- 50,379
- 26,435
Ibix said:Does concave just mean "no retrograde motion"?
No. It means the net acceleration is always towards the Sun, never away from the Sun.
sophiecentaur said:I wonder what the limiting case for this is - i.e. what's the lowest Earth orbit that's still concave wrt the Sun?
So not a lot lower than the Moon's orbit then? Below that, the orbital speed of the satellite around the Earth would be greater than its orbital speed round the Sun. (?)PeterDonis said:For an object directly on a line between the Earth and the Sun, the accelerations due to the Sun's and Earth's gravity are equal and opposite at about 257,000 km from the Earth (the Moon's orbit is at an average distance of about 400,000 km). So that altitude is the limiting altitude for an orbit to always be concave towards the Sun.
sophiecentaur said:So not a lot lower than the Moon's orbit then?
sophiecentaur said:Below that, the orbital speed of the satellite around the Earth would be greater than its orbital speed round the Sun. (?)
No, that's the calculation I did. A bit of Googling turns up this paper, which models a moon moving in an Earth-centered circle superimposed on the Earth's Sun-centered circle. It shows that the instantaneous radius of curvature of the orbit can change sign for close-in orbits, but does not for the Moon's real orbit.sophiecentaur said:So not a lot lower than the Moon's orbit then? Below that, the orbital speed of the satellite around the Earth would be greater than its orbital speed round the Sun. (?)
PeterDonis said:Actually, the physics says the Moon orbits the Sun, not the Earth. More precisely, the Sun's gravitational force on the Moon is always stronger than the Earth's, so the Moon's orbit is always concave towards the Sun.
DrStupid said:The force doesn't matter.
DrStupid said:Moon is gravitationally bound to Earth and not only to the Sun.
DrStupid said:It would still orbit Earth when the Sun would be removed.
PeterDonis said:In other words, it is bound to both. Yes, I never said it wasn't.
DrStupid said:You claimed that Moon does not orbit Earth.
PeterDonis said:In the sense that its orbit is not always concave towards the Earth, but is always concave towards the Sun.
DrStupid said:In the rest frame of Earth
DrStupid said:there is no reason to prefer the rest frame of Sun
DrStupid said:The Moon orbits Earth - even according to your own definition.
DrStupid said:The world lines of both, Earth and Sun are geodesics.
PeterDonis said:Which is not inertial over the relevant time scale.
PeterDonis said:No, it doesn't, because my definition requires an inertial frame.
It is always that way from my viewpoint. It's not a good idea to try to describe what things 'really' are because it's all relative.PeterDonis said:In the sense that its orbit is not always concave towards the Earth
DrStupid said:Earth is free falling around the Sun. Thus, the rest frame of Earth is a local inertial frame (you don't need GR to see that)
sophiecentaur said:It is always that way from my viewpoint.
sophiecentaur said:Imagine you are in a craft, orbiting the Moon. How would you describe things - assuming you knew nothing about modern astronomy?
PeterDonis said:You could set up Fermi normal coordinates centered on the Earth's worldline, and those would cover the Earth now and a month from now (or indeed as far into the future as you like); however, those would not extend far enough in space to cover the Sun, so it is impossible to describe an "orbit" for the Sun in such a frame.
DrStupid said:I'm not talking about the Sun but about Moon orbiting Earth.
If you use gravity. (specifically quantum because sub-atomic gravity and gravitons are far too confusing) you can point out that either the entirety of physics is a lie or the suns gravity pulls the Earth into orbit and not vice versa.saddlestone-man said:Summary:: Is there a simple way of proving that the Earth moves around the Sun and not vice versa?
It seems to me that Galileo and his successors benefitted from there being other bodies in the solar system other than the Earth and the Sun to prove that the Earth (and other bodies) orbited the Sun, and not the other way round.
In an imagined solar system where the Earth has no moon, and there are no other planets, asteroids, comets, etc, is there a (relatively) simple way of proving that the Earth orbits the Sun, and not the other way round?
best regards ... Stef
PeterDonis said:Of course "right" here is ultimately a matter of preference;
sophiecentaur said:We all assume that the Moon orbits the Earth except when the apparent paradox of the shape of the Moon's solar orbit is brought into the discussion.
andrew s 1905 said:When I observe the Galilean moons of Jupiter I am with Galileo in that they appear to orbit it.
andrew s 1905 said:a Galileo observing from Mars might conclude the moon orbits the earth
I think that's just being controversial - you'd have to absolutely bend over backwards to hold that view genuinely.PeterDonis said:I would phrase it differently. I would say we all assume that the Moon orbits the Earth if the Earth and the Moon are the only bodies we are considering.
sophiecentaur said:I think that's just being controversial
sophiecentaur said:There are some Horseshoe orbits that could possibly be interpreted that way.
PeterDonis said:No, you're talking about the Moon not orbiting the Sun
DrStupid said:I never claimed something like that.
DrStupid said:In the rest frame of Earth it is not always concave towards the Sun, but is always concave towards the Earth.
etc.PeterDonis said:by the definition of "orbit" that I was using
