Astronomy in a Simple Solar System
The discussion revolves around the question of how one might demonstrate that the Earth orbits the Sun in a simplified solar system scenario, particularly one without other celestial bodies. Participants explore various methods, including parallax and observational techniques, while considering the implications of modern technology on such demonstrations.
  • Some participants suggest that parallax could be used to demonstrate the Earth's orbit around the Sun, comparing it to the apparent motion of nearby streetlamps against distant hills.
  • Others propose that the phases of Venus and Mercury, as well as the motion of stars, could serve as evidence for a heliocentric model, while noting that the outer planets do not exhibit similar phases.
  • A participant questions whether parallax is necessary, arguing that the changing positions of stars each night could indicate the Earth's motion relative to the Sun.
  • There is a discussion about the limitations of observations that a child might make, with some suggesting that modern technology could facilitate easier demonstrations.
  • One participant emphasizes that the heliocentric model simplifies the explanation of planetary motions compared to a geocentric model.
  • Another participant mentions that sophisticated scientific instrumentation is necessary for accurate measurements of parallax.
Participants express a range of views on the methods for demonstrating the Earth's orbit around the Sun, with no consensus on a single approach. Some agree on the utility of parallax, while others question its necessity and explore alternative observations.
Participants acknowledge the complexity of the required observations and the dependence on technology, as well as the speculative nature of some scenarios discussed.
  • #61
hmmm27 said:
Even if there were no other celestial bodies hanging about to make it "easy", all you need to immediately shoot down " The Sun orbits the Earth once a day" , and establish declination and 1yr orbital period, is a gimballed gyroscope.
The axiom for daily rotation is that the Sun appears to move around the Earth each 24 hour day, however, the axiom for orbital motion is that the Sun appears to move through the constellations every 365 1/4 days. It is known as the periodic times argument where the motion of the Sun between the orbital periods of Mars and Venus was switched with the orbital motion of the Earth -
" The 10th argument, taken from the periodic times, is as follows; the apparent movement of the Sun has 365 days which is the mean measure between Venus' period of 225 days and Mars' period of 687 days. Therefore does not the nature of things shout out loud that the circuits in which those 365 days are taken up has a mean position between the circuits of Mars and Venus around the Sun and thus this is not the circuit of the Sun around the Earth -for none of the primary planets has its orbit arranged around the Earth, but the circuit of the Earth around the resting Sun " Kepler
There is no equivalency between the Sun orbiting the Earth each day and the Earth orbiting the Sun and that is a really significant point that needs dealing with. Delighted to see nobody has gone into defensive mode as nothing is served by retaining deficient perspectives.
Astronomy news on Phys.org
  • #62
saddlestone-man said:
A simple experiment that a child could conduct would be to estimate the brightness of Venus over say 18 months.
I don't think so. When Venus is closest it is a crescent and when Venus is farthest it is full. This partially compensates so the variation of only about a factor of 2 in intensity (0.7 in magnitude), and not the factor of 47 you seem to be suggesting.
There is also not much it can be compared with - there are few constant sources of similar magnitude.
  • #63
It shows its fully dark hemisphere to our view as it passes between the stationary Sun and our slow-moving planet
  • #64
I didn't mention equivalency : just getting the easy ones out of the way, first.
Were one to construct all the possible planet-centric maps of the solar system using plain old observational data, the only one which wouldn't look like the result of a drug-fuelled spirograph party is the Sol-centric one : the only one with all circular orbits. For the others, the only circular orbit is the Sun... which would be a clue.
(I'm a bit confused as to why anybody's going to get "defensive" about this sort of thing.)
  • #65
russ_watters said:
By understanding gravity -- they obit their common center of mass.
I think that could be putting the cart before the horse for a Science that's starting from scratch. The laws of gravity would only be found from astronomical observations. It was Kepler's observations that helped there. The local measurements of G, with observations of pendulums near a mountain and the attraction between massive balls were made a lot later. I guess we could have waited for that - and then come to the conclusion that we orbit a common Centre of Mass. Definitely the hard way round, though.
Ibix said:
Telescopes on opposite sides of the Earth thus see slightly different star positions
Star parallax is pretty hard to observe, even with a baseline of 2 AU (Astronomical Units) when observations are taken six months apart along our solar orbit.. A baseline within the Earth's sphere would be asking rather a lot. (Search for Parsec meaning.)
  • #66
Ibix said:
but better kit is required.
It certainly is. I saw a very tired and fuzzy parallax image on a photographic plate once (the only one I ever saw, aamof). Even images to show it from good home equipment require a fair bit of care. I'm surprised there are not more of them about though. There are PetaBytes of amateur astro images.
  • #67
How actually WAS Earth moving proved officially?
So Brahe believed that Sun moved around Earth and planets around Sun, because Earth "of course" was stationary and we had reliable information that Sun moved around Earth (a God had told us). Kepler argued that there was little reason for Sun to move around Earth if planets did not... and Galilei believed Kepler. And was convicted for stating as much, in 1633.
A Murillo painting dated 1643...1645 shows that the anecdote "E pur si muove" already circulated in some form.
So, first, when was Earth moving accepted officially? Since when was a respectable intellectual, such as a priest or a monk, going to be upbraided and ridiculed for believing Sun to move around Earth, by his official superiors (bishops and abbots) everywhere - Poland or Portugal, Italy or Philippines?
And secondly, what arguments persuaded bishops in "E pur si muove", seeing how Kepler did not?
  • #68
With the introduction of Relativity (Newtonian), there was nothing to 'prove'. A heliocentric universe is just an easier way of looking at things. But no one now imagines the Sun is at the centre of the Universe so, apart from historical interest, none of it's very relevant.
Talking of relativity. When modern day Astronomers and Navigators look at the sky for information, they frequently 'freeze' the Earth and effectilvely go back to a Geocentric ( and geostationary referenced) Universe.
  • #69
This judgement has been reversed on 31th October 1992. That's the date when the Vatican officially accepted Earth moving.
  • #70
This thread seems to have lost direction and control. If we are trying to invent a system that doesn’t involve the planets then why are they being discussed in such depth? You can’t have a debate with your fingers crossed and hands behind your back.
Stars ok. Planets not ok. Also stick to other rules such as the necessity of very accurate timekeeping when you can’t see the star Sun parallax directly. The whole world of Science needs to be modified in order to work strictly to this model.
  • #71
oriel36 said:
Let's face it, the easiest way to determine that the Earth orbits the Sun is to appreciate that the stars will transition from left to right of the central/stationary Sun and parallel to the orbital plane. I personally feel that it is from the most unappreciated satellite out there.
The stars in the region of space known as the constellation Scorpius are now transitioning to the right of the central Sun due to the orbital motion of the Earth just as anyone who drives around a traffic circle will see background objects change position from one side of the roundabout to the other as the car travels/orbits the centre.
https://sol24.net/data/html/SOHO/C3/96H/VIDEO/
https://theskylive.com/planetarium
The old geocentric astronomers marked the transition of the stars from an evening to morning appearance as heliacal risings but, with a satellite out there free of daily rotational influences, that transition can now be described in heliocentric or Sun-centred perspectives as the Earth's orbital motion is responsible for that transition.
It is a matter of a more expansive view so try not to be caught between two stools.
  • #72
Without an appreciation of Gravity, what’s to say the stars don’t go round us but just at a different rate from the Sun? When the Earth is clearly the largest and most important body then why challenge that model?
Partial ignorance is not too hard to mimic but total ignorance is pretty much impossible.
  • #73
As the originator of the thread, I was happy to let it diverge and drift to some extent (don't most threads on most Forums?) as all the contributions were constructive and interesting.
I modified the question halfway through the thread's life to something like "if you now allow all the planets to exist, is there a simple experiment a child could conduct which would prove that the Sun is at the centre of the Solar System, and not the Earth". Bearing in mind the computing power, almost instantaneous worldwide voice and data communication, GPS receivers at our fingertips, reasonable quality cameras built into our phones, etc, we have today, I thought that a child has considerably more resource at his/her fingertips than any scientist in the past.
The conclusion so far seems to be that "no, there is no such experiment".
  • #74
Historically, the European discovery of heliocentricity was a result of astrological activity. Before Newton both "sciences" evolved parallelly. In astrology there was some incosistency impossible to solve in geocentric model. Because of Christianity rule, open discussion of these problems was impossible (astrology was forbidden officially, but in reality practicized under rich feodals shield). The most strinking problem was "retrograde movement of planets", now called "pseudo-reversal of their course". We know that it results from changing wiewpoint because of simultaneous movements of Earth and other planets. In geocentric model Earth stands in place and retrogradation is impossible.
Of course, early astronomers registered positions of all visible planets (fast moving objects) and stars (slow moving objects). By digital simulations it was simple to prove that stars have one-day period of movement, and return to previous position. Cycles of planets was more complex, as they do not return to the same position next day. Correlation of digital coefficients describing movements of celestial objects fits quite well to heliocentric model and not geocentric-at all.
Of course this was discovered before Copernicus, but early European astronomers lived relatively nearby to Inquisition centers, and Copernicus relatively far, in northern Poland. He had also powerful protection of Polish kings from Jagiellonian dynasty. So, after publishing its theory, the Vaticane preferred to ignore it and prosecute followers of Copernicus in italy.
Galileo, Kepler and other Renaissance astronomers have had "perspectives", which makes impossible for honest observer to support geocentric theory. Relatively slow changing details on Moon and planets surfaces made possible identifications of their movements without correlations.
These astronomers and astrologs were not scientists, rather the crafsmans of instruments and ideas. Astronomic observations were important for sailors, astrology was behind many political decisions. So, the consequences of error might be hard. Both disciplines calculate future positions of stars and planets: to accurately fins sailor's position on ocean and to find best day for many human activities. Details of calculation were hidden as the intellectual properties of "scientists", but some informations about such activity were written. In both disciplines gravity was unimportant, so mechanical dynamics was not needed. The results of calculations and observations were only positions of stars and planets. The science of astronomy starts from Newton, his predecessors were generally craftsmans, not scientists. Nota bene, Newton was astrologer, too.
Regards,
zbikraw
  • #75
Some things are made easier with modern technology, like you say. For example, an experiment to disprove the flat Earth is pretty much trivial with modern communication technology. It makes long distance coordination quite straightforward, and quite crude measurements with a wide geographic spread are good enough.
The problem with heliocentric versus geocentric models is that the differences are only detectable on longer timescales. Those measurements are possible for a sufficiently committed amateur to make, but aren't made much easier by modern technology. The only thing I think you could do is a cheap and cheerful simulation to show that you expect both prograde and retrograde motion given a heliocentric model (and ask why planets would reverse course in a geocentric model). Then use published tables of planetary positions to show that they have this behaviour. Then do a couple of observations to show that the tables accurately predict the positions of the planets on a few nights.
  • #76
Some geocentric models even result in the same astronomical observations (e.g. a simple transformation of the heliocentric model into the rest frame or Earth). Additional information would be required in order to ruel them out (e.g. conservation of momentum). Maybe the best approach is to demonstrate how to predict the astronomical observations with a heliocentric model and than to ask for a pure geocentric model with at least the same accuracy. It would be a surprise if the latter turns out to be more convenient.
  • #77
We tend to take for granted that the 'right' model would be the simplest model. It's in the DNA of Scientists to go for the most basic model. Should Convenience really be the touchstone? After all, every one of those 'Laws' ends up with codicils and those codicils tend to be more huge than the original Law.
One person's law of nature can be another person's quick fix for working out what to do.
  • #78
Physics shall be useful. Thus, convenience should matter. However, it depends on the praticular application. A model that is convenient for one application (e.g. to provide a better understanding for humans) might not be suitable for another (e.g. for computer simulations). Therefore it is not an objective criterion.
In regard to the current topic this means that from different models (e.g. barycentric, heliocentric or geocentric) resulting in the same predictions (within a given accuracy), the model that is less painful to use should be preferred. That would be the barycentric model for Newtonean dynamics or the heliocentric model for Keplers laws. I am not aware of an application that would cry for a geocentric model.
  • #79
What is this thread about now? It seems to be all over the place.
  • #80
Remains of stronomical observatories in China, India and pre-Incan Andean countries contains stone tools (parts of the buildings) making possible (with recording materials like paper, pergamine, wood, etc.) recording of observation through years. In a medieval Europe mobile instruments and notebooks were much easier to hidden such observation from Inquisition. Both systems were capable of centurial observations. Unfortunately we don't know if these capabilities were exploited in reality.
zbikraw
  • #81
Yes, I agree and that's a good pragmatic approach. Eventually, a simple law proves to be inadequate, though and the new law has to be less and less simple. In the example of the OP, I'm wondering what would make those Scientists look for anything other than a simple 'planetarium' model which doesn't consider actual distances or masses.
  • #82
Let's say I allow the child (or maybe its parent) to ring or e-mail a scientist on the ISS. Would they be able to make any useful observations that the child on Earth couldn't make.
Maybe I'm hung up on the observations being made by a child. How about it's a group of year 10/11 students under the guidance of their science teacher?
PS: I'm not a science teacher looking for a project for my students.
  • #83
The only experiment that I could think of is making several pictures of the same regions of the sky over the year and than to measure the angle between neighboring stars. With sufficient accuracy this should reveal changes of the positions (in the images) of nearby stars relative to distant stars. Within the ecliptic the appearent motion should be linear and in the polar regions it should be circular. That should be an acceptable indication for the motion of Earth. This has already been mentioned above (parallax method).
Astronomical observations within the solar system could distinguish between different geocentric models (e.g. Sun and all other planets orbit Earth vs. Sun orbits Earth and all other plantes orbit Sun) but not between a heliocentric model and geocentric models in general (because some of them are equivalent to the heliocentric model in regard to the predicted astronomical observations).
  • #84
A model that is only a choice of origin away from the modern standard Newtonian (or post-Newtonian) model is not a distinct model. I would describe that as a disguised heliocentric model; a simpler description is available in the Sun frame (or center of mass frame). A geocentric model would be one such as that sketched in #28, where the simplest description is available in the Earth-centered frame. Obviously, no experiment can differentiate a heliocentric model from a coordinate transformed version of itself.
Indeed. And Tycho Brahe's observatory was a naked eye observatory. But, again, the OP was asking for an experiment that kids could do. Sure you can make sufficient measurements over the course of a few months to convince yourself, but I don't think there's any one-or-two night measurements they could make without borrowing data from some other source.
  • #85
It's far from trivial to make parallax measurements and those measurements rely on long history of astronomical techniques. I am not sure that our fictitious situation would allow that. It seems that we are picking and choosing about what we are allowed to use out present knowledge to do. If we're in a position to do parallax measurements then we would also be in a position to measure the 'proper motion' of stars as they move about the galaxy.
Way before parallax measurements were possible, the distances to and between the bodies in the Solar System had been measured (amazingly, without the use of telescopes in the early cases). I think that we'd hard put to deduce those distances accurately without using a heliocentric model.
  • #86
I agree. Too hard and too extended for all but the exceptional child with lots of available time.
I think you may be overestimating what simple astronomical observations reveal. I was rather taken up with the process measuring astronomical distances and tried to communicate the ideas to two sets of adults. It was fun.
Bear in mind that all you can ever measure is angles and knowledge of one or more distances. A working knowledge of school geometry and assumptions about circular orbits can take you from the Moon's distance (using a baseline on Earth) to the Sun's distance and then to the distances to the planets. But just the angles tell a very limited story.
Hats off to the old astronomers with their basic instruments.
  • #87
DrStupid said:
We do that because we know the physics behind it.
Actually, the physics says the Moon orbits the Sun, not the Earth. More precisely, the Sun's gravitational force on the Moon is always stronger than the Earth's, so the Moon's orbit is always concave towards the Sun.
  • #88
Is this correct?
Yes. That is what we 'see'. Any particular star changes apparent position but, after one year, it's got round to where it was, after 366 days (approx). Parallax amongst the stars is not visible from a baseline within the Earth and relative (proper) motion is very subtle, year on year.
  • #89
I wonder what the limiting case for this is - i.e. what's the lowest Earth orbit that's still concave wrt the Sun?
  • #90
Does concave just mean "no retrograde motion"? If so, the orbital radius whose speed is the same as the Earth's orbital speed, so that the satellite is instantaneously stationary with respect to the Sun.
If Earth's orbital speed is ##v## and its orbital radius is ##R## from the Sun of mass ##M_S##, then ##v^2=GM_S/R##. Similarly, if a satellite has orbital speed ##u## and orbital radius ##r## from an Earth of mass ##M_E##, then ##u^2=GM_E/r##. Equating ##u## and ##v## I get ##r=R(M_E/M_S)##, or a bit less than 45km from the center of the Earth(!).
Edit: obviously that's nonsense because you can't treat the Earth as a point mass at the center once you are inside it. So there probably is no such orbit.
  • · Replies 52 ·
  • · Replies 24 ·
  • · Replies 21 ·
