Atwood machine rope tension problem
The discussion revolves around an Atwood machine problem involving a smaller mass of 5.2 kg and its acceleration of 4.6 m/s². Participants explore the relationship between the mass, acceleration, and tension in the rope, questioning how to approach the problem without knowing the second mass.
  • Participants discuss drawing free body diagrams and applying Newton's laws to analyze forces acting on the smaller mass. There are attempts to derive equations for tension and acceleration, with some participants questioning the setup and definitions used in their equations.
The discussion includes various interpretations of the equations governing the system. Some participants provide guidance on how to relate forces and tension, while others express uncertainty about the correct formulation of the equations. There is no explicit consensus on the final approach, but several productive lines of reasoning are being explored.
Participants note that they have not previously worked with a single mass in this context, which adds complexity to their understanding. There are also corrections regarding the values used in the equations, indicating a need for careful attention to detail.
Freeq
Smaller mass on an Atwood machine is 5.2 kg (m1). If the mass accelerates at 4.6 m/s2what is the mass of the object? What is the tension of the rope?
a = g(m2-m1)/(m2+m1)
I can't approach this questions, because we always worked with two masses and had to find acceleration and tension of the string, but we have never worked without the second mass.
Draw a free body diagram of the forces acting on the smaller mass. What forces are operating on it? What does Newton's second law have to say about the net force and resulting acceleration on a given mass?
That's what I did. According to Newton's law the forces need to be equal on boths sides.
(Left side)
Ft=m1g+m1a
Ft=(5.2x9.8)+(5.2x4.6)
Ft=74.88N
Then I can sub in Ft into the second equation.
(Right side)
Ft=m2g-m2a
Ft=m2(g-a)
When I want to check it, it works perfectly!
Ft=m2g-m2a
Ft=(14.4x9.8)-(14.4x4.6)
Ft=74.88N
Thanks!
I see that in your diagram, on the left hand side, you have an equation relating the forces acting on the smaller mass.
Your equation is FT = mg + ma. Since FT must be acting upwards on m, and mg must be operating downwards, and since the acceleration of the mass must be upwards (it's the smaller mass), then the equation should probably look like: FT = ma - mg for this smaller mass.
Now, for which of the variables in that equation do you have values?
EDIT: Silly me. ma should be the reaction force. That does indeed make it FT = mg + ma as you wrote. Apologies.
Not really, because when you think about tension of the rope, you need to add two opposite forces (or substract two forces in the same direction), and even if it should be mg-ma, and this is equation for the bigger mass. Which grade are you in? :D
If the smaller mass is accelerating upwards, then the force on that mass due to the tension in the cord exceeds the force due to gravity on that mass. Thus I write ma = T - mg, or T = ma - mg. This allows you to solve for the tension given values that you have in hand, namely the mass and acceleration of the small block. Try it.
EDIT: Doh! ma = T - mg, so T = ma + mg.
Sorry about that. I've been up to long...
ok I am going to teach you a bit of physics, the greater the downward force of gravity on the object, the greater the upward tension in the rope. In other words, the more the material is stretched, the greater the tension in the material. Now let's apply this to my assigmnent question : the smaller mass is stretched downward by gravity and upward by acceleration where, the bigger mass is only stretched downward by gravity and that stretch is reduced by upward acceleration, so the tension of the smaller object needs to be added.
Well, Freeq, if you have all the answers, you should be able to solve the problem without help!:smile: Write your equation and solve for the tension.
for m2 and plug in the known values of a and m1to find m2.
Good luck!
Freeq said:
(Right side)
Ft=m2g-m2a
Ft=m2(g-a)
I forgot to fiinish this so,
m2= Ft/(g-a)
m2=74.88/(9.8-4.6)
m2=14.4kg
BTW: I goofed on the picture - I wrote the mass of smaller object 5.3kg which it should be m1 5.2kg
Then I want to prove you AGAIN that this is right, by using the formula you mentionied in your post above.
a= g(m2-m1)/(m2+m1)
a= 9.8(14.4-5.2)/(14.4+5.2)
a= 4.6 m/s2
Which is right, because the acceleration given in the question is 4.6 m/s2
Dear gneill, I'm glad that I helped you understand physics a litte bit better :)
For more info/refference visit:
http://en.wikipedia.org/wiki/Atwood_machine
http://en.wikipedia.org/wiki/Tension_(physics )
Have fun!
  • · Replies 29 ·
