How Do You Calculate Initial Velocity with Angled Projectile Motion?
  • Thread starter Thread starter Michels10
    Angle Ball
The calculation of initial velocity for a projectile launched at an angle of 50 degrees is determined using the equations of motion. Given the landing coordinates (4, 7, 0), the initial velocity (vo) is calculated to be approximately 8.957 m/s. The equations used include x = (vo * cos(50) * cos(θ)) * t and y = (vo * cos(50) * sin(θ)) * t. The time of flight (t) is derived from the x-coordinate, leading to the final velocity calculation.
  • Understanding of projectile motion equations
  • Familiarity with trigonometric functions (sine and cosine)
  • Basic algebra for solving equations
  • Knowledge of gravitational acceleration (g = 9.8 m/s²)
  • Study the derivation of projectile motion equations
  • Learn how to apply trigonometric identities in physics problems
  • Explore numerical methods for solving nonlinear equations
  • Investigate the effects of different launch angles on projectile trajectories
Students in physics, educators teaching kinematics, and anyone interested in understanding projectile motion calculations.
Michels10
A ball is launched from the origin at an angle of inclination of 50 degrees above the xy plane. If the ball lands at coordinates (4,7,0), find the initial velocity of the ball.
x=(voCos(50)Cos(theta))t
y=(voCos(50)Sin(theta))t
Unfortunately, I have the answer, but I am unaware of how it was obtained.
x=.3189vot
y=.5581vot
z=vosin(50)t-4.9t^2
z=0 when t=.1563
so vo=sqrt(4/(.3189)(.1563)) = 8.957m/s
Can anyone give me some insight as to how the x and y was solved for?
Hi Michels10, welcome to PF.
x= vo*cosθ*t. So t = x/vo*cosθ...(1)
y = vo*sinθ*t - 1/2*g*t^2...(2)
x and y is given. Angle of projection is given.
Substitute the value of t in eq.(2) and solve for vo
Hi, thank you for the response!
I made an effort to plug in t and I did not receive the correct answer.
7=vo*sin(50)(4/(vo*cos(50)))-(1/2)*(9.8)*((4/(Vo*cos(50)))^2
does this look correct?
I plugged it into wolfram and ended up with a result of +-(9.21823 i)
The above statement indicates that the angle is above the xy plane, and the ball lands on the xy plane at the co-ordinates (4, 7, 0). So here y = 0 and x = sqrt(4^2 + 7^2).
Now try to solve the problem.
  • · Replies 36 ·
  • · Replies 39 ·
  • · Replies 31 ·
  • · Replies 38 ·
