Ball in gravity: how high does the ball go? Initial velocity?
The discussion centers on solving the kinematic equation for a baseball thrown vertically, represented by h(t) = 5.9 + 69t - 16t². The initial velocity is confirmed as 69 feet per second, while the acceleration due to gravity is correctly identified as 32 ft/s², not 9.81 m/s². Participants clarify that to find the maximum height, one must evaluate the derivative of the height function and set it to zero, leading to the time at which the maximum height occurs. The correct maximum height can then be calculated using the original height equation.
  • Understanding of kinematic equations in physics
  • Familiarity with derivatives and their application in optimization
  • Knowledge of units of measurement in physics (feet and seconds)
  • Basic algebra for solving quadratic equations
  • Learn how to derive and apply kinematic equations in different contexts
  • Study the concept of optimization using calculus, specifically finding maxima and minima
  • Explore the differences between metric and imperial units in physics calculations
  • Practice solving real-world problems involving projectile motion
Students studying physics, educators teaching kinematics, and anyone interested in understanding projectile motion and its mathematical representation.
mayo2kett
i know this is a really simple problem but I'm kinda stuck on it since i don't know what to do with the equation I'm given :eek: ...
Having won the game, a baseball pitcher hurls the ball up in the air. Its height in feet t seconds after the throw is given by
h(t)=5.9+69t-16t^2
How high does the ball go?
What is its initial velocity?
Are you familiar with derivatives?
All you have to do is maximize that function and evaluate the derivative of that function at 0.
cookiemonster
Thowing the ball up: h=initial height + v0*t - (1/2)gt^2. That's the usual gravity accel equation-thing.
69 is the initial velocity. It must be feet per second, because 16=1/2 of 32 and g=32 ft/s^2, or so they say. 5.9 is the initial height, they gave it to you.
The total time from when it goes up and comes back to the initial height is when height=initial height,
so,
height-initial height = 0 = v0 * t - 1/2 gt^2, solve for t, the time.
When you get that, 1/2 of that is on the way up to its max height.
So put 1/2 of that time into the first equation to get the max height.
Holly's method allows you to do it without derivatives. That is, you just compare it to the standard form of the "kinematical equation."
i have learned derivatives but i was trying to learn how using the formula...
i now understand how to get the initial velocity and height ( i didn't know they gave then to me like that), but I'm a little stuck on the max height... this is the work i did:
0 = 69t-(1/2)(9.81)t^2
t=14.067
(1/2)14.067=7.03
then:
h=hi+ v0*t - (1/2)gt^2
h=5.9+69(7.03)-(1/2)(9.81)(7.03)^2
=248.56
but this answer seems to be wrong... I'm not sure what i did, was it just a multiplying error?
You have to identify the numbers in the kinematic equation, which is strictly mathematical (pre-physics, if you will). You are imposing unwarratned physics. Perhaps it would help you to imagine that you are on some alien planet. Then, consider the kinematical equation in the form that holly suggested. (Of course, also as holly pointed out, this is representative of Earth in the units given, but it is a good exercise to consider the more fundamental meaning of the kinematical equation.) In other words, 9.81 is inappropriate in this case.
ok so i understand why i shouldn't included gravity in this but how else can i solve for t?? i think I'm making this much harder than it should be, but i never learned anything about kinematics...
whouldn't it just be easier if i took the derivative of this: h(t)=5.9+69t-16t^2
so: h(t)'=69-32t
but what do i do from here to get the max height? our physics teacher has only taught us using formulas...
t=14.067
(1/2)14.067=7.03
then:
=248.56
What you did wrong was to put your own value for g in the equation. The original equation was perfectly fine. Why did you put g = 9.81?
As Holly explained, this equation uses feet for distance units, not meters. So g = 32 ft/s^2.
To use Holly's method, do this. Find the times where the height is the original height. Why? That equation is trivial to solve! You were on the right track, but you modified the given equation for some reason.
So: 0 = 69t-16t^2 = t (69-16t)
The solutions are t = 0 and t = 69/16 = 4.31 sec.
Now you take it from here. Using the original equation for height, of course!
so: h(t)'=69-32t
The maximum height is where the derivative (the velocity!) is zero. Find the value of "t" that gives zero velocity. Then find the height at that time.
Do it both ways and compare your answers. They'd better match.
you guys are awsome thanks so much... i understand what i was doing wrong now, i just didn't understand holly's explanation correctly... we've never learned that gravity could be anything besides 9.81. :)
Make sure you aren't including me in your "thanks," because I didn't learn any of "my" method by myself. Turin, marcus, Doc Al, cookiemonster and the other Brains of the forum showed me how to do it before. It's these Brains I am mighty thankful for...when one of them answers you, you can rest easy...THEY ARE GREAT!
I think you earn the primary credit for this one, holly. It is an arrogant person who assumes self sufficiency for their own knowledge.
Yeah, really. You think we figured all this out on our own? You're just doing what we're doing, so all's fair!
cookiemonster
