At what height does this plank leave the wall
  • Thread starter Thread starter Pushoam
    Height Wall
44 replies · 6K views · last reply
Pushoam
When the plank leavs the wall at angle ##\theta ##,
Torque about ground ## \tau _g = mgl \cos \theta = \frac { m(2l)^2 \alpha }3##
Torque about COM ## \tau _c = Nl =\frac { m(2l)^2 \alpha } {12} ##
Acceleration of COM: a = ## [g^2 +( \frac N m )^2 - 2 g \frac N m \cos \theta]^{0.5} = \alpha l ##
Is this correct so far?
I think the last eqn. is wrong as further calculation gives ##\cos \theta =1##
robphy said:
Is your free-body diagram complete?
Yes, it is.
The wall could not exert any force as the plank leaves it.
So, there are only two forces acting on it which I have shown already.
What is ##\alpha## and where does it come from in the torque equation? There is also the motion of the center of mass to consider.
mfb said:
What is αα\alpha and where does it come from in the torque equation?
##\alpha ## is the standard symbol used for angular acceleration. It is in the torque equation.
The last eqn in the OP is about the above.
I know, but it doesn't seem to make sense at this place because you do not have a pure rotation.
Pushoam said:
When the plank leaves the wall at angle ##\theta ##,
Normal force is perpendicular to the surface. You have the orientation of ##\ \vec N \ ## wrong in your FBD .
Does the wall (vertical) also provide a normal force?
There is more to the motion of the COM than simply giving its acceleration.
In terms of L and ##\theta##, what are the coordinates of the center of mass? In terms of these kinematic parameters, what are the velocity components of the center of mass? What are the acceleration components of the center of mass? What are the force balances in the vertical and horizontal directions?
Chestermiller said:
Hummmm. Sound interesting.
You can obtain the velocity and angular velocity as functions of the initial and current angles just from conservation. It follows that it can be solved by considering the instantaneous circumstances at the current angle, since no further history can be relevant.
Yes. If you are willing to take one time derivative, you can get the needed info about angular acceleration from the energy equation. No need to set up torque or force equations (other than knowing that zero horizontal force implies zero horizontal acceleration of cm). I think we each have our own way that we like to solve this problem. :oldsmile:
Yes. Or to avoid calculus entirely, take moments about the instantaneous centre of rotation.
I'm intrigued by this. I was able to solve this problem using conservation of energy in conjunction with the force balance in the x direction, but had to use calculus to express the linear velocity- and acceleration components of the center of mass in terms of the angular velocity and angular acceleration. Please share how you were able to solve without using calculus.
Did you identify the instantaneous centre of rotation?
SammyS said:
Normal force is perpendicular to the surface. You have the orientation of ## \vec N##wrong in your FBD .
There are two surfaces and so there are two normal to the surfaces, 1) normal to the ground 2) normal to the plank?
Since you said that the one I took was wrong , I think ##\vec N ## will be normal to the ground. But, in general how to decide the correct normal?
No, it doesn't, as when the plank leaves the wall, it loses contact with the wall. So, at the moment of plank leaving the wall, I have to take the normal force exerted by the wall to be 0.
About other posts, I will reply after digesting them. Thanks for them.
Is that the contact point on the horizontal surface?
No.
At each instant, each point of the plank will be moving tangentially to the instantaneous rotation centre. So just take the normals to the contact points and see where they intersect.
haruspex said:
No.
This is new to me. I'll have to think about it.
By taking moments about the instantaneous center of rotation, do you mean setting up the equation ##\sum \tau_p = I_p \alpha##, where ##p## denotes the instantaneous center of rotation? This equation is not true in general, but it does happen to be true for this problem. Its validity here was not obvious to me until I justified it. Maybe I'm overlooking an easy way to see that it's true in this problem.
Yes, but the motion could be divided into pure rotation and pure translation. So, I think a ≠ αl, but are other parts of the three eqns correct in OP?
Actually, it is.
As I was taught at school, it is ok to use any fixed point in an inertial frame, the mass centre of the object, or the instantaneous centre of rotation of the object.
At the time, it bothered me that it was so special-case. Recently I investigated this and found that the set of points of the object which, taken as axis, happen to give the right answer form a circle passing through the mass centre and the instantaneous centre of rotation.
I can see why ##\sum \tau_p = dL_p/dt## is valid. It's the equating of ##dL_p/dt## with ##I_p \alpha## that I don't think is always valid.
For example, suppose at some instant of time a rod is instantaneously rotating about one end, p, with angular speed ##\omega##. Also, at this instant there is a single force F applied to the rod at p, as shown. Then ##\sum \tau_p = dL_p/dt## is valid since you can show that both sides are zero. But ##\alpha \neq 0##. So, ##\sum \tau_p \neq I_p \alpha##.
haruspex said:
In that model, the linear acceleration of the mass centre has moment about the chosen axis. That is all part of the rate of change of angular momentum.
Yes. I think maybe I've misinterpreted what you were originally saying when you said "take moments about the instantaneous center of rotation". If you meant set up ##\sum \tau_p = dL_p/dt## and then show that ##dL_p/dt = I_p \alpha##, then I'm with you. But if a student were to start with ##\sum \tau_p = I_p \alpha##, I would ask for justification since I don't think this equation is generally valid.
TSny said:
. If you meant set up ##\sum \tau_p = dL_p/dt ##and then show that##dL_p/dt = I_p \alpha##, then I'm with you. But if a student were to start with ##\sum \tau_p = I_p \alpha##, I would ask for justification since I don't think this equation is generally valid.
You are asking for justification because ## \vec L_p = I_p \omega ## is valid only for fixed-axis rotation. Right?
TSny said:
But α≠0. So, ##\sum \tau_p \neq I_p \alpha##.
Because, of the applied force at p, the direction of axis of rotation does not change. Right? If so, then the axis of rotation remains fixed in direction.
Hence, ##\sum \tau_p = I_p \alpha##.
How do you know that α≠0? Because if it is so, then ## \omega ## is changing and so the angular momentum.
Another attempt :
Center ūf mass motion gives,
mg(-\hat y ) + N \hat y = m\ddot y \hat y ~~~~~~~~~~~~~~~~~ \ddot y <0. ~~~~~~~~~~~~~~(1)##
## y = l \sin \theta
\\ \ddot y = l\{\ddot \theta \cos \theta - \sin \theta {\dot \theta }^2\}
I can't decide here whether ## \ddot \theta ## is positive or negative.
Since the torque about both center of mass C and pivot P is anti - clockwise,
considering ## \vec \tau = I \vec \alpha : \vec \alpha = \ddot \theta \hat z, ## I decide ##\ddot >0. ~~~~~~~~~~~~~~~~(2)##
But this method is valid only if ## \vec \tau = I \vec \alpha## is valid only for fixed axis rotation.
Using (1) and (2) ,
##N- mg = ml[ \cos \theta ~\ddot \theta - \sin \theta ~ {\dot \theta }^2 ] ~~~~~~~~~~~~~~~~~~~~~~(1.1)##
Similarly,
## \ddot x =0 ~ and~ x = l \cos \theta ## gives,
##\ddot \theta = \cot \theta {\dot \theta}^2 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~(3)##
(1.1) and (3) gives,
##N - mg = \frac {ml {\dot \theta }^2 \cos {2 \theta} } {\sin \theta } ~~~~~~~~~~~~~~~(4)##
Now, considering rotational motion about center of mass,
Torque about center of mass,
##Nl\cos \theta = I_{cen} \alpha ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~(5)##
Now, can I take ## \ddot \theta = \alpha##?
How to derive the energy eqn. as normal forces by wall and ground are not known?
Should I take them constant ?
Why do we take Normal force perpendicular to the ground instead of that to the plank?
