Can A=B be Proved Algebraically without Linear Transformations?
  • Context: Undergrad
  • Thread starter Thread starter Bipolarity
The discussion centers on proving the equality of two matrices A and B given that Ax = Bx for all column vectors x. It is established that if Ax = Bx for all x, then A must equal B, as this is a fundamental property of linear transformations. The proof can be approached without linear transformations by substituting specific vectors, demonstrating that corresponding columns of A and B are equal. Ultimately, the conclusion is that A = B can be derived from the equation (A - B)x = 0 for all x.
  • Matrix algebra
  • Understanding of column vectors
  • Concept of linear transformations
  • Basic properties of matrix equality
  • Study the properties of matrix equality in detail
  • Explore the implications of linear transformations in matrix theory
  • Learn about the role of basis vectors in matrix representation
  • Investigate alternative proofs for matrix equality without linear transformations
Mathematicians, students of linear algebra, and anyone interested in the foundational principles of matrix theory and proofs of equality in linear systems.
Bipolarity
Suppose A and B are matrices of the same size, and x is a column vector such that the matrix products Ax and Bx are defined.
Suppose that Ax=Bx for all x. Then is it true that A=B?
I know that this is true and I can prove it using the idea of transformation matrices, and viewing Ax and Bx each as linear transformations and showing that those two transformations are equivalent, but I was curious if this can be proved without appealing to the notion of a linear transformation.
Tips?
BiP
If you view them as linear transformations, then there's nothing to prove, since "Ax=Bx for all x" is by definition what A=B means. (This holds for all functions A and B that have the same domain, not just for the linear ones).
If you don't, then you can do it by trying many different choices of x. For example, if you try (1,0,...,0), then the equality tells you that the first column of A is equal to the first column of B.
A=B <=> A-B=0
write as
(A-B)x=0
transform way
Tx=0 for all x
T=0
matrix way
the matrix is defined by the action on any basis
Tx=0 for all x
let B be a basis
TB=0
T=0
  • · Replies 19 ·
