Asymptotic properties of Hydrogen atom wave function
Homework Helper
Insights Author
I am working through an explanation of the wave function of the Hydrogen atom.
I have got as far as deriving the version of Schrödinger's equation for the one-dimensional problem in which only the radial coordinate can vary:
##[-\frac{\hbar^2}{2m}\frac{\partial^2}{\partial^2 r}+\frac{\hbar^2 l (l+1)}{2mr^2}+V(r)]U_{El}(r)=EU_{El}(r)##
It is assumed that ##V(r)=-\frac{e^2}{r}##.
The presentation I am working through says:
'Find the asymptotic behavior of ##U_{El}(r)## as ##r\rightarrow 0##...
Solution: At ##r\rightarrow 0##, the first and second terms in the Hamiltonian will dominate, so [the above equation] becomes:
##\frac{\partial^2}{\partial^2 r}U_{El}(r)=\frac{l(l+1)}{r^2}EU_{El}(r)##'
I don't see why this follows. Certainly the second term in the square brackets will dominate the third term, which is only divided by ##r##, not ##r^2##, and the right-hand side of the equation, but why would it not also dominate the first term, which is not divided by ##r## at all?
Is it possible to derive the second equation above in a more convincing way?
Thank you.
Suppose it did not exist, you'd have a static thing (U would be constant or something).
The derivative will give you how things change...
This is a standard technique in differential equations. To derive an approximate solution valid in a particular region (r → 0 in this case), assume a general form for the solution. Examine the magnitudes of each term in the equation, and keep only the leading ones.
So we assume u ~ rn and compare magnitudes of the four terms:
u'' ~ rn-2
u/r2 ~ rn-2
u/r ~ rn-1
Eu ~ rn
As r → 0, the first two terms have equal magnitude and dominate the others, so those are the ones we keep.
One could ask instead for an approximate solution for r → ∞. In that case, assume u ~ e-ar. Plugging it in, you'll find that the first and fourth terms dominate the others.
Thank you very much. That has completely cleared it up for me.
If I may, I would like to ask a supplementary question on the same topic area, although this time from a different text - Shankar.
Shankar (p341-2 of 2nd edition of 'Principles of Quantum Mechanics') discusses what constraints must be placed on ##U_{El}## in order for the Hamiltonian operator (part in square brackets in 1st equation - which he abbreviates to ##D_l(r)##) to be Hermitian with respect to U, ie for ##<D_l(r)U_{El}|=<U_{El}|D_l(r)## to hold.
He derives an equivalent condition that, for any two functions ##U_1## and ##U_2## obeying these constraints, we must have:
##[U_1^*\frac{dU_2}{dr}-U_2\frac{dU_1^*}{dr}]_0=0## [12.6.9]
He then states that 'this condition is satisfied if ##lim_{r\rightarrow 0}U=c## where '##c## is constant'.
I don't understand what this statement means - constant with respect to what? Obviously it is constant with respect to r, because it is a limit at a particular value of r, so that can't be his meaning. He might mean constant with respect to time but, given that we are talking about eigenvectors of the time-independent Schrödinger equation, the time dimension doesn't seem relevant. The only other interpretation I can think of is that he means:
##\exists c## such that ##\forall U: lim_{r\rightarrow 0}U(r)=c##.
But if that's what he means, I can't see how he proves that the above condition 12.6.9 follows from it.
Can anybody suggest what Shankar might be trying to say here, and how it can be proven?
