Baby Rudin problem driving me crazy
  • Context: Graduate
  • Thread starter Thread starter slipperypete
The discussion centers on proving a geometric problem from "Baby Rudin," specifically problem #16 from Chapter 1, which involves finding points \(\mathbf{z}\) in \(\mathbb{R}^k\) that satisfy certain distance conditions relative to points \(\mathbf{x}\) and \(\mathbf{y}\). The user correctly identifies that if \(2r > d\), there are infinitely many solutions, while if \(2r = d\), there is exactly one solution, and if \(2r < d\), no solutions exist. The user employs Rudin's Proposition 1.37(f) to support their reasoning but struggles with rigorous proof, particularly in the two-dimensional case.
  • Understanding of metric spaces in \(\mathbb{R}^k\)
  • Familiarity with Rudin's "Principles of Mathematical Analysis"
  • Knowledge of geometric interpretations of distance
  • Proficiency in mathematical proof techniques
  • Study Rudin's Proposition 1.37(f) in detail to understand its implications
  • Explore geometric interpretations of distance in higher dimensions
  • Learn about the properties of circles and spheres in \(\mathbb{R}^k\)
  • Practice constructing rigorous proofs for geometric problems
Mathematics students, particularly those studying real analysis, and anyone seeking to deepen their understanding of geometric proofs and distance properties in higher dimensions.
slipperypete
I started my way through baby Rudin recently, been able to answer every question so far, but I just can't get #16 from Chapter 1.
I (think) understand the geometry of it perfectly. I just can't prove it rigorously/analytically. I haven't been able to do anything for 3 days now, except think about this problem. So any help would be appreciated.
Suppose [tex]k\geq 3, |\mathbf{x}-\mathbf{y}|=d>0,\text{ and }r>0[/tex]. Prove:
(a) If 2r>d, there are infinitely many [tex]\mathbf{z}\in\mathbb{R}^k[/tex] such that [tex]\left|\mathbf{z}-\mathbf{x}\right|=\left|\mathbf{z}-\mathbf{y}\right|=r[/tex].
I have:
Since [tex]\left|\mathbf{z}-\mathbf{x}\right|=\left|\mathbf{z}-\mathbf{y}\right|=r[/tex], then [tex]2r=\left|\mathbf{z}-\mathbf{x}\right|+\left|\mathbf{z}-\mathbf{y}\right|[/tex]. Also, so [tex]\left|\mathbf{z}-\mathbf{x}\right|=\left|\mathbf{x}-\mathbf{z}\right|[/tex], so [tex]2r=\left|\mathbf{z}-\mathbf{x}\right|+\left|\mathbf{z}-\mathbf{y}\right|=\left|\mathbf{x}-\mathbf{z}\right|+\left|\mathbf{z}-\mathbf{y}\right|[/tex]. By Rudin's Proposition 1.37(f), [tex]\left|\mathbf{x}-\mathbf{y}\right|\leq\left|\mathbf{x}-\mathbf{z}\right|+\left|\mathbf{z}-\mathbf{y}\right|[/tex] for any [tex]\mathbf{x},\mathbf{y},\mathbf{z}\in\mathbb{R}^{k}[/tex]. Since [tex]\left|\mathbf{x}-\mathbf{y}\right|=d[/tex], this proposition makes it is clear that, given [tex]\mathbf{x},\mathbf{y}\in\mathbb{R}^{k}[/tex], there exists infinitely many [tex]\mathbf{z}\in\mathbb{R}^{k}[/tex] satisfying the equations [tex]2r>d,\left|\mathbf{z}-\mathbf{x}\right|=\left|\mathbf{z}-\mathbf{y}\right|=r[/tex].
I'm not sure this is a valid proof, because it would hold in [tex]\mathbb{R}^2[/tex]. But if I'm imagining the geometry correctly, there should be exactly 2 solutions in 2-space (i.e., the 2 points at which the circles of radius r, drawn about [tex]\mathbf{x}[/tex] and [tex]\mathbf{y}[/tex], intersect), not infinitely many. So I'm sure I'm missing something, but I don't see any holes in the proof.
I've also observed that under 2-space, if you square these equations: [tex]\left|\mathbf{z}-\mathbf{x}\right|=r,\left|\mathbf{z}-\mathbf{y}\right|=r[/tex] and apply the definition of norm, you get a system of two equations and two variables ([tex]z_1,z_2[/tex]). I know there's a solution there, which meshes perfectly with my understanding of the geometry behind this problem. Moreover, if you move on to 3-space and proceed in the same way, you get a system of two equations and three variables ([tex]z_1,z_2,z_3[/tex]). I know that this system will have infinitely many solutions. But I don't know how to prove rigorously that the 2-variable system is solvable or that the 3-variable system is unsolvable. Also, the way I understand the problem, r is fixed. But it is subject to some constraint (e.g., 2r>d). I don't know how to incorporate this constraint into the proof.
(b) If 2r=d, there is exactly one such [tex]\mathbf{z}[/tex].
I can't even figure out where to begin. I've noticed that if you set [tex]\mathbf{z}=\tfrac{1}{2}\left(\mathbf{x}+\mathbf{y}\right)[/tex], then [tex]\left|\mathbf{z}-\mathbf{x}\right|=\left|\mathbf{z}-\mathbf{y}\right|[/tex]. Also, this makes [tex]2r=2\left|\mathbf{z}-\mathbf{x}\right|=2\left|\tfrac{\mathbf{x}+\mathbf{y}}{2}-\mathbf{x}\right|=\left|\mathbf{y}-\mathbf{x}\right|=d[/tex].
I can derive this "solution" for [tex]\mathbf{z}[/tex] by squaring [tex]\left|\mathbf{z}-\mathbf{x}\right|=\left|\mathbf{z}-\mathbf{y}\right|[/tex] and going from there. But no relationship between 2r and d is needed to figure this out, so it would seem that [tex]\mathbf{z}=\tfrac{1}{2}\left(\mathbf{x}+\mathbf{y}\right)[/tex] should be true in the cases of 2r>d and 2r<d. So I'm stuck on this one.
(c) If [tex]2r<d[/tex], there is no such [tex]\mathbf{z}[/tex].
This is the one I think I've made the most progress on. I think Rudin's Theorem 1.37(f) should apply. Let me know if this proof works/doesn't work:
Assume a solution does exist. Since [tex]\left|\mathbf{z}-\mathbf{x}\right|=\left|\mathbf{z}-\mathbf{y}\right|=r[/tex] and [tex]\left|\mathbf{z}-\mathbf{x}\right|=\left|\mathbf{x}-\mathbf{z}\right|[/tex], then [tex]2r=\left|\mathbf{x}-\mathbf{z}\right|+\left|\mathbf{z}-\mathbf{y}\right|[/tex]. It's given that [tex]\left|\mathbf{x}-\mathbf{y}\right|=d[/tex], so if [tex]2r<d[/tex], then [tex]\left|\mathbf{x}-\mathbf{z}\right|+\left|\mathbf{z}-\mathbf{y}\right|<\left|\mathbf{x}-\mathbf{y}\right|[/tex]. But this contradicts Rudin's Theorem 1.37(f), which says that [tex]\left|\mathbf{x}-\mathbf{z}\right|+\left|\mathbf{z}-\mathbf{y}\right|\geq\left|\mathbf{x}-\mathbf{y}\right|[/tex]. Therefore, no [tex]\mathbf{z}[/tex] exists.
Any input would be appreciated.
  • · Replies 24 ·
