e-zero
- 58
I have a question which states that a car's speed is 110km/h. Should I assume this speed to be 3 significant figures or 4 significant figures? why??
The discussion centers on the interpretation of significant figures in the context of a car's speed of 110 km/h. Participants conclude that 110 km/h should be considered as having 3 significant figures, primarily due to the ambiguity of the trailing zero. The conversation highlights the importance of significant figures in conveying measurement accuracy, with a consensus that while significant figures are crucial, they can sometimes lead to confusion and misinterpretation in practical applications. The need for clarity in reporting measurements and the potential pitfalls of over-relying on significant figures are emphasized.
PREREQUISITESStudents and professionals in physics, chemistry, and engineering who require a solid understanding of significant figures for accurate measurement reporting and data analysis.
Borek said:I was always under impression that in most physics courses nobody cares about sig figs, they are treated seriously only by chemists (and even then not by all).
technician said:They are treated as a means of assessing and conveying accuracy but it would be laborious if every example had to have this error analysis applied.
e-zero said:Would you equate that to 3 significant digits or 1? I am suggesting 1 because the numerator & denominator of the fraction 1/2 are both composed of 1 significant digit.
e-zero said:How about this example: 130km / 95km/h
Would your answer be 1.37h or 1.4h?
AlephZero said:If you want to estimate the error in the answer, then do it properly.
"Counting significant figures" is such a crude method as to be no real practical use. If the answer happens to be 99, then to 2 significant figures you have an error of about 1%. If it happens to be 101, to 2 s.f. you have an error of about 10%. If you think that makes any sense, then carry on counting significant figures...
Edit: I started typing this before jtbell's post appeared.
e-zero said:I'm still a little confused. How about 65 * 1.96
What would you state that answer as?
technician said:101 is not given to 2 significant figures, it is 3. 101 means you know it is not 100 and it is not 102.
about 1% variation.
The problem arises when a value of 100 is quoted I would say
technician said:65 x 1.96 this could represent the length of a steel bar and the width of the steel bar. If you are required to calculate the area then only 2 figures should be used because the 65 could be a value anywhere between 64 and 66 whereas the 1.96 could be any value between 1.95 and 1.97.
technician said:The whole idea of significant figures is to do with reporting measurements which must have some degree of uncertainty about them.
technician said:Do you have any advice about sig figs that is constructive?
Do you know how the use of sig figs is taught in schools?
e-zero said:Let me use an example to see opinion: ½(23.1 cm3 − 20.32 cm3 + 19.0 cm3)
tiny-tim said:that's addition (and subtraction), so you don't use significant figures anyway, you use decimal places …
you use the highest decimal place of the given numbers, in this case one decimal place after the decimal point
then you divide by 2 which is exact (ie a million billion trillion sig figs)![]()
e-zero said:½(23.1 cm3 − 20.32 cm3 + 19.0 cm3) * 6cm3
then you would have to round to 1 significant figure.
correct?
