Electric Field and Work on a Moving Charge
  • Thread starter Thread starter anthonych414
    Electricity
The discussion focuses on the physics of electric fields and work done on a moving charge. The force acting on a charge +q in a constant electric field ε V/m is calculated using the formula F = εNq, directed positively. The work done by this force when the charge moves a distance d is expressed as W = Fd. The voltage at position x = d is derived from the relationship ε = -dv/dx, leading to Vd = -εd. The relationship between electric potential energy loss and work done is confirmed through energy conservation principles, indicating that the kinetic energy (KE) of the charge at x = d equals the loss in electric potential energy.
  • Understanding of electric fields and forces
  • Familiarity with the work-energy theorem
  • Knowledge of voltage and electric potential energy
  • Basic concepts of kinematics and dynamics
  • Study the relationship between electric fields and forces in detail
  • Learn about the work-energy theorem in physics
  • Explore the concept of electric potential energy and its calculations
  • Investigate kinematic equations for motion under constant acceleration
Students studying electromagnetism, physics educators, and anyone interested in the principles of electric fields and their effects on charged particles.
anthonych414
Given an electric field ε V/m that is constant in the x-direction and a charge +q C located at the origin and free to move in the x-direction. (a) What is the magnitude and direction of the force F acting on q? (b) If q moves under the influence of F a distance d m, how much work is done by F? (c) Assuming the voltage at the origin to be zero, what is the voltage Vd at x = d m, bearing in mind that ε = -dv/dx? (d) How is the loss in electric potential energy related to the work done by F? (e) Assuming the charge has a mass m kg and zero velocity at the origin, show that the KE of the charge at x = d is equal to the loss in electric potential energy.
a. F= εNq in the positive direction
b. W=Fd
c. I can guess that it's -εx but I don't know how to explain it properly
d. Equal by conservation of energy.
e. Not too sure how.
Thank you in advance.
a-d: right.
For (e), I would use energy conservation. Alternatively, calculate the acceleration, and use this to determine the velocity there.
The question uses an ugly way to deal with units :(.
  • · Replies 16 ·
