Asymmetry in Stokes' theorem & Gauss' theorem
30 replies · 4K views
feynman1
Stokes theorem relates a closed line integral to surface integrals on any arbitrary surface bounded by the same curve. Gauss theorem relates a closed surface integral to the volume integral within a unique volume bounded by the same surface. What causes this asymmetry in these 2 theorems, in the language of calculus?
A closed surface defines a unique volume. A closed curve defines a unique area in 2D, but not a unique 3D volume.
Right. Why is there such a difference? Mathematically or philosphically.
There's no difference except the dimension. Why is a cube different from a square?
A 2d closed surface can only enclose a unique 3d volume while a 1d close curve can enclose multiple 2d surfaces. Why’s that asymmetry?
There is no asymmetry. A closed 2D surface can also enclose multiple 3D volumes if you allow "bridges", what you obviously did in the 2D case. The intersection point of a figure 8 can likewise be used to connect surfaces in 3D.
Great. Could you please give an example of bridges for a spherical surface or anything simple?
Just take two balls and connect them by a straight line. Then you have a closed surface. But even without, the two spheres alone are one closed surface. You confuse closed with connected.
Then in this example of yours, the 2 balls form 1 surface, then what is/are the enclosed 3d volume?
I agree with you , this asymmetry exists indeed, and it must be something related to the topology of ##\mathbb{R^3}## and ##\mathbb{R^n}## in general. But as I was pretty weak in topology during my undergraduate studies, I can't seem to give a deeper explanation on why this asymmetry is present.
The reason I ask this is due to applications of Gauss' and Stokes theorems.
There is no asymmetry:
2D surface - unique 3D volume (in 3D space) - multiple 3D volumes (in 4D space)
1D curve - unique 2D surface (in 2D) - multiple 2D surfaces (in 3D)
It's the same thing one dimension higher.
[/QUOTE]
I doubt about this. What if the 1D curve isn't planar, then there's no 2D surface in 2D in your language.
Yes in ##R^4## there isn't such asymmetry but i believe there we would have another asymmetry present (something like a 3D volume can enclose only one 4D volume but a 3D surface can enclose many 4D volumes).
[/QUOTE]
The difference between Gauss's law and Stokes's theorem is a mystery then! I don't know why they are not the same.
The original question is here:
https://www.physicsforums.com/threa...d-by-the-same-curve-in-stokes-theorem.989709/
And here:
https://www.physicsforums.com/threads/asymmetry-in-stokes-theorem-gauss-theorem.989780/
If you want to take a look. I may be misunderstanding what the OP is asking.
[/QUOTE]
A non-planar 1D curve translates to a 2D surface embedded in 4D (not 3D). A circle translates to a sphere, but a close curve that extends into 3D translates to a closed 2D surface that extends into 4D.
You only get an asymmetry when you allow a 1D curve to be in 3D space, but restrict a 2D surface to 3D space.
The spheres are the 2D surfaces, the balls the 3D volume.
Yes, so there's no more than 1 volume enclosed?
Why that? There are two spheres, hence they enclose two volumes / balls.
But when applying Gauss' theorem, one has to enclose both spheres. It's not a choice to enclose which of the 2.
I think you still confuse closed and connected. But maybe I don't understand your point. A picture would be helpful.
Could you post a pic of your idea of 1 2D surface enclosing more than 1 choice of 3D volume?
No, since I don't know what choice means in this context.
Search "double cone".
You confusion arises because a simple closed curve bounds at most one* single continuous area whereas a closed curve that is not simple (i.e. crosses itself) may bound 2 or more disconnected areas.
Exactly the same is true for surfaces - a simple closed surface bounds at most one volume but a surface that crosses (i.e. intersects) itself may* bound 2 or more.
* note degenerate cases e.g. line on a Möbius strip, Klein bottle. exercise - must a crossing curve enclose at least one area? What about a simple surface?
Thank you. How would you explain 1 surface enclosing only 1 volume in applying Gauss' theorem? How will it apply to a double cone?
I wouldn't. The divergence theorem (which is how we now refer to the vector calculus generalisation of Gauss's law in electrostatics), is not restricted to simple closed surfaces.
Well it would have to be a double truncated cone to be closed. Why do you think there is a difficulty in applying Gauss's law here?
My difficulty is, for Stokes' theorem 1 curve can enclose multiple surfaces but in Gauss' 1 surface encloses 1 volume
You keep stating this but you are not responding to a number of different people pointing out that a single "volume" in what you call Gauss's law is not necessarily continuous.
Also, this is the third post on the subject. It was already answered in the threads mentioned in post #12 above. Here, for example, is a good answer to the question:
