Jupiter6
- 131
What is the purpose of the spiral ribs seen on modern car radio antennas?
The spiral ribs on modern car radio antennas serve a mechanical purpose by providing structural strength while maintaining flexibility. This design helps to distribute shear forces along the antenna, preventing crimping and enhancing durability. Additionally, the spiral shape increases the antenna's bandwidth at the expense of gain and reduces wind noise by directing air currents away from the vehicle. Research indicates that the spacing of these ribs is critical for damping vibrations at specific speeds, thereby improving overall performance.
PREREQUISITESAutomotive engineers, antenna designers, and anyone interested in the mechanics and aerodynamics of vehicle components will benefit from this discussion.
DaveC426913 said:I think its purpose is mechanical (rather than electronic). It provides strength to the antenna while allowing it to remain flexible, spreading any shear over the length of the antenna.
You see the same spiral structure on steam iron power cords, commercial kitchen sink hoses, etc., anywhere where you need flexibility spread evenly over a length so that you do not get a crimp.
dlgoff said:Would the spiral give the antenna not just an omni directional pattern in the horizontal plane but a vertical component? Thinking of transmission here.
Jupiter6 said:The rings and the antenna itself are an integral metal piece...e.g. the rings are not electrically isolated so it couldn't be to increase antenna length. It took awhile but I did some further research on the subject and apparently the rings are there to cut noise and keep the antenna from vibrating at certain speeds. The rings set up little ebbs in the air current which dampen movement at the natural frequencies of the antenna. The speeds and frequencies at which this damping occurs is determined by the spacing of the rings. I was quite suprised to read that much thought went into a car antenna.
NoTime said:I have yet to see one built to this purpose.
All I have seen are as berkeman describes.
Do you have a specific example?
