Creating an Atomic Screen: A Solution to Separating Nuclei in Physics
  • Context: Graduate
  • Thread starter Thread starter Crazymechanic
    Atomic Screen
The discussion centers on the feasibility of creating a device that selectively allows heavier nuclei to pass while blocking lighter nuclei, akin to a sieve. The concept involves using a nozzle in a pressurized gas or plasma environment to achieve this separation. However, participants express skepticism regarding its practicality, noting that traditional methods typically permit lighter nuclei to escape while retaining heavier ones. The consensus indicates that such a device has not been successfully implemented in nuclear physics.
  • Understanding of nuclear physics principles
  • Familiarity with gas dynamics and plasma behavior
  • Knowledge of material properties affecting diffusion
  • Basic concepts of fusion processes
  • Research advanced gas separation techniques in nuclear applications
  • Explore the principles of diffusion in various materials
  • Investigate existing methods for nuclear fusion containment
  • Study the design and function of nozzles in fluid dynamics
Physicists, nuclear engineers, and researchers interested in advanced separation techniques and nuclear fusion processes.
Crazymechanic
Hi , well this is just a idea that came up when thinking about a certain problem in physics.
Now it's late and I don't wan to be long but is it possible or has it been done , a device that could for example hold back lighter nuclei and let through heavier ones or vice versa?
Well imagine a pipe that has some gas or plasma under pressure and at the end a nozzle but the nozzle let's only heavier nuclei through so unless those nuclei have fused or etc they cannot escape the nozzle.
Somewhat like a sieve for rocks , when you want to separate bigger ones from smaller ones or from sand for building purposes.
Helium and hydrogen can diffuse through many materials quite easily (at least compared to other nuclei) as they are so small. This is a serious issue if you want to have a good vacuum.
I doubt that this can be used in any fusion-related way.
Typically it works the reverse way. The lighter, smaller objects are allowed through while the bigger ones are trapped. I don't see any way to make it work the way you are asking.
  • · Replies 19 ·
  • · Replies 88 ·
18K
  • · Replies 17 ·
  • · Replies 25 ·
