DaveC426913
2025 Award
- 24,772
- 9,197
jbriggs444 said:This is not correct. If you reduce the volume but carefully avoid adding energy to the contents (draining as much in thermal energy as you are injecting by performing mechanical work) the result is an isothermal compression.
The same amount of thermal energy is in a smaller space, but the temperature is unchanged.
Did you not see the reference to gas laws? They don't involve bleeding off excess.
The OP believes that compressing a volume of gas will not raise its temperature. That is not true.
You can always complicate the experiment to obfuscate the principle being demonstrated if you want.
