Background for designing CNT antennas for THz biosensing
12 replies · 3K views
pretysmitty
I want to use small molecular - preferably CNT - "antennas" to produce THz signals to monitor activity in biological systems. After some googling, I've been reading things like "absorption spectra", "energy bands", "spectroscopy", as well as a bunch of antenna-science related jargon... I need some references that will give me a solid foundation in these topics so that I can read literature with a bit more fluency. These subject seem to span from chemistry to electrical engineering/EM physics.
Not sure where to begin; I'm concerned I'll pick a book that's too broad and waste time on background reading.
Whoops. I'm a senior electrical engineering major. The most I know about optics/radiation is from Physics II and Gen Chem. Would prefer a primer on the basics of antenna design and physics/chem related to background topics for THz Radiation. I'm not sure how much quantum/Physical Electronics knowledge I need, but I recognize some stuff such as energy gaps, use of eV units, current density etc (please excuse my ignorance... it's been a while since physical electronics).
The references you suggested seem to assume a working knowledge of antennas, EM radiation etc.
Should I just pick up a general Engineering Physics Book and brush up on optics and radiation? Or are there any more specific primers you suggest?
Thanks for the input
Can you say more about why you are focusing on THz frequencies? What will be your signal generators (the antenna just couples the radiation to the far field)? There are lots of existing systems that monitor biological activity and transmit the information in the MHz to GHz region. Dealing with THz frequencies brings in lots of difficult issues...
One can easily (via AAV virus) attach small CNT "antennas" to neurons. The electrical impulse of the neuron should drive the nanocircuit and resonate the CNT antenna. Triangulation can then be performed to identify the precise location of the CNT.I've read that the size CNT's I need cannot produce sub-THz signals. I've also read that the THz band is naturally favored by CNTs. Also, even if a small enough CNT could produce a sub-THz signal, the wavelength would be too large to identify the precise location. Obviously, there are lots of questionable components to this idea. The biggest issues I can identify from a layman's perspective are
(1) the amount of THz noise generated by biological systems - will it drown out the CNT antenna? and
(2) the power of a signal generated by a CNT antenna: is the mV (generated by the neuron) input enough to overpower the surrounding noise? and
(3) what is the minimal bandwidth of a CNT antenna? Ideally they need a bandwidth of 1Hz (likely unfeasible)
Wow. That sounds to me like years of study to prepare yourself for that. More than a couple of references, I would say an additional degree.
That's not how antennas work. You need an oscillator or at least a very sharp transient to get the antenna to transmit any energy. Do you know the bandwidth of the electrical activity in neurons and the gaps? I'd guess it's in the kHz region or less.
Do you know what THz is? What in biological systems would generate THz radiation? Bioluminescence?
It would be good if you would do some reading about basic antenna theory. Antennas resonate when their physical dimensions are around the wavelength of the transmitted or received radiation. Look for Kraus or other good antenna books in your university library to get you started.
I see. I will definitely read the Kraus book. Also heard that Balanis is a good one.
Is it possible for an antenna to transmit in the near-infrared/IR region?
a transmitter/antenna for near/IR is a laser or light emitting diode
Gonna add “optics” to the list of stuff to read up on
I second this. It looks about as in-depth as something you'd do in the course of getting a doctorate. But that's just my uneducated guess, as I don't have a doctorate.
Also, this wiki quote doesn't make this task sound any easier.
Terahertz radiation occupies a middle ground between microwaves and infrared light waves known as the “terahertz gap”, where technology for its generation and manipulation is in its infancy.
... the generation and modulation of coherent electromagnetic signals in this frequency range ceases to be possible by the conventional electronic devices used to generate radio waves and microwaves, requiring the development of new devices and techniques.
Beware of instant gratification - but I doubt that you would apply that philosophy to your specialty. You will surely have done a load of background reading there.
To know what it is that you actually need to know, you will need a fair bit of background knowledge; that's why professionals are needed in their field. Knowledge is a bit like advertising. If you actually knew which part is 'wasted' then you could save a lot pf time and money. Lack of knowledge could expose you to the baseless enthusiasm of equipment salesmen.
Yep.
Sounds to me that you need a TEAM for this exercise but I guess that could be hard to arrange.
I don't know about THz frequencies but we use Harmonic Radar for tracking insects. The part on the insect is a passive reflector which re-radiates the incoming radar at a harmonic frequency.
https://newzealandecology.org/nzje/2027.pdf
Cheers
