At what angle of force is Kinetic friction least?
The discussion revolves around determining the angle at which the force applied to drag a box across a surface with kinetic friction is minimized. The problem involves concepts from mechanics, specifically relating to forces, friction, and angles of application.
  • Mixed
  • Participants explore the relationship between the applied force and the angle, with some suggesting the use of calculus to find the angle that minimizes the force. Others question the necessity of calculus, proposing that algebraic manipulation may suffice. There are inquiries about the definition of the angle theta and whether a diagram was provided.
Participants are actively engaging with the problem, sharing their attempts and reasoning. Some have provided hints regarding the use of derivatives, while others express confusion and seek further clarification. There is no explicit consensus on the approach to take, as different methods are being considered.
One participant notes that they are studying independently for an upcoming AP physics exam and lacks access to immediate help, which may influence their understanding and approach to the problem. There is also mention of potential sign errors in the force equations being discussed.
gijungkim
The total force needed to drag a box at constant speed across a surface with coefficient of kinetic friction Uk is least when the force is applied at an angle theta such that
a.sin(theta) = Uk.
b.cos(theta) = Uk.
c.tan(theta) = Uk.
d.cot(theta) = Uk.
e.sec(theta) = Uk.
F = ma
Ff = Uk * Fn = m*g*Uk
Fx = F *cos(theta)
Fy = F*sin(theta)
First the answer is d. cot(theta) = Uk
I tried to solve it, but couldn't figure it out...
This is my work
Since it is dragged at constant speed, the acceleration is 0. So a = Ftotal/m = 0
Ftotal = F*cos(theta) - (mg - F*sin(theta))Uk = 0
F*cos(theta) / (mg - F*sin(theta)) = Uk... which is wrong...
Can anyone help me?
So far, so good.
Realize that F is a function of theta. You'll need a bit of calculus to figure out the value of theta that minimizes F.
Question: Did they give a diagram defining the angle theta?
Doc Al said:
So far, so good.
They did not give me any diagram defining the angle theta.. Can you help me out little bit more using calculus?? I still don't get it :(
How would you use calculus to find the max or min of a function?
You derive the function and make it as a 0 ??
Yes! You'll set the derivative (##dF/d\theta##) equal to zero and solve for ##\theta##.
Hint: What you have will require implicit differentiation.
I need one more hint! What equation do I have to set the derivative??
This one??
Oh nevermind it will be this one right?
I don't think this requires calculus. Just some algebraic manipulation.
Ok... I tried my best... and got tan(theta)... Ughhhh why is this so hard to me
Can you help me out?
Were you assigned this problem in a calculus based physics class?
Nope. I'm studying physics by myself so I can take AP physics on May! I don't have anyone to ask questions beside here and I got this questions from internet!
Try solving for the coefficient of kinetic friction in terms of F and itself. You can then substitute this value ...somewhere...
Also, I believe you made a sign error in your forces.
Given how you defined theta, I would say that was correct. (That's why I asked if you had been given a diagram.)
Ahh physics is killing me hahaha
So when do I get cot(theta)?? where does the theta have to be to get an answer cot(theta)??
Since cot(theta) = 1/tan(theta), you'd get cot(theta) if you let theta = angle with the vertical.
Where did you find the problem?
I found this question from internet! I think this question is based on the book "Physics for scientist and engineers" Serway and Jeweet, but I already read the book and couldn't find anything that explains this problem haha
Can I ask you one irrelevant question? Do you know where I can find good Physics Mechanics problem? Since I'm studying by myself, I just like to read the book and solve problems from online and ask questions here if I get stuck. I found good problems from the book I mentioned above, but I'm almost done with that so I'm just wondering if you knew any or if you have any haha
There are many books of problems available, at various levels. To start off, you might want to try something like https://www.amazon.com/dp/0071763465/?tag=pfamazon01-20.
  • · Replies 41 ·
13K
  • · Replies 24 ·
