the ith particle is x(i), y(i) and its contained in an LxL box. I go through and calculate what the final positions are and then update those positions so that they're still inside the box. Just an fyi, I also have to keep around the old position for the Verlet method to work. The way I do this updating is as follows:
! adjust for torus
if (x(i) .gt. L) then
a = floor(x(i)/L)
x(i) = x(i) - a*L
xold(i) = xold(i) - a*L
endif
if (x(i) .lt. 0.0) then
a = ceiling(x(i)/L)
x(i) = x(i) + a*L
xold(i) = xold(i) + a*L
endif
if (y(i) .gt. L) then
a = floor(y(i)/L)
y(i) = y(i) - a*L
yold(i) = yold(i) - a*L
endif
if (y(i) .lt. 0.0) then
a = ceiling(y(i)/L)
y(i) = y(i) + a*L
endif
Now the length of my box is just 10.0. But for whatever reason, when I output x, y data for the final time, it gives me extremely large values (order of 10^8 and more). Am I oversimplifying the situation when the particle travels from one side of the box to the other or is this the correct way to update it? If it is correct, how is it I can be getting positions on the order of 10^8?
Many thanks to anyone who takes the time to read this.
-Louis-
Shameless bump of thread.
Final shameless bump before abandoning hope for a reply.
It can take more than 94 minutes for an answer.
So I've convinced myself that my updating of positions is valid. However, I am still receiving final positions outside of the box. This is my entire code. Perhaps someone can find the error. Note, I intend to randomize the starting positions and velocities once I get this to actually work.!
! Program to calculate properties of an argon gas
! using the Verlet method in molecular dynamics.
program assn6no1
implicit none
double precision x(100), y(100), velx(100), vely(100), xold(100), yold(100), energy(10000), velcm(10000)
double precision storex(10000,100), storey(10000,100), time(10000), accelx(100), accely(100)
double precision xnew(100), ynew(100)
double precision L, dt, tempx, tempy, loopx, loopy, loopdistance, cmxtemp, cmytemp, cosine, sine
double precision lineardistance, distance, mass, answer, energytemp, xaccel, yaccel
double precision xdistance, ydistance, p, q, r, s
integer N, i, j, k, timesteps, a
! n = number of argon atoms, L = size of box side (10sigma, sigma=1)
N = 100
L = 10.0
dt = 0.005
mass = 1.0
timesteps = 1000
! initial velocities
do i=1, N
velx(i) = 0.0
vely(i) = 0.0
enddo
! Making the initial positions of 100 argon atoms and x/y at time -dt
do j=1, 10
do i=1, 10
x(i+(j-1)*10) = (i+0.0) - 1.0/2.0
y(j+(i-1)*10) = (i+0.0) - 1.0/2.0
enddo
enddo
! Slightly offsetting each position by 1/10*sigma and calculating x/y(0)
do i=1, N
if (mod(i,2) .eq. 1) then
x(i) = x(i) + 1.0/100.0
y(i) = y(i) + 1.0/100.0
else
x(i) = x(i) - 1.0/100.0
y(i) = y(i) - 1.0/100.0
endif
enddo
do i=1, N
xold(i) = x(i) - velx(i)*dt
yold(i) = y(i) - vely(i)*dt
enddo
! begin calculating motion (time loop)
do k=1, timesteps
! Calculate the acceleration, first initialize
do i=1, N
accelx(i) = 0.0
accely(i) = 0.0
enddo
! first loop is for the ith particle's acceleration
do i=1, N
! calculating a from every other particle
xaccel = 0.0
yaccel = 0.0
tempx = 0.0
tempy = 0.0
do j=1, N
! if statement prevents caclulating acceleration from the same particle
if (i .ne. j) then
cosine = minDist(x(i),x(j))/sqrt( minDist( x(i),x(j) )**2 + minDist( y(i),y(j) )**2 )
sine = minDist(y(i),y(j))/sqrt( minDist( x(i),x(j) )**2 + minDist( y(i),y(j) )**2 )
tempx = xaccel + 1.0/mass*force(x(i),x(j),y(i),y(j))*cosine
tempy = yaccel + 1.0/mass*force(x(i),x(j),y(i),y(j))*sine
xaccel = tempx
yaccel = tempy
endif
enddo
accelx(i) = xaccel
accely(i) = yaccel
enddo
! Calculate the new position of ith particle
do i=1, N
! computing new x/y
xnew(i) = 2.0*x(i) - xold(i) + accelx(i)*dt**2
ynew(i) = 2.0*y(i) - yold(i) + accely(i)*dt**2
! compute velcocity before adjusting for torus
velx(i) = (xnew(i) - xold(i))/(2*dt)
vely(i) = (ynew(i) - yold(i))/(2*dt)
enddo
! adjusting each particle for torus boundary
do i=1, N
if (xnew(i) .gt. L) then
a = floor(xnew(i)/L)
xnew(i) = xnew(i) - a*L
x(i) = x(i) - a*L
endif
if (xnew(i) .lt. 0.0) then
a = ceiling(xnew(i)/L)
x(i) = x(i) - a*L
endif
if (ynew(i) .gt. L) then
a = floor(ynew(i)/L)
ynew(i) = ynew(i) - a*L
y(i) = y(i) - a*L
endif
if (ynew(i) .lt. 0.0) then
a = ceiling(ynew(i)/L)
y(i) = y(i) - a*L
endif
enddo
! updates values
do i=1, N
xold(i) = x(i)
x(i) = xnew(i)
enddo
! store time and velocity data
do i=1, N
time(k) = k*dt
storex(k,i) = velx(i)
storey(k,i) = vely(i)
enddo
enddo
! calculating energy as function of time
do k=1, timesteps
energytemp = 0.0
cmxtemp = 0.0
cmytemp = 0.0
do i=1, N
energytemp = energytemp + 1.0/2.0*(velx(i)**2+vely(i)**2)
cmxtemp = cmxtemp + velx(i)
cmytemp = cmytemp + vely(i)
enddo
energy(k) = energytemp
velcm(k) = sqrt(cmxtemp**2 + cmytemp**2)
enddo!
! Outputting data
open (unit=9, file='positionData.txt', access='append', status='new')
do i=1, N
write(9,*) x(i), y(i)
9 continue
enddo
close(unit=9)
contains
! function to calculate the minimum distance on toroid
double precision function minDist(p,q) result(answer)
double precision, intent(in) :: p
double precision, intent(in) :: q
answer = min( abs(p-q),L-abs(p-q) )
end function minDist!
! function to calculate force between ith/jth particles
double precision function force(p,q,r,t) result(answer)
double precision, intent(in) :: r
double precision, intent(in) :: t
xdistance = minDist(p,q)
ydistance = minDist(r,t)
distance = sqrt(xdistance**2 + ydistance**2)
! if particles are too far, make force zero
if (distance .le. 3.0) then
answer = 24.0*(2.0/(distance**13)-1.0/(distance**7))
else
answer = 0.0
endif
end function force
end program
Related to Why Do Argon Atoms in a Toroidal Box Show Unusually Large Positional Values?
1. What is Argon gas in a Box (torus)?
Argon gas in a Box (torus) is a scientific concept that involves confining Argon gas within a torus (a doughnut-shaped structure) for experimental purposes. The gas is usually kept at a high pressure and low temperature to study its properties and behavior.
2. How is Argon gas in a Box (torus) used in scientific experiments?
Argon gas in a Box (torus) is used in various scientific experiments, such as studying plasma physics, nuclear fusion, and materials science. The confined gas allows scientists to control and manipulate its properties, making it an ideal tool for research and experimentation.
3. What are the benefits of using Argon gas in a Box (torus)?
The use of Argon gas in a Box (torus) provides several benefits in scientific experiments. It allows for a controlled environment to study the gas, eliminates external interference, and provides accurate measurements and observations. Additionally, the torus structure allows for long confinement times, making it suitable for studying dynamic processes.
4. What are some potential applications of Argon gas in a Box (torus)?
Argon gas in a Box (torus) has several potential applications in various fields of science and technology. It can be used for developing more efficient nuclear fusion reactors, understanding plasma behavior for space exploration, and improving industrial processes that involve plasma, such as welding and semiconductor production.
5. What are the challenges of working with Argon gas in a Box (torus)?
Working with Argon gas in a Box (torus) comes with several challenges, such as maintaining a high-pressure environment, controlling the temperature, and handling potential hazards associated with working with gas under pressure. Additionally, the cost of building and operating such a facility can be a challenge for smaller research institutions.
  • MATLAB, Maple, Mathematica, LaTeX
