Audio Amplifier Using TIP 147, 142
The discussion revolves around troubleshooting an audio amplifier circuit that utilizes an LM386 integrated circuit and seeks to improve its performance using a Darlington pair or power transistors like TIP147/142. Participants are sharing insights on circuit design, microphone selection, and potential issues in the construction of the amplifier.
  • Homework-related
  • One participant reports that their audio amplifier does not amplify sound from the microphone and seeks assistance in improving the design.
  • Another participant requests additional information, including a circuit diagram and photos of the construction, to identify potential errors.
  • There is a suggestion to use a common collector configuration for its high input impedance, but the participant expresses confusion about the microphone connection and the lack of sound output.
  • Concerns are raised about the adequacy of the common collector stage, with a suggestion that a coupling capacitor is needed to connect the microphone signal to the base of the transistor.
  • Participants ask for clarification on the actual circuit implementation versus textbook designs, indicating a need for practical details.
Participants generally agree that there are issues with the current circuit design, particularly regarding the common collector stage. However, there is no consensus on the specific solutions or the correct microphone type to use.
Limitations include a lack of detailed circuit diagrams and photographs, which may hinder accurate troubleshooting. There are also unresolved questions about the microphone specifications and the exact configuration of the amplifier circuit.
Individuals interested in audio amplifier design, troubleshooting electronic circuits, or working with LM386 and transistor configurations may find this discussion relevant.
Usama Khurram
<< Obnoxious all caps post fixed by Moderators >>[/color]
I have made an audio amplifier using an LM386 IC, but it does not amplify any sound from the microphone. Please help me to improve this using a Darlington pair or any other power transistor like the TIP147/142...
Please don't use uppercase lettering ... its considered shouting when typing online
OK you haven't given us enough info to help you
how about circuit diagram if what you have built and maybe a photo or 2 of your construction so that the wiring can be checked for errorsDave
Also, please add any information you have about your microphone.
I have cascaded these two , means first i install the Common colletor because of high input impedence and then i apply its output from emitter to LM386 ... but theere is no sound which i applied on common collector base. which type of microphone should i use for this.. please guide me.
Well, the common collector stage you have shown is just a textbook drawing. What does your real circuit look like?
output speaker specs is: 4Ohm, 3 Watt
Your common-collector stage needs fixing! You'll almost certainly need a capacitor to couple the signal from the mic to the base, and this capacitor needs to go directly to the base (you are showing the mic wrongly connected directly to the power rail, Vcc).
can
you please draw the picture on peper and send me here? as it does not work till now.
Here is a schematic for a "common collector" stage.
  • · Replies 37 ·
  • · Replies 53 ·
20K
