At what distance does a charge attain half its speed at infinity?
The problem involves two charges, each with a value of 3.40μC, where one charge is fixed at the origin and the other is released from rest at a specified position. The objective is to determine the distance from the origin at which the moving charge reaches half its speed at infinity, which is given as 7.79 m/s. The mass of the moving charge is 2.49 m.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the application of conservation of energy principles, questioning the relationship between kinetic and potential energy at different points in the charge's motion. There is uncertainty about the correct setup of the equations needed to solve the problem. Some participants suggest sketching a diagram to clarify the situation and emphasize the importance of understanding the initial conditions, such as the initial velocity being zero.
Participants are exploring various interpretations of the problem and discussing the equations that may be relevant. Some guidance has been offered regarding the use of conservation of energy and the potential energy of point charges. There is an ongoing examination of the initial conditions and how they relate to the final speed at infinity.
There are indications of constraints due to the original poster's difficulties in understanding the material, compounded by missed class time. The discussion also touches on the potential for the problem to be over-determined, given the provided values and relationships.
alyssa.d
A charge of 3.40μC is held fixed at the origin. A second charge of 3.40μC is released from rest at the position (1.25m, 0.570m). If the mass of the second charge is 2.49 m, and its speed at infinity is 7.79 m/s, at what distance from the origin does the second charge attain half the speed it will have at infinity?
I really am unsure which equations to use. However, I think that, when the second charge attains half the speed it will have at infinity, half its energy will be kinetic and half its energy will be potential. (Right? No? Maybe?) So some relevant equations would be:
Ki + Ui = Kf + Uf
F = kQ/r^2
ΔK = 1/2mvf^2 - 1/2mvi^2
ΔV = qΔV
You are solving for r.
My issue in physics always is that I'm unsure how to set up the problem, and I never know which equations to pick. Lately this has been compounded by the fact that I've lost class and study time due to severe migraines, so I've been teaching myself almost everything (and this part of physics is something I've been struggling to pick up on my own).
Anyway, my attempt at a solution was this:
1/2mvi^2 + qVi = 1/2mvf^2 + qVf
1/2mvi^2 + q(kq/ri^2) = 1/2mf^2 + q(kq/rf^2)
I plugged in the numbers given in the problem (using 1.37 for ri, calculated from the initial position of the second charge). I got an rf value of 5.37. Any help would be appreciated!
Ki + Ui = Kf + Uf
F = kQ/r^2
ΔV = qΔV
Hello alyssa. Welcome to PF !
(Use the X2 icon for superscripts, X2 for subscripts.)
Is "(Right? No? Maybe?)" a multiple choice? ... then No.
If the second charge has half it's max speed, does that mean it has half it's max Kinetic Energy? ... No.
You'll need to show what you did in more detail.
What's the KE at infinity?
What's the KE when the second charge is at half speed?
Conservation of energy would be a good place to start.
Don't worry about remembering the equations to pick - sketch a diagram of the situation. This is the thing to practice.
The free charge will accelerate radially away from the fixed one ... so you just need to know the initial radius and the angle rather than the x-y components.
What is the initial velocity of the free charge?
Try thinking about this in terms of work. dW=F(r).d
Do you know the equation for the potential of a point charge?
Yes. The initial velocity of the free charge is 0, since it's released from rest. The equation for the potential of a point charge is V = kq/r. I feel like I am making this more difficult than it needs to be, like I am missing something very simple just in terms of how I'm thinking about setting it up.
The problem appears to me to be over-determined.
ri is given, so you have initial potential energy, Ui = q1V1 = kq2/r1.
Ki = 0.
Uf = 0, so you can find Kf from conservation of energy.
You are given the mass of the charged particle, so you can determine the speed at infinity.
Does that agree with the speed given?
Well, if that mass is 2.49 grams, then yes, the speed at infinity is consistent with the other given information.
If I use K for kinetic energy:
* You have ##v_\infty = \sqrt{2K_\infty/m}##
* You know that loss in potential energy moving to position r = gain in kinetic energy.
* The speed at position r must be given by ##v=\sqrt{2K(r)/m}##
* You want to find r so that ##v(r)/v_\infty=1/2##.
That help?
9K
