Astrophysics rotational break up velocity
2 replies · 9K views · last reply
nissanztt90
Write out expressions for the rotational speed (at the equator) and rotational period of an object mass M and radius R that is spinning at the break up velocity.
[tex]F= mg[/tex]
[tex]F = m \omega^2 r[/tex]
[tex]g = \frac{mG}{r^2}[/tex]
So i know that for something to be "flung" off the spining mass, the centrifugal acceleration would need to be greater than the gravitational acceleration.
So i just set them equal to each other, and solve for omega...
which is...
[tex]\sqrt{\frac{mg}{r^3}} < \omega[/tex]
And for the rotation period...
[tex]p < \frac{2\pi}{\sqrt{\frac{mG}{r^3}}}[/tex]
Is this correct?
That's correct. You should just write your answers with M, G and R instead to avoid confusion. And the break up velocity is reached with an "=" sign, not ">" or "<".
You're basic force equation for a masse "m" would be:
F = -mg +N = -m(v^2)/r, but since the normal force N equals to 0 you get
g = (v^2)/r
After that you just need to replace with the angular velocity and the gravitational field strenght equations, which you have figured out.
So the Earth would need to spin 17 times faster for us to feel no gravity!
Thanks!...we had to calculate how fast the sun needed to spin as well...calculated a period of 2.8 hours...i was quite surprised to say the least.
