How Accurate Can an Atwood Machine Measure Gravity?
The forum discussion focuses on using an Atwood machine to measure local acceleration due to gravity (g) with a target accuracy of 5%. The derived formula for gravity is g = (2L(m1+m2))/((m1-m2)t^2), where L is the distance fallen, m1 and m2 are the masses, and t is the time taken. The relationship between the uncertainties in gravity and time is established as dg/g = (-4L(m1+m2))dt / ((m1-m2)gt^3). To achieve a 1% accuracy in measuring g, the mass m2 must increase, highlighting the importance of mass uncertainty in the calculation.
  • Understanding of Newton's second law (F=ma)
  • Familiarity with kinematic equations, specifically x-x0 = v0*t + 0.5*a*t^2
  • Basic knowledge of derivatives and their application in physics
  • Concept of measurement uncertainty and its impact on experimental results
  • Explore the derivation of kinematic equations in greater detail
  • Study the principles of error analysis in experimental physics
  • Learn about the impact of mass ratios on the accuracy of gravitational measurements
  • Investigate alternative methods for measuring gravitational acceleration, such as pendulum experiments
Students studying physics, particularly those focusing on mechanics and experimental methods, as well as educators seeking to enhance their understanding of gravity measurement techniques.
Johnny0290
Consider the Atwood's machine of Lecture 8. We wish to use this machine to measure our local acceleration of gravity with an accuracy of 5% [i.e. (Delta g)/g = 0.05]. To begin, suppose we let the mass m_1 fall through a distance L.
3.1 Find an expression for the acceleration of gravity, g, in terms of m_1, m_2, L and t.
3.2 Now suppose we are able to measure time with an accuracy of (Delta t) = 0.1 s. Assuming that, for example, (Delta t)/t can be approximated by the differential dt/t, write the relationship between (Delta g)/g and (Delta t)/t. You can do this by starting with the derivative dg/dt determined from the equation in the previous part.
3.3 If L = 3 m and m_1 = 1 kg, determine the value of m_2 required to determine g to 5%. If we want to measure g to 1% would the mass m_2 increase or decrease - why? (On your own, you might want to consider the effect of the uncertainty in the masses of m_1 and m_2 on the determination of g.)
F=ma
x-x_0=v_o*t+.5*a*t^2
First I summed up the forces on the two masses and solved for the acceleration of the blocks.
I ended up with...
a=g(m1-m2)/(m1+m2)
Then I used x-x_0=v_o*t+.5*a*t^2 and solved for the acceleration.
a=2L/t^2
Combing the two equations and solving for gravity I got...
g=(2L(m1+m2))/((m1-m2)t^2)
3.2
I took the derivative of both sides of the equation with respect to t and got...
dg/dt=(-4L(m1+m2))/((m1-m2)t^3)
My attempt to relate dg/g to dt/t
dg/g=(-4L(m1+m2))dt / ((m1-m2)gt^3)
And that's where I'm stuck. I'm not sure if I did everything right and I can't figure out what I have to plug into do part 3.3
Any help is appreciated. Thank you!
It seems that you got tangled up in all those symbols. You can make your life simpler if you look at it this way. The expression for g is of the form
g = C t2, where C is a constant.
Now take the derivative and see what you get. BTW, the derivative of t2 does not go as t3.
Good. Now simplify by plugging your earlier expression for g into the right hand side.
10K
