Is the Harmonic Series Diverging with Ars Conjectandi?
  • Thread starter Thread starter Shackleford
    Series
The discussion centers on the harmonic series, denoted as Sn, and its divergence. Participants clarify that Sn represents a finite sum, specifically Sn = 1 + 1/2 + 1/3 + ... + 1/n, which diverges as n approaches infinity. The conversation emphasizes the importance of using partial fraction decomposition to express terms in the series, particularly the transformation of 1/(n(n+1)) into 1/n - 1/(n+1). The final consensus is that the finite sum simplifies to 1 - 1/(n+1) for finite n.
  • Understanding of harmonic series and its notation (Sn).
  • Knowledge of partial fraction decomposition techniques.
  • Familiarity with telescoping series and their properties.
  • Basic calculus concepts, particularly limits and convergence.
  • Study the properties of telescoping series in detail.
  • Learn how to apply partial fraction decomposition to various types of rational functions.
  • Explore the implications of series convergence and divergence in mathematical analysis.
  • Investigate the relationship between finite sums and their limits as n approaches infinity.
Mathematicians, students studying calculus or series, and educators looking to deepen their understanding of series convergence and divergence.
Hint: Expand \frac 1 {n(n+1)} into partial fractions.
1. But the difference between two divergent series is not necessarily divergent or infinite.
2 Actually write stuff out - write out Sn - Sn+1 as series and what does it equal? and write out the term typical term 1/n(n + 1) - how else would you naturally express that?
This should suggest something to you.
Well, I realized that Sn - Sn+1 = S the first series. If I multiply that by 2 I get the sum identity inverse.
So, he's wanting an expression for the finite sum? I suspected it was finite, but I wasn't sure.
Terms would cancel in that difference. The first series is a telescoping series.
It simplifies to 1 - (1/n+1) for some n.
Both of the sums shown in the linked-to image are finite sums.
You don't have the parentheses in the right places. This should be 1 - 1/(n+1).
\frac{1}{n(n + 1)} = ?
Edit (Actually that is what Kurz is saying).
Sooner or later you'll kick yourself.
Yeah, I have 1 - 1/(n+1) on my paper. If you take the limit as n goes to infinity it tends to 1. Since n does not go to infinity, then you have the expression for some finite n.
Based on the photo you uploaded, the question has nothing to do with limits. It could be that this is asked for in the problem itself, but it looks to me like what they're asking you to do is find Sn = 1 + 1/2 + 1/3 + ... + 1/n, which I say again, is a finite sum.
Sn - Sn+1 = 1 - 1/(n+1).
This is incorrect - the left side is negative and the right side is close to 1 (hence positive).
Are you sure about that?
Sn - Sn+1 = (1 + 1/2 + 1/3 + ... + 1/n) - (1/2 + 1/3 + ... + 1/n + 1(n+1)) = 1 - 1/(n+1).
If I write this in partial fractions I get
1 = A(n+1) + Bn
If I continue, I don't get a nice expression.
Yes.
The expression you have for Sn+1 is wrong because it is missing a term. Sn is a sum of n terms, while Sn+1 is a sum of n + 1 terms. Sn - Sn+1 < 0.
1 = A(n+1) + Bn
The equation above is an identity that must be true for all n. That means that the polynomial on the left has to be identically equal to the one on the right.
Grouping by powers of n gives
1 = (A + B)n + A
More suggestively, this is
0n + 1 = (A + B)n + A
Mark44 said:
Yes.
I'm interpreting it differently. Why is it not the following?
sum of (1/k) from k = 1 to k = n
sum of (1/k+1) from k = 1 to k = n
1 = (A + B)n + A
I haven't worked partial fractions in a while. I reworked and got 1 = A and -1 = B.
According to what you're saying,
Sn - Sn+1 = (1 + 1/2 + 1/3 + ... + 1/n) - (1 + 1/2 + 1/3 + ... + 1/n + 1(n+1)) = -1/(n+1).
Yes, that's better. Now, do you understand how all this ties into the real problem?
Namely, finding the sum
\frac{1}{1 \cdot 2} + \frac{2}{2 \cdot 3} + \frac{3}{3 \cdot 4} + ... + \frac{n}{n \cdot (n + 1)}
The whole business of partial fraction decomposition is intended to help you rewrite the individual terms in the sum above.
Maybe.
S = 2Sn - Sn+1
Shackleford said:
Maybe.
S = 2Sn - Sn+1
How are you getting this?
I worked this problem using the suggested hint and have something completely different for S.
One thing that bothers about the problem statement is their confusing use of S and Sn to represent unrelated things. For example, in the problem it is given that
S = \frac{1}{1 \cdot 2} + \frac{2}{2 \cdot 3} + \frac{3}{3 \cdot 4} + ... + \frac{n}{n \cdot (n + 1)}
Later on, they have Sn = 1 + 1/2 + 1/3 + ... + 1/n. For this latter sum, they should have used a different letter altogether, maybe Hn.
Well, maybe that's my fault. I'm calling that S. The problem just gives the series. It doesn't call it S or anything.
Here's how I got that expression up there. You should be able enlarge it.
http://i111.photobucket.com/albums/n149/camarolt4z28/IMG_20111105_142452.jpg
Then lets' not give names to 1 + 1/2 + ... + 1/n and 1 + 1/2 + ... + 1/n + 1/(n+1). And let's reserve Sn to mean the first n terms of the original sum. IOW,
S_n = \frac{1}{1 \cdot 2} + \frac{2}{2 \cdot 3} + \frac{3}{3 \cdot 4} + ... + \frac{n}{n \cdot (n + 1)}
As I see it, you aren't making the connection between the partial fractions business and the terms in this series. The partial fractions decomposition you did says that 1/(n(n+1)) = 1/n - 1/(n + 1).
Apply this formula to each term in the sum above to get a formula for Sn
Your Sn is different than their first series. You can express your Sn as sum of n[(1/n) - 1/(n+1)] from 1 to n.
This thread has gotten so bollixed up I can't tell whether Shackleford has solved the problem or not. The original sum was
\sum_{k=1}^n \frac 1 {k(k+1)} = \sum_{k=1}^n \left(\frac 1 {k}-\frac 1 {1+k}\right)
Just write that out and cancel what you can and it's done.
That's the sum I interpreted initially.
You get 1 - 1/(n+1), right?
And using partial fractions you show that the above equals the desired series.
Yes. Partial fractions is how you express the single fraction as the difference of those two fractions.
so, is Sn-Sn+1 supposed to equal 1/n - 1/(n+1)? So, that you then get Sn-Sn+1 = to 1/(n(n+1))?
