The average density of the gasoline in the steel gas can is 806 kg/m^3.
The average density of a full steel gas can containing gasoline is calculated to be 806 kg/m³. The gas can has a mass of 2.80 kg and holds 20 L (0.02 m³) of gasoline with a density of 680 kg/m³. The total volume of the gas can, including the steel, is determined to be approximately 0.02035 m³. This calculation involves using the formula for density, mass, and volume, leading to the conclusion that the combined density of the gas can and gasoline is 806 kg/m³.
  • Understanding of density calculations and the formula ρ = m/V
  • Knowledge of unit conversions, specifically between liters and cubic meters
  • Familiarity with mass density of materials, such as steel and gasoline
  • Basic algebra skills for manipulating equations
  • Study the principles of fluid mechanics and density variations in different materials
  • Learn about the properties of various fuels and their densities
  • Explore advanced applications of density calculations in engineering and material science
  • Investigate the impact of temperature on the density of liquids and gases
Students in physics or engineering, professionals in material science, and anyone involved in fuel storage and transportation will benefit from this discussion.
cbarker1
MHB
Dear Everybody,
A 2.80 kg steel gas can holds 20 L of gasoline when full. What's the average density (in kg/m^3) of full gas can, taking into the volume occupied by steel as well as by gasoline?
Work:
Given
the mass of the steel gas can= 2.80 kg
The Total Volume of Gas can= 20.0 L
The density of the gasoline= 680 kg/m^3
$\rho=\frac{m}{Volume of the gasoline}$
How to setup the problem?
Thanks
Cbarker1
Obviously, if the can holds 20.0 L of gasoline, then the total volume of the can must be greater than 20.0 L. Let's assume that the can is made of stainless steel with a mass density of 8000 kg/m³. What would the volume of the given mass of steel be?
the volume is 2857.14 m^3.
I think you have the volume inverted...I would write:
$$V=\frac{m}{\rho}=\frac{2.80\text{ kg}}{8000\,\dfrac{\text{kg}}{\text{m}^3}}=\frac{7}{20000}\text{ m}^3$$
Okay, now we need to convert the 20.0 L of gasoline into m³. I would use the fact that 1 L is 1000 cm³...
The answer for L to m^3 is .02 m^3.
$$1\text{ L}=1\text{ L}\cdot\frac{1000\text{ cm}^3}{1\text{ L}}\cdot\left(\frac{1\text{ m}}{100\text{ cm}}\right)^3=\frac{1}{1000}\text{ m}^3$$
And so:
$$20\text{ L}=20\cdot\frac{1}{1000}\text{ m}^3=\frac{1}{50}\text{ m}^3\quad\checkmark$$
Okay, so then what is the total volume of the can and gasoline when the can is full?
And so:
The Total volume is .02035 m^3.
Yes, although I would write:
$$V=\frac{407}{20000}\text{ m}^3$$
Now, we need to find the mass of the 20.0 L = 1/50 m³ of gasoline...we know the volume, and we know the mass density, and we have a formula that relates volume, density and mass...
$$\rho=m/V$$
$$680=m/1/50\implies 680=50m\implies 680/50=m\implies 13.6=m$$
Cbarker1 said:
$$\rho=m/V$$
To find the mass of the gasoline, I would write
$$m_g=\rho V=\left(680\,\frac{\text{kg}}{\text{m}^3}\right)\left(\frac{1}{50}\text{ m}^3\right)=\frac{68}{5}\text{ kg}$$
So, the total mass of the gasoline and the steel can is:
$$m_T=m_g+m_s=\left(\frac{68}{5}+\frac{14}{5}\right)\text{ kg}=\frac{82}{5}\text{ kg}$$
Recall, we found earlier:
$$V_T=\frac{407}{20000}\text{ m}^3$$
And so, what is the total mass density of the can full of gasoline?
$$\frac{m_T}{V_T}=\rho_T$$
$$\frac{\frac{82}{5}}{\frac{407}{20000}}=\rho$$
$$\rho=806$$
9K
