Assistance finding the nuclear energy difference during nuclear fusion
5 replies · 3K views
TechmoUnity
TL;DR
I need to know how to calculate the difference in energy during nuclear fusion so I can figure out the energy release from it. However, there is no-where that seems to explain where the formulas for that get their numbers from
Hello!
I have finished high school quite a few years ago. I did a physics course that went over nuclear fusion and fission, and I quite enjoyed it. However, I unfortunately no longer have those textbooks (I sold them on as many people do). Now I am doing a bit of programming in the field of nuclear physics for a bit of fun at home, and I've realized that I've forgotten how to calculate the energy release of a fusion reaction.
Upon looking into it on google, a lot of people point out that:
- 1U = 1.661 * 10^(-27)
- Alpha particle mass (Helium) = 4.0026U
- Proton mass = 1.0072U
- Neutron mass = 1.0084U
I understand that to get the energy of, for example, helium would be calculated by doing:
2 * 1.0072 + 2 * 1.0084 = 4.0312U
Now just take the difference between the calculated energy (4.0312U) and the given energy (4.0026U) and you get out 0.0286U, which turns out to be 26.641MeV energy difference. From here, I can do the same for hydrogen fusing into helium to calculate the difference in energy to figure out the net release of energy.
Now that's all fine. The question however, is this number: "4.0026U" for the alpha particle. How is this found? Is it something I can calculate with the number of protons and neutrons in a nucleus alone? I'm presuming something about the distances between the protons and neutrons involving the strong nuclear force would be involved, but is there actually a way to calculate that given only information like the number of proton/neutrons in an atomic nucleus, the mass/energy of a proton, and the mass/energy of a neutron?
I'm trying to create a coding library that handles all this, but I don't want to have a massive index of every single possible variation of an atom with varying numbers of neutrons. I want to be able to throw it in a function and have it spit out that original "4.0026U" or even "6.64832 * 10^(-27) Kg". I don't mind if the equation ends up being very large and complicated (With nuclear physics like this, I kinda expect it to be). I just want to know if this is something that can be calculated on the fly. For example, if I throw in uranium 214, I want to know what the expected energy of that would be so that I can calculate the energy loss when it splits WITHOUT the need for searching through a multi-hundred megabyte list of information to find uranium 214.
The trouble is that I keep running in circles. Everything that shows me how to calculate an atoms nucleus binding energy result in the formula:
B = (Mn + Mp - Mo)*c
Where Mn is the mass of neutrons, Mp is the mass of protons, Mo is the observed mass, and c is obviously the speed of light. The issue is the Mo. How do we get that? Is there a way to calculate it without needing to experimentally measure it and put it in a massive array of data?
Any help would be greatly appreciated, as I am completely stumped by this point. All my research in this matter just runs me in circles, and google really isn't helping, as any attempts to look it up either produce that formula for binding energy, or it gives me back calculating atomic mass, which really isn't what I'm after.
Kind regards,
Andrey
I do not believe there is any way to calculate the data.
You will need an isotope table with the mass numbers for each isotope.
It will not be a "multi-hundred megabyte list" that needs searching.
It will be an array of data indexed by N and Z.
Darn, I was hoping there was a way to calculate it. Ah well thankyou so much anyways. Is there anywhere you would recommend for getting the isotope energy data? I could just use wikipedia and go through each isotope one by one, but I would prefer a more credible source if you know one off the top of your head?
If you want a full table look for something like; NUCLEAR SCIENCE REFERENCES CODING MANUAL. S. Ramavataram and C.L. Dunford. August 1996.
If you just want the stable isotopes, the table can be much smaller. Try this to begin with.
[CODE title="Stable isotopes"]
' Z Name Symbol Mass of Atom(u) % Abundance
Data "1", "Hydrogen"
Data "1H", 1.007825, 99.9885
Data "2H", 2.014102, 0.0115
Data "3H", 3.016049, 0.0
Data "2", "Helium"
Data "3He", 3.016029, 0.000137
Data "4He", 4.002603, 99.999863
Data "3", "Lithium"
Data "6Li", 6.015122, 7.59
Data "7Li", 7.016004, 92.41
Data "4", "Beryllium"
Data "9Be", 9.012182, 100
Data "5", "Boron"
Data "10B", 10.012937, 19.9
Data "11B", 11.009305, 80.1
Data "6", "Carbon"
Data "12C", 12.000000, 98.93
Data "13C", 13.003355, 1.07
Data "14C", 14.003242, 0.0
Data "7", "Nitrogen"
Data "14N", 14.003074, 99.632
Data "15N", 15.000109, 0.368
Data "8", "Oxygen"
Data "16O", 15.994915, 99.757
Data "17O", 16.999132, 0.038
Data "18O", 17.999160, 0.205
Data "9", "Fluorine"
Data "19F", 18.998403, 100
Data "10", "Neon"
Data "20Ne", 19.992440, 90.48
Data "21Ne", 20.993847, 0.27
Data "22Ne", 21.991386, 9.25
Data "11", "Sodium"
Data "23Na", 22.989770, 100
Data "12", "Magnesium"
Data "24Mg", 23.985042, 78.99
Data "25Mg", 24.985837, 10.00
Data "26Mg", 25.982593, 11.01
Data "13", "Aluminum"
Data "27Al", 26.981538, 100
Data "14", "Silicon"
Data "28Si", 27.976927, 92.2297
Data "29Si", 28.976495, 4.6832
Data "30Si", 29.973770, 3.0872
Data "15", "Phosphorus"
Data "31P", 30.973762, 100
Data "16", "Sulphur"
Data "32S", 31.972071, 94.93
Data "33S", 32.971458, 0.76
Data "34S", 33.967867, 4.29
Data "36S", 35.967081, 0.02
Data "17", "Chlorine"
Data "35Cl", 34.968853, 75.78
Data "37Cl", 36.965903, 24.22
Data "18", "Argon"
Data "36Ar", 35.967546, 0.3365
Data "38Ar", 37.962732, 0.0632
Data "40Ar", 39.962383, 99.6003
Data "19", "Potassium"
Data "39K", 38.963707, 93.2581
Data "40K", 39.963999, 0.0117
Data "41K", 40.961826, 6.7302
Data "20", "Calcium"
Data "40Ca", 39.962591, 96.941
Data "42Ca", 41.958618, 0.647
Data "43Ca", 42.958767, 0.135
Data "44Ca", 43.955481, 2.086
Data "46Ca", 45.953693, 0.004
Data "48Ca", 47.952534, 0.187
Data "21", "Scandium"
Data "45Sc", 44.955910, 100
Data "22", "Titanium"
Data "46Ti", 45.952629, 8.25
Data "47Ti", 46.951764, 7.44
Data "48Ti", 47.947947, 73.72
Data "49Ti", 48.947871, 5.41
Data "50Ti", 49.944792, 5.18
Data "23", "Vanadium"
Data "50V", 49.947163, 0.250
Data "51V", 50.943964, 99.750
Data "24", "Chromium"
Data "50Cr", 49.946050, 4.345
Data "52Cr", 51.940512, 83.789
Data "53Cr", 52.940654, 9.501
Data "54Cr", 53.938885, 2.365
Data "25", "Manganese"
Data "55Mn", 54.938050, 100
Data "26", "Iron"
Data "54Fe", 53.939615, 5.845
Data "56Fe", 55.934942, 91.754
Data "57Fe", 56.935399, 2.119
Data "58Fe", 57.933280, 0.282
Data "27", "Cobalt"
Data "59Co", 58.933200, 100
Data "28", "Nickel"
Data "58Ni", 57.935348, 68.0769
Data "60Ni", 59.930791, 26.2231
Data "61Ni", 60.931060, 1.1399
Data "62Ni", 61.928349, 3.6345
Data "64Ni", 63.927970, 0.9256
Data "29", "Copper"
Data "63Cu", 62.929601, 69.17
Data "65Cu", 64.927794, 30.83
Data "30", "Zinc"
Data "64Zn", 63.929147, 48.63
Data "66Zn", 65.926037, 27.90
Data "67Zn", 66.927131, 4.10
Data "68Zn", 67.924848, 18.75
Data "70Zn", 69.925325, 0.62
Data "31", "Gallium"
Data "69Ga", 68.925581, 60.108
Data "71Ga", 70.924705, 39.892
Data "32", "Germanium"
Data "70Ge", 69.924250, 20.84
Data "72Ge", 71.922076, 27.54
Data "73Ge", 72.923459, 7.73
Data "74Ge", 73.921178, 36.28
Data "76Ge", 75.921403, 7.61
Data "33", "Arsenic"
Data "75As", 74.921596, 100
Data "34", "Selenium"
Data "74Se", 73.922477, 0.89
Data "76Se", 75.919214, 9.37
Data "77Se", 76.919915, 7.63
Data "78Se", 77.917310, 23.77
Data "80Se", 79.916522, 49.61
Data "82Se", 81.916700, 8.73
Data "35", "Bromine"
Data "79Br", 78.918338, 50.69
Data "81Br", 80.916291, 49.31
Data "36", "Krypton"
Data "78Kr", 77.920386, 0.35
Data "80Kr", 79.916378, 2.28
Data "82Kr", 81.913485, 11.58
Data "83Kr", 82.914136, 11.49
Data "84Kr", 83.911507, 57.00
Data "86Kr", 85.910610, 17.30
Data "37", "Rubidium"
Data "85Rb", 84.911789, 72.17
Data "87Rb", 86.909183, 27.83
Data "38", "Strontium"
Data "84Sr", 83.913425, 0.56
Data "86Sr", 85.909262, 9.86
Data "87Sr", 86.908879, 7.00
Data "88Sr", 87.905614, 82.58
Data "39", "Yttrium"
Data "89Y", 88.905848, 100
Data "40", "Zirconium"
Data "90Zr", 89.904704, 51.45
Data "91Zr", 90.905645, 11.22
Data "92Zr", 91.905040, 17.15
Data "94Zr", 93.906316, 17.38
Data "96Zr", 95.908276, 2.80
Data "41", "Niobium"
Data "93Nb", 92.906378, 100
Data "42", "Molybdenum"
Data "92Mo", 91.906810, 14.84
Data "94Mo", 93.905088, 9.25
Data "95Mo", 94.905841, 15.92
Data "96Mo", 95.904679, 16.68
Data "97Mo", 96.906021, 9.55
Data "98Mo", 97.905408, 24.13
Data "100Mo", 99.907477, 9.63
Data "43", "Technetium"
Data "98Tc", 97.907216, 100
Data "44", "Ruthenium"
Data "96Ru", 95.907598, 5.54
Data "98Ru", 97.905287, 1.87
Data "99Ru", 98.905939, 12.76
Data "100Ru", 99.904220, 12.60
Data "101Ru", 100.905582, 17.06
Data "102Ru", 101.904350, 31.55
Data "104Ru", 103.905430, 18.62
Data "45", "Rhodium"
Data "103Rh", 102.905504, 100
Data "46", "Palladium"
Data "102Pd", 101.905608, 1.02
Data "104Pd", 103.904035, 11.14
Data "105Pd", 104.905084, 22.33
Data "106Pd", 105.903483, 27.33
Data "108Pd", 107.903894, 26.46
Data "110Pd", 109.905152, 11.72
Data "47", "Silver"
Data "107Ag", 106.905093, 51.839
Data "109Ag", 108.904756, 48.161
Data "48", "Cadmium"
Data "106Cd", 105.906458, 1.25
Data "108Cd", 107.904183, 0.89
Data "110Cd", 109.903006, 12.49
Data "111Cd", 110.904182, 12.80
Data "112Cd", 111.902757, 24.13
Data "113Cd", 112.904401, 12.22
Data "114Cd", 113.903358, 28.73
Data "116Cd", 115.904755, 7.49
Data "49", "Indium"
Data "113In", 112.904061, 4.29
Data "115In", 114.903878, 95.71
Data "50", "Tin"
Data "112Sn", 111.904821, 0.97
Data "114Sn", 113.902782, 0.66
Data "115Sn", 114.903346, 0.34
Data "116Sn", 115.901744, 14.54
Data "117Sn", 116.902954, 7.68
Data "118Sn", 117.901606, 24.22
Data "119Sn", 118.903309, 8.59
Data "120Sn", 119.902197, 32.58
Data "122Sn", 121.903440, 4.63
Data "124Sn", 123.905275, 5.79
Data "51", "Antimony"
Data "121Sb", 120.903818, 57.21
Data "123Sb", 122.904216, 42.79
Data "52", "Tellurium"
Data "120Te", 119.904020, 0.09
Data "122Te", 121.903047, 2.55
Data "123Te", 122.904273, 0.89
Data "124Te", 123.902819, 4.74
Data "125Te", 124.904425, 7.07
Data "126Te", 125.903306, 18.84
Data "128Te", 127.904461, 31.74
Data "130Te", 129.906223, 34.08
Data "53", "Iodine"
Data "127I", 126.904468, 100
Data "54", "Xenon"
Data "124Xe", 123.905896, 0.09
Data "126Xe", 125.904269, 0.09
Data "128Xe", 127.903530, 1.92
Data "129Xe", 128.904779, 26.44
Data "130Xe", 129.903508, 4.08
Data "131Xe", 130.905082, 21.18
Data "132Xe", 131.904154, 26.89
Data "134Xe", 133.905395, 10.44
Data "136Xe", 135.907220, 8.87
Data "55", "Cesium"
Data "133Cs", 132.905447, 100
Data "56", "Barium"
Data "130Ba", 129.906310, 0.106
Data "132Ba", 131.905056, 0.101
Data "134Ba", 133.904503, 2.417
Data "135Ba", 134.905683, 6.592
Data "136Ba", 135.904570, 7.854
Data "137Ba", 136.905821, 11.232
Data "138Ba", 137.905241, 71.698
Data "57", "Lanthanum"
Data "138La", 137.907107, 0.090
Data "139La", 138.906348, 99.910
Data "58", "Cerium"
Data "136Ce", 135.907144, 0.185
Data "138Ce", 137.905986, 0.251
Data "140Ce", 139.905434, 88.450
Data "142Ce", 141.909240, 11.114
Data "59", "Praseodymium"
Data "141Pr", 140.907648, 100
Data "60", "Neodymium"
Data "142Nd", 141.907719, 27.2
Data "143Nd", 142.909810, 12.2
Data "144Nd", 143.910083, 23.8
Data "145Nd", 144.912569, 8.3
Data "146Nd", 145.913112, 17.2
Data "148Nd", 147.916889, 5.7
Data "150Nd", 149.920887, 5.6
Data "61", "Promethium"
Data "145Pm", 144.912744, 100
Data "62", "Samarium"
Data "144Sm", 143.911995, 3.07
Data "147Sm", 146.914893, 14.99
Data "148Sm", 147.914818, 11.24
Data "149Sm", 148.917180, 13.82
Data "150Sm", 149.917271, 7.38
Data "152Sm", 151.919728, 26.75
Data "154Sm", 153.922205, 22.75
Data "63", "Europium"
Data "151Eu", 150.919846, 47.81
Data "153Eu", 152.921226, 52.19
Data "64", "Gadolinium"
Data "152Gd", 151.919788, 0.20
Data "154Gd", 153.920862, 2.18
Data "155Gd", 154.922619, 14.80
Data "156Gd", 155.922120, 20.47
Data "157Gd", 156.923957, 15.65
Data "158Gd", 157.924101, 24.84
Data "160Gd", 159.927051, 21.86
Data "65", "Terbium"
Data "159Tb", 158.925343, 100
Data "66", "Dysprosium"
Data "156Dy", 155.924278, 0.06
Data "158Dy", 157.924405, 0.10
Data "160Dy", 159.925194, 2.34
Data "161Dy", 160.926930, 18.91
Data "162Dy", 161.926795, 25.51
Data "163Dy", 162.928728, 24.90
Data "164Dy", 163.929171, 28.18
Data "67", "Holmium"
Data "165Ho", 164.930319, 100
Data "68", "Erbium"
Data "162Er", 161.928775, 0.14
Data "164Er", 163.929197, 1.61
Data "166Er", 165.930290, 33.61
Data "167Er", 166.932045, 22.93
Data "168Er", 167.932368, 26.78
Data "170Er", 169.935460, 14.93
Data "69", "Thulium"
Data "169Tm", 168.934211, 100
Data "70", "Ytterbium"
Data "168Yb", 167.933894, 0.13
Data "170Yb", 169.934759, 3.04
Data "171Yb", 170.936322, 14.28
Data "172Yb", 171.936378, 21.83
Data "173Yb", 172.938207, 16.13
Data "174Yb", 173.938858, 31.83
Data "176Yb", 175.942568, 12.76
Data "71", "Lutetium"
Data "175Lu", 174.940768, 97.41
Data "176Lu", 175.942682, 2.59
Data "72", "Hafnium"
Data "174Hf", 173.940040, 0.16
Data "176Hf", 175.941402, 5.26
Data "177Hf", 176.943220, 18.60
Data "178Hf", 177.943698, 27.28
Data "179Hf", 178.945815, 13.62
Data "180Hf", 179.946549, 35.08
Data "73", "Tantalum"
Data "180Ta", 179.947466, 0.012
Data "181Ta", 180.947996, 99.988
Data "74", "Tungsten"
Data "180W", 179.946706, 0.12
Data "182W", 181.948206, 26.50
Data "183W", 182.950224, 14.31
Data "184W", 183.950933, 30.64
Data "186W", 185.954362, 28.43
Data "75", "Rhenium"
Data "185Re", 184.952956, 37.40
Data "187Re", 186.955751, 62.60
Data "76", "Osmium"
Data "184Os", 183.952491, 0.02
Data "186Os", 185.953838, 1.59
Data "187Os", 186.955748, 1.96
Data "188Os", 187.955836, 13.24
Data "189Os", 188.958145, 16.15
Data "190Os", 189.958445, 26.26
Data "192Os", 191.961479, 40.78
Data "77", "Iridium"
Data "191Ir", 190.960591, 37.3
Data "193Ir", 192.962924, 62.7
Data "78", "Platinum"
Data "190Pt", 189.959930, 0.014
Data "192Pt", 191.961035, 0.782
Data "194Pt", 193.962664, 32.967
Data "195Pt", 194.964774, 33.832
Data "196Pt", 195.964935, 25.242
Data "198Pt", 197.967876, 7.163
Data "79", "Gold"
Data "197Au", 196.966552, 100
Data "80", "Mercury"
Data "196Hg", 195.965815, 0.15
Data "198Hg", 197.966752, 9.97
Data "199Hg", 198.968262, 16.87
Data "200Hg", 199.968309, 23.10
Data "201Hg", 200.970285, 13.18
Data "202Hg", 201.970626, 29.86
Data "204Hg", 203.973476, 6.87
Data "81", "Thallium"
Data "203Tl", 202.972329, 29.524
Data "205Tl", 204.974412, 70.476
Data "82", "Lead"
Data "204Pb", 203.973029, 1.4
Data "206Pb", 205.974449, 24.1
Data "207Pb", 206.975881, 22.1
Data "208Pb", 207.976636, 52.4
Data "83", "Bismuth"
Data "209Bi", 208.980383, 100
Data "84", "Polonium"
Data "209Po", 208.982416, 100
Data "85", "Astatine"
Data "210At", 209.987131, 100
Data "86", "Radon"
Data "222Rn", 222.017570, 100
Data "87", "Francium"
Data "223Fr", 223.019731, 100
Data "88", "Radium"
Data "226Ra", 226.025403, 100
Data "89", "Actinium"
Data "227Ac", 227.027747, 100
Data "90", "Thorium"
Data "232Th", 232.038050, 100
Data "91", "Protactinium"
Data "231Pa", 231.035879, 100
Data "92", "Uranium"
Data "234U", 234.040946, 0.0055
Data "235U", 235.043923, 0.7200
Data "238U", 238.050783, 99.2745
Data "" ' end of data
[/CODE]
Data "2", "Helium"
Data "3", "Lithium"
Data "5", "Boron"
Data "6", "Carbon"
Data "8", "Oxygen"
Data "10", "Neon"
Data "11", "Sodium"
Data "18", "Argon"
Data "26", "Iron"
Data "27", "Cobalt"
Data "28", "Nickel"
Data "29", "Copper"
Data "30", "Zinc"
Data "47", "Silver"
Data "49", "Indium"
Data "50", "Tin"
Data "53", "Iodine"
Data "54", "Xenon"
Data "55", "Cesium"
Data "56", "Barium"
Data "58", "Cerium"
Data "68", "Erbium"
Data "76", "Osmium"
Data "79", "Gold"
Data "82", "Lead"
Data "86", "Radon"
Data "88", "Radium"
[/CODE]
Thankyou thankyou THANKYOU! That is absolutely perfect, and exactly the backup plan I was after! I cannot thankyou enough! You have perfectly solved my problem. You have yourself a wonderful day/afternoon/night!
